Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 05-17-2010, 04:43 PM   #1
Deaner
Deaner's Avatar
Fan#: 39531
What I Drive: 2002 ATX Twilight Blue ZX5
FF Reputation: 31 Deaner Great Standing Member
Buy-Sell-Trade Rating: (8)
How to Fit a Double Din in a 00-04 Focus
Warning: This install will not allow you screw your bezel into place. If you require the bezel to be screwed in, you must modify the bezels face for the radio to slide in from the front rather than the back.
I am NOT held liable for any damage or stolen property.
___________________________________________
This is a how to, that I came up. It's a very easy way on installing a double din. This tut is meant for all models in 00-04 Foci.
In order to get this installed you must have the Metra kit 95-5806 and the double din radio of your choice.
1. Start by removing your aftermarket radio and dash kit or factory radio.
2. Once removed start removing the 4 screws that hold the bezel in place. This can be found only after removing the radio. You will need a 7mm socket to remove the screws.
3. After the screws have been removed, pull out the ashtray and press down on the tab on the top and then gently slide out the entire tray. It helps if this is off the bezel, you'll understand during reinstall.
4. The bezel is snapped into place so gently with force pull off the bezel from the sides in order to remove the bezel.
5. Now start by disconnecting all the HVAC wires, cig lighter wires, and hazard switch wires.
6. Once you have the bezel free from the dash, start by removing all parts attached to the bezel(except the cig lighter) soo that your bezel will be naked.
As you can see in pictures, the radio will NOT slide in from the front without trimming of the top and bottom tabs of the bezel and rounding off the top corners more.
In this how to you will most likely not have to trim you bezel in order to install your radio. I know some of you like the clean look of an install and rather not scratch and mess up the face of the bezel in order for the radio to slide in from the front.
NOT all double dins are the same. Some are differently and will require you to trim the bezel a little. In order to check this, stand your radio face up and slide the bezel over the front. If the bezel does not slide more that 1/4 inch over then some trimming maybe be required. I went ahead and trimmed mine(I found out I didn't have to for my radio, i regret doing so haha). Here is an example of what needs to be trimmed:
7. Once the bezel is naked, it is time to attach the radio to the bezel. Follow by the steps I did in this video:
YouTube Video
8. Once you have the radio attached to bezel, cut the the tab off that is circled in the picture below. Without cutting this tab, the bezel will not fit into the dash flush.
9. Once the tab is cut off, you can now put the bezel back together. Wire up the radio, connect the radio, HAVC, cig lighter and hazard switch. The radio will fit, but it will be snug. Slide the radio into place snugly, then snap the bezel into place. Then put the ashtray back in and your done!
10. Now sit back and enjoy your new double din radio.
¸_____
/_|_|__\__
l(o)____(o)l
<--EüRöFöCüS: 02 Twi Blu ZX5 FoFo Euroness SOLD!!!
New toy: TOYota FJ Cruiser 4x4
Deaner is offline
Fan#: 1
Old 05-17-2010, 05:20 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
FF Reputation: 43 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (16)
your pics don't work, and for your youtube link you need the url not the embed code
Advocare 24 Day Challenge!
SkyPilot is offline
Old 05-17-2010, 05:38 PM   #3
Deaner
Deaner's Avatar
Fan#: 39531
Photobucket is going through some maintenance or something.
¸_____
/_|_|__\__
l(o)____(o)l
Deaner is offline
Old 05-17-2010, 07:56 PM   #4
FocusFreak09
Flat Black King
FocusFreak09's Avatar
Fan#: 51243
What I Drive: 2003 Silver Focus SE
FF Reputation: 30 FocusFreak09 Great Standing Member
Buy-Sell-Trade Rating: (9)
good write up dean, i am noe going to do this as soon as i get some cash and a new bezel.
R.I.P. Izzy
SedanRevolution #73
Stretch&Poke=
FocusFreak09 is online now
Old 05-17-2010, 10:19 PM   #5
miragesmack
Fan#: 65159
What I Drive: 2000 Sony Edition Sedan
FF Reputation: 3 miragesmack Good Standing Member
Nice writeup. Hard to tell in the video, are the side pieces from the kit flush with the bezel, or flush with the stereo? Do you have any pics installed in your car yet?
miragesmack is offline
Old 05-17-2010, 10:50 PM   #6
death_bomber
Aggresive Not Crazy
death_bomber's Avatar
Fan#: 39461
What I Drive: 2001 RED LX
FF Reputation: 6 death_bomber Good Standing Member
X2 i would like to see what install pics are like and how would you rate the quality on the install? Is it flush? does it have pockets on the corners or top of the HU?
Im overall upset that i bought a single din when i could have waited 2 years lol but hey im glad it's available now
death_bomber is offline
Old 05-18-2010, 04:20 PM   #7
Deaner
Deaner's Avatar
Fan#: 39531
OOPS! I meant to post the after pic and the brackets fit flush with to the bezel. I will fix the first post
¸_____
/_|_|__\__
l(o)____(o)l
Deaner is offline
Old 05-19-2010, 11:38 AM   #8
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2008 Mazda 3 Sedan
FF Reputation: 28 misfire Great Standing Member
Buy-Sell-Trade Rating: (11)
im thinking about doing this
Will aka Misfire
2010/2011/2012/2013 Ford Master Certified Service Advisor
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 05-22-2010, 06:33 PM   #9
F1SportsFan
F1SportsFan's Avatar
Fan#: 65473
What I Drive: 2002 Pitch Black SVT 3 door
FF Reputation: 3 F1SportsFan Good Standing Member
Awesome!!! Does the bezel move around at all or rattle when you are driving?
F1SportsFan is offline
Old 05-22-2010, 10:47 PM   #10
VAfromMN
Fan#: 20592
What I Drive: 2004 Screaming Yellow Focus SVT 5-d
FF Reputation: 8 VAfromMN Good Standing Member
It's been about 25 years since I last installed a radio. I'm looking to put a Pioneer AVH-P3200BT DVD Receiver in my '04 Focus SVT 5-door. Bring me up to date. If I use the factory connectors, will I keep my sub, or do I have to go to an aftermarket setup? Any advise would be appreciated.
VAfromMN is offline
