valve clearance problems - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 05-23-2010, 04:38 PM   #1
mbyrne27
Fan#: 75310
What I Drive: 2003 silver svt
FF Reputation: 1 mbyrne27 Good Standing Member
Ok guys i bought a 2003 svt with a blown head gasket and i took the head off and had the head milled and new valve seats installed. After i put it all back together i found the valve clearance's were off. Ive figured out what size tappets i need but i cant figure out where to get them. I work as a tech at a ford dealer but cant get them threw ford. Do you guys know any after market companys that make them???? Any help would be great
mbyrne27 is offline
Old 05-23-2010, 05:26 PM   #2
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, 03 ZX3
Points 2,926, Level 33
Points: 2,926, Level: 33 Points: 2,926, Level: 33 Points: 2,926, Level: 33
Level Up 18% Completed
Forum Activity 4%
FF Reputation: 8 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
PM sent.
Points to ponder:
When you are dead, you do not know you are dead.
It's only painful for others.
Same applies to stupid.
02ztsian is online now
Old 05-24-2010, 09:05 AM   #3
mstng46
Fan#: 54724
What I Drive: '03 CD Silver SVT Focus
Points 2,286, Level 28
Points: 2,286, Level: 28 Points: 2,286, Level: 28 Points: 2,286, Level: 28
Level Up 91% Completed
Forum Activity 2%
FF Reputation: 1 mstng46 Good Standing Member
dude your fine, put a thicker mls head gasket in...use the stock buckets and at least this way you don't have to worry about finding a new size....cfm sells them...
mstng46 is offline
Old 05-24-2010, 12:04 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,065, Level 85
Points: 18,065, Level: 85 Points: 18,065, Level: 85 Points: 18,065, Level: 85
Level Up 44% Completed
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Try reading his post and not just the title next time.
Also remember that the SVT tappers/buckets are different that the standard zetec tappets/buckets.
Curious what your clearances were and if you tried playing musical buckets?
and dug this up --> http://forums.focaljet.com/zetec-tun...ce-help-2.html
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 05-24-2010, 12:28 PM   #5
mbyrne27
Fan#: 75310
hey yea ive played musical buckets and got a couple to fit correctly but now im looking for 5 buckets that i cant find
mbyrne27 is offline
Old 05-24-2010, 06:06 PM   #6
RecoilRob
Fan#: 21404
What I Drive: 04, CD Silver SVTF
FF Reputation: 8 RecoilRob Good Standing Member
Have you installed the head yet? If not, and it always is a great idea to set valve clearances on the head before installing it, you can pull the cams and touch the head of the valve to reduce it a bit. I'm assuming your clearances are tight, yes? If loose, the seat needs sunk a bit to bring the valve up. Have you talked to the machine shop about this problem? My favorite guys here in town will work with me if I run into something like this. I tell them which valve needs to come up or down and how much and they make it so. Might be worth a call.....
RecoilRob is offline
Old 05-24-2010, 07:03 PM   #7
WuNgUnSVT
WuNgUnSVT's Avatar
Fan#: 15803
What I Drive: '02 Sonic Blue SVT Focus, '03 Wagon
Points 5,041, Level 45
Points: 5,041, Level: 45 Points: 5,041, Level: 45 Points: 5,041, Level: 45
Level Up 46% Completed
FF Reputation: 34 WuNgUnSVT Great Standing Member
I'd be a little worried about grinding off any surface hardness on the valve stems...although with new/machined seats, he's likely tight all the way across, which of course, means grinding won't help. :)
Originally Posted by MattyKrackSVT View Post
...go threw your posts and see who can't spell retard...
WuNgUnSVT is offline
Old 01-16-2013, 07:16 PM   #8
200two-zx3
200two-zx3's Avatar
Fan#: 108491
What I Drive: 2002 blue zx3
FF Reputation: 2 200two-zx3 Good Standing Member
I'm running into the same issue with my 02 zx3, I have a little pitting in my exhaust valve face area, so I took it to my local performance shop to have the valves ground and then realized if I did this id need new buckets or lifters whatever you like to call it, has any one found any new info on this I've found these pt numbers but still haven't found who sells them???
YS4Z-6500-DADSELECT-FIT 17.145MM THICK
YS4Z-6500-EASELECT-FIT 17.175MM THICK
YS4Z-6500-EABSELECT-FIT 17.205MM THICK
YS4Z-6500-EACSELECT-FIT 17.235MM THICK
YS4Z-6500-EADSELECT-FIT 17.265MM THICK
YS4Z-6500-FASELECT-FIT 17.295MM THICK
YS4Z-6500-FABSELECT-FIT 17.325MM THICK
YS4Z-6500-FACSELECT-FIT 17.355MM THICK
YS4Z-6500-FADSELECT-FIT 17.385MM THICK
YS4Z-6500-GASELECT-FIT 17.415MM THICK
YS4Z-6500-GABSELECT-FIT 17.445MM THICK
YS4Z-6500-GACSELECT-FIT 17.475MM THICK
YS4Z-6500-GADSELECT-FIT 17.505MM THICK
YS4Z-6500-HASELECT-FIT 17.535MM THICK
YS4Z-6500-HABSELECT-FIT 17.565MM THICK
YS4Z-6500-HACSELECT-FIT 17.595MM THICK
YS4Z-6500-HADSELECT-FIT 17.625MM THICK
YS4Z-6500-JASELECT-FIT 17.655MM THICK
Claim not, dynos prove all!
200two-zx3 is offline
Old 01-16-2013, 08:31 PM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 50,525, Level 100
Points: 50,525, Level: 100 Points: 50,525, Level: 100 Points: 50,525, Level: 100
Level Up 0% Completed
Forum Activity 26%
Activity: 26% Activity: 26% Activity: 26%
Buy-Sell-Trade Rating: (28)
No one sells them any more , your machine shop should be able to set clearances , if the valve job was done properly they all should be to tight , by checking the clearances then cutting the valve stem you can set the clearances to the buckets
This why I charge 200.00 to set clearances , it is very time consuming
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 01-16-2013, 08:50 PM   #10
200two-zx3
200two-zx3's Avatar
Fan#: 108491
Ok I feared this but with my machining experence I shoul have no problem with this I was just hoping not to remove the surface hardness from the valve but if this is how we must do it then ill give it a try,
Thanks by the way
