Heater selector switch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-17-2010, 06:28 PM   #1
panelguy
Fan#: 39992
What I Drive: 2000 focus se
Points 541, Level 10
Points: 541, Level: 10 Points: 541, Level: 10 Points: 541, Level: 10
Level Up 82% Completed
FF Reputation: 1 panelguy Good Standing Member
Hello all,
The heater selector switch wont change the position of the air flow, it is blowing on defrost and doesn't matter the switch position.
The switch was a bit stiff for awhile now it moves freely, obviously something has let go.
My question is would the problem be with the cabling or electric. Have you had this problem ?
My car is a 2000 Focus wagon.
Thanks
panelguy is offline
Old 05-18-2010, 02:47 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,833, Level 73
Points: 12,833, Level: 73 Points: 12,833, Level: 73 Points: 12,833, Level: 73
Level Up 96% Completed
Forum Activity 99%
Posted via FF Mobile Mechanical from your description, now you need to look at it to see just what let go, avoids buying parts by guess...
sailor is online now
Old 07-12-2010, 07:29 PM   #3
panelguy
Fan#: 39992
On further investigation I see there is no cabling hooked on to the heater position switch , just wires running down to blend doors next to the gas pedal.
The fact that there was a lot of resistance when moving the knob and now it moves freely makes me think the switch itself is broke.
Does this sound logical to you?
Thanks.
panelguy is offline
Old 07-12-2010, 11:22 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Posted via FF Mobile If the knob moves and the wires (cables) don`t, either the knob is spinning on the shaft or the shaft isn`t moving the mechanism properly. (yeah, it`s broke!)
Old 07-15-2010, 07:44 AM   #5
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
Thanks.
Are you saying there are no mechanical connections to the switch? I thought the position switch had a metal cable attached to it which operated the flap.
niggly51 is offline
Old 07-15-2010, 08:19 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
No, it controls electric motors that actuate the vent and the temperature blend door. It is possible that the switch went out. I haven't looked at this myself, but if you can figure out how to test the leads going to each motor for resistance then that will tell you if the motors are not good, and by process of elimination you can assume that the switch is most likely bad.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-15-2010, 09:12 AM   #7
niggly51
niggly51's Avatar
Fan#: 74542
I did not think it was mechanical from his description, but was confusedby the fact it went stiff and then let go and was loose. This is usually what happens to the mechanical controls. Being electrical then switch replacement would seem the obvious move. Sorry for confusing things.
niggly51 is offline
Old 07-15-2010, 09:38 AM   #8
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
when my switch went out it actually melted its self and so you couldn't turn it...until i tried harder and it broke. I would just pull it out and visually inspect it. Especially in an '00.
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 08-01-2010, 01:47 PM   #9
panelguy
Fan#: 39992
Thanks for your answers.
I changed the switch which does have cables leading to the blend door.
It work fine for a couple of weeks then broke again.
I can freely move the blend door by hand and can change the air movement position by hand.
I'm not sure whats next but at $60.00 for the switch I won't change it again until I find the problem.
panelguy is offline
Old 08-01-2010, 02:30 PM   #10
niggly51
niggly51's Avatar
Fan#: 74542
Sounds as though the cables are not routed correctly, putting a strain on the mechanism. Did you lubricate all moving parts on reassembly? Did you use a new switch and cables?
If you think I've been able to help, just say
niggly51 is offline
