HOW TO: rear control arm poly bushings - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-09-2013, 12:33 PM   #21
dardack
Fan#: 114151
What I Drive: 2003 Red SE Wagon PZEV 2.3L engine
Points 701, Level 14
Points: 701, Level: 14 Points: 701, Level: 14 Points: 701, Level: 14
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 3 dardack Good Standing Member
You can get it $90 if you can get a code off the coupon:
http://www.ebay.com/itm/HARBOR-FREIG...item2a2b991c36
dardack is offline
Old 06-08-2013, 04:56 PM   #22
whammo
Fan#: 10692
Points 114, Level 2
Points: 114, Level: 2 Points: 114, Level: 2 Points: 114, Level: 2
Level Up 28% Completed
FF Reputation: 1 whammo Good Standing Member
Question,
Could the symptoms of these bushings failing include a noisy rear end that wallows alarmingly in turns on the freeway?
whammo is offline
Old 06-08-2013, 08:08 PM   #23
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,617, Level 48
Points: 5,617, Level: 48 Points: 5,617, Level: 48 Points: 5,617, Level: 48
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 36 thenorm Great Standing Member
depends on the type of noise. is it during bumps or smooth driving.
in my case on the freeway i had a rythmic wobble back n forth, sometimes the movement might be accompanied by a little knock or clunk.
another source of noise and loose handling is the shocks, which might be a reason for the wallowing you speak of.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 06-09-2013, 04:15 AM   #24
whammo
Fan#: 10692
Points 114, Level 2
Noise comes while going over bumps.
Shocks were just replaced on last visit to mechanic's, didn't fix the problem.
whammo is offline
Old 07-01-2013, 10:11 PM   #25
PWSVT
Fan#: 92678
What I Drive: 2003, Black SVT
FF Reputation: 1 PWSVT Good Standing Member
Excellent information. Thanks everyone. Spent most of today trying to get the rear arms apart. Ended up dropping the whole subframe to try and get these bolts out as I have no lift I'm working on the floor. Every one of the bolts is rusted to the sleve inside the bushing.
Back to work with the grinder tomorrow it appears. Can't believe a 10 year old car could be so rusty underneath. There's hardly a blemish on the bodywork and I always keep the car clean.
PWSVT is offline
Old 07-09-2013, 05:13 AM   #26
tpw84
Fan#: 116549
What I Drive: Ford focus hatchback 2008 1.8tdci
FF Reputation: 1 tpw84 Good Standing Member
Originally Posted by thenorm View Post
well, I blew out a rear control arm bushing, so it was time to replace. Ford, in its infinite wisdom, does not sell replacement bushings, you have to buy the entire control arm as the bushings are integral.
So, instead of buying a 55$ control arm (the little dogbone linkage) and wondering when the next one will die, I spent 120$ and can upgrade all of them. This process was quite a bit easier than doing the front poly bushings and the rear trailing arm bushing.
I got the prothane kit 6-307-BL from C-F-M.
replacement bolts are from Ford *w500744*s439
PS ignore the Moog tie rod ends, I happend to pick them up at the same time.
this would also be a good time to intall a camber bolt or swap to a new camber arm. see this thread http://www.focusfanatics.com/forum/s...37#post2745037
Tools required:
-hydraulic press
-15mm socket and rachet
-PB blaster
-jack and jack stands
-breaker bar
-lots of extensions
-impact gun(optional)
-air hammer (optional)
-angle grinder (maybe)
tip: like a week before you begin, it would be wise to start penetrating the bolts with the PB blaster.
tip: have a spare vehicle ready to run to the parts store to get new bolts when you find have to cut your old ones out (they're metric. 12mm wide, ~60mm long, grade 10.8) i got mine from Ford for 3$
step 1.
Jack up the rear of the car. support the car with jack stands. i put them ahead of the wheel on the frame rail. alternatly u can put 2 close together on the rear subframe (but that is where i jacked from)
step 2.
remove wheels
step 3
use the PB blaster 1 more time. if you have an air hammer, use it to vibrate the end of the bolt to try and break the corrosion free.
step 4
using your breaker bar and 15mm socket, break loose the bolts. for some of the upper bolts you might need a long extension and you can use your breaker/rachet from behind the fuel tank.
step 5
using your rachet or impact try to remove the bolts. if you are lucky they will come right out. if not proceed to step 5a
step 5a
back out the bolt as much as you can before it totally binds up. get out your angle grinder and a fresh wheel (a sawzall could work, but its too slow and difficult, they are hardened bolts after all. believe me i tried). Cut through the bushing and bolt near the edge on both sides. dont damage the control arm, however you dont need to reuse the cylindrical metal bushing shell, so feel free to cut it. carefull, everything will be hot after this. the tough part might be getting the tip of the bolt that is still partly threaded in. you're on your own for that, but u could always cut the spot weld on the nut and work on it on your bench or use a vise etc.
step 6
dismantle your new bushings
step 7
once your bolts are out, take all your control arms to your hydraulic press and press out the old bushing including the outer metal shell. if you are good, you can press out the old with the new shell, killing 2 birds with 1 stone.
step 8
lube up all the parts. press in the poly parts first by hand, then press in the inner cylinder by hand.
step 9
ready for reinstallation. sometimes to get stuff to line up, i jack up the trailing arm so things weren't at such an extreme angle
step 10
tighten it up. torque specs for the rear suspension are below
Rear:
Upper shock nut (sedan, hatch) - 13 lb-ft
Upper shock nut (wagon) - 85 lb-ft
Lower shock bolt - 66 lb-ft
Upper control arm (inner) - 76-85 lb-ft
Upper control arm (outer, cam adjustment bolt) - 55 lb-ft
Spindle/hub retaining bolt - 49 lb-ft
Trailing arm pivot bracket bolts - 85 lb-ft
Lower control arm (inside) - 111 lb-ft
Sway bar end links - 11-15 lb-ft
Sway bar clamps - 35 lb-ft
step 11
put on the wheels, lower the jack and you are done. stand back and admire.
Thanks for that great and informative post thenorm. I know this is an old thread, but I am here with a question regarding a similar problem.
My rear suspension (esp. right side) on my focus 2 2008 1.8 Tdci has been making knocking and bumping noises when going over bumps for some time now - worse when going round corners, and I too get that 'rear end break-out' sensation over bumps in corners. I took off wheels to inspect suspension, and I immediately noticed that the control arm links (I think that's the right name) - the 'dog bone' shaped links that you show in the photos - appear to have worn bushings. I say 'appear' because I am not an expert - can anybody tell me what kind of visual signs indicate shot bushings on this part? Mine do not appear to be lined up perpendicular to the bolt that goes through the middle of them, suggesting to me that part of the rubber/poly has worn away.
I have photos if that would be more explanatory.
Thanks in advance for anyone who has any advice.
tpw84 is offline
Old 07-09-2013, 07:35 AM   #27
bile0026
bile0026's Avatar
Fan#: 97349
What I Drive: 2009 Amber Gold Metalic Focus
Points 401, Level 8
Points: 401, Level: 8 Points: 401, Level: 8 Points: 401, Level: 8
Level Up 2% Completed
FF Reputation: 7 bile0026 Good Standing Member
Dry cracking bushing are the beginning signs of wear. Once they get bad you can begin to see the inner sleeve of the bushing and things won't be lined up like what you described in your post. Chances are if those bushings are bad though the other sets of bushings on the camber arms and the spring arms are bad too... It's worth a look as you can get all the bushings in one kit.
Sent from cyberspace
2009 Ford Focus Sedan SE--Amber Gold Metallic--FS Cool-flo intake, 17" Black Kazera Rims with Potenza S-04PP, Custom 2.5" Exhaust.
bile0026 is offline
Old 07-09-2013, 10:19 AM   #28
tpw84
Fan#: 116549
thanks for quick reply bile026.
Well, to update, I just went to a garage who took the time to take my car out for a spin, and then put it up on a ramp. He confirmed (as I suspected) that my right rear brake pad was rattling in its seat - damn cheapo parts from a so-called 'discount' superchain. He tried fixing up a shim on it, but couldn't find a suitable piece of metal... anyway, that's for another time - it's not dangerous, just annoyingly noisy!
The deeper 'knocking' noise coming through the body over bumps we think is down to the end bushes on the anti-roll bar. On the right hand side, there is about 1-2mm of play between bar and bush. It makes a 'clicking/tapping' noise under load, which no doubt sounds like a knock when the sound comes through the body and into the cabin. No play on left side. No noticeable play on other bushings. Mechanic says 'funny' angle is normal on this car.
I attach a photo for anyone curious to compare. It's the right rear lateral control link 'dogbone' shape. Apologies for bad quality.
Thanks again for great informative posts.
tpw84 is offline
Old 07-09-2013, 10:46 AM   #29
thenorm
thenorm's Avatar
Fan#: 14947
Forum Activity 4%
the deflection seen in that bushing is normal at full droop. sounds like you found the problem in the sway bar.
that 'rear end break-out' sensation over bumps in corners is just a symptom of this suspension design, the toe-in is dynamic as the suspension compresses. it is exacerbated by excessive toe in or toe out. if you ever get an alignment, have them set rear toe to zero (or very close to it)
welcome to FF.
May 2014 ROTM
thenorm is offline
Old 07-09-2013, 10:47 AM   #30
bile0026
bile0026's Avatar
Fan#: 97349
Points 401, Level 8
I would agree with thenorm. Alignments are crucial with this vehicle and can cause problems if it is off even a little.
bile0026 is offline
