Won't Shift Out of Park - Focus Fanatics
Old 05-19-2010, 03:06 PM   #1
TigerTank77
Fan#: 75220
What I Drive: 2000 Tan Ford Focus LX 2.0 SOHC
FF Reputation: 1 TigerTank77 Good Standing Member
Afternoon everyone.
So my 2000 Focus LX has decided it's not going to shift out of park anymore, as well as not have working brake lights.
I've tried replacing the brake light fuse and the brake pedal switch, but of course, nothing.
So I think it's either the shifting actuator or the shift lock solenoid.
Problem is, I don't know which, and I'd like to avoid replacing the wrong part and/or going to a garage if at all possible.
Heeeeeeeelp.
TigerTank77 is offline
Old 05-19-2010, 03:26 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing MemberEgz Excellent Standing Member
I would double check the fuses first, just to be safe, before replacing the solenoid.
http://www.focusfanatics.com/forum/showthread.php?t=182747
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 05-19-2010, 05:19 PM   #3
FocusRebuilder
Fan#: 62313
What I Drive: 2006 ZX5 SES, Silver
FF Reputation: 5 FocusRebuilder Good Standing Member
If you're willing to take the shifter assembly out and tinker with it, you might as well replace the whole thing-- it's easier and probably cheaper. I believe the 05-07 shifter is the same as yours, so just call around the local junkyards for a 2007 (or newest you can get) shifter assembly. It's not a high-demand part, or one that takes much labor to pull, so the junkyards should have plenty of them and they should be cheap.
In the meantime, do you know how to work the manual over-ride? It's a small slot to the right of the track and it's covered by a small, round plastic cover. Remove the cover and push a key or screwdriver down in the slot to over-ride the shift lock.
FocusRebuilder is offline
Old 05-21-2010, 10:46 PM   #4
miragesmack
Fan#: 65159
What I Drive: 2000 Sony Edition Sedan
FF Reputation: 3 miragesmack Good Standing Member
Buy-Sell-Trade Rating: (9)
Mine was doing the same thing, but the brake lights worked. My issue was the shift actuator in the console, which I bypassed like mentioned above with a screwdriver. One thing my car did that may help you out, when the door was open and key OUT of ignition, my door chime made a constant screeching sound, which I think indicated a actuator problem. That went away once fixed.
FYI, you cannot buy just the actuator alone new, you must buy the whole shifter assembly, which is kinda pricey. I got one used, cleared up all my problems.
miragesmack is offline
