Dash Brake and ABS lights vs Wheel Speed Sensor - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-20-2010, 09:05 PM   #1
239rsw
239rsw's Avatar
Fan#: 15133
What I Drive: 2002 Yellow ZX3
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 239rsw Good Standing Member
My brake and abs lights are on. I have an automatic 2002 ZX3. After starting the car, with the emergency brakes engaged, I pressed and depressed the switch under it. That would make the light go off and then back to on.
I disengaged the ebrake (light off) and drove. After a couple of minutes driving, the brake light turns on again. This time, while the car is idle, pressing and depressing the switch will not make the light turn off
Would a defective wheel speed sensor make the brake light turn on?
2002 ZX3 @ 333K
Last Update : 10/05/2014
239rsw is offline
Old 05-20-2010, 09:52 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
Posted via FF Mobile Brake light is for fluid level and e-brake application only. I personally have had intermittent brake light problems, though not recently - switches tested OK, bypassed them and still not proper operation - when it acts up, switch positiondoesn`t affect light, then randomly goes back to normal operation. with light on only when either switch activated. ABS light could be sensor, tone ring, or something else - barring an obvious unhooked or broken wire, code reading of ABS would avoid just throwing parts at the problem randomly...
sailor is offline
Old 05-21-2010, 11:50 AM   #3
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
A failing ABS unit will give you the red E-brake light after a little while of driving (from own experience)- As long as your speedo & odo works ok yhe VSS should be ok.
nilskje is offline
Old 06-04-2010, 11:02 PM   #4
239rsw
239rsw's Avatar
Fan#: 15133
I think that's what happened. When I replaced the front wheel bearing, the shop pressed the bearing in the wrong position, which made the ABS light. After a while of driving, my wife noticed that the ebrake has lighted. Confused, she pulled up the handle while driving on a highway on a summer day and ended up in a park-and-ride with a melted wheel bearing on the rear wheel.
I replaced both rear wheels with drum-hub(with bearing) assembly. I think the store gave me the ones for a non-ABS assembly because when the front wheel bearing was replaced again, both lights are still on.
Had an emission test last weekend. They got two codes (not related to emission) C1235 and C1236. The computer is not getting any signal from the rear sensors.
2002 ZX3 @ 333K
239rsw is offline
Old 07-05-2010, 09:06 PM   #5
chaseb913
chaseb913's Avatar
Fan#: 75962
What I Drive: 04 eggyolk yellow ZX3
FF Reputation: 1 chaseb913 Good Standing Member
did u buy your drums from autozone? i did and i have the exact same problem as you... pulled the drums today and they didnt have a tone ring for the abs on them thus cases the abs and ebrake light...
chaseb913 is offline
Old 09-19-2010, 07:20 PM   #6
chaseb913
chaseb913's Avatar
Fan#: 75962
did you ever solve your abs problem??
Old 09-20-2010, 09:53 AM   #7
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
He aint gonna come back...lol
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
Old 10-06-2010, 10:38 PM   #8
239rsw
239rsw's Avatar
Fan#: 15133
No. I didnt replace the drums yet. I also got it from autozone.
I had an emission sometime in June and while i was at the shop, i asked them to read the code. The mechanic said that it is not getting any signal from the rear ABS sensor. I will probably replace it next year.
2002 ZX3 @ 333K
239rsw is offline
Old 10-15-2010, 08:59 PM   #9
jesusamares
jesusamares's Avatar
Fan#: 64713
What I Drive: 2000 Rainforest SE SOHC SPI
FF Reputation: 1 jesusamares Good Standing Member
damn that sucks, one of my rear brake drums is stiff as hell i recently replaced my tires and when they were done installing them at the shop the dude said that my rear passenger wheel doesnt move, and i need to replace the speed sensor on my driver side. it's just ford sells all these parts like if it was a mercedes benz or bmw vehicle, too pricey.
!Stock_2000_Focus!---[S.E.-S.O.H.C.-S.P.I.]
jesusamares is offline
