ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
#21 | ||||
2.75" better for N/A or forced induction like myself?
2006 sonic blue zx5 GT2871r turbo.
#22 | ||||
When going with a bigger MAF you should also lower your minimum maf voltage setpoint because you will be closer to it with a larger maf at idle. It could possibly set off codes.
Another trick is to put a honeycomb air straightener out of a GM maf in your sample tube. The honeycomb out of a 3" GM maf will press fit directly into a ford 70mm sample tube. It will dramaticly clean up your maf's voltage signal and makes your MAF respond the same way regardless of positioning near bends. MAfs are designed to meter Mass Air flow when the air is at or near standard pressure and density. When you put your MAF in a blow through configuration after the turbocharger you are trying to make it meter air in a way it is not designed to. It is much harder to tune in that configuration because of the dynamics of the environment. I always make mine draw through. It works much better for me. Keep in mind it is only truly nessecary to upgrade your MAF when when you have reached the limit of its metering capability(4.5+ volts). If your routinely getting way up there then you should consider upgrading MAfs. I dont think the stock Zetecs will max out thier stock MAF but if your going turbo you will need at least a 70mm. Last edited by ford_boy; 05-15-2010 at 08:14 PM. Reason: more info |
#23 | ||||
Token Engin-nerd
If you read the wiki article I linked you will understand that it IS designed to do that.
#24 | ||||
So your saying that maf hotwire setup is just as accurate when that aircharge is 300 degrees as it is when its at 60. I highly doubt it.
You can go blow through if you want. I just do what works best or me. |
#25 | ||||
Token Engin-nerd
Yes.
#26 | ||||
soon to be turbo!
the only reason i would go to a 3 inch maf tube is if i were to run a 75mm mustang throttle body with a custom ITM. so once it hits the 67mm throttle body it's being restricted by the decrease in diameter the throttle body. right? |
#27 | ||||
FF Affiliate
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#29 | ||||
FF Affiliate
I am only going to start with #1 because I dont have the time or am I going to take it to teach you tuning
The Focus has closed loop , the closed loop function trims the fuel automaticly at idle and part throttle , change your MTF by how much the closed loop is trimming by % wise and your done Most cases you can do idle , 2000 , 3000rpm in "N" and your about 85-90% finished with your MTF till you go open loop WOT No forcing open loop , having to drive and having to watch AF , just log and slight changes when you return , faster , easier , let the ECU do as much of the work as you can Tom
#30 | ||||
Ah, I see. You go about it a different way than me.
I view closed loop operation as a variable, and opt to disable it. You use it to your advantage. Perhaps you didn't notice the end Quote:
I agree, your way does sound easier. My way must be old school. But hey, works great for me. |
| Tags |
| 3" maf, blow through |
| Thread Tools | |
| Display Modes | |
