How-to: Atx to Mtx shift knob/boot mod, made easy - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > MK2 Interior Mods & Upgrades
MK2 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2008-2011 Focus.
Old 05-06-2010, 09:45 PM   #1
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
i modded that typical Saleen shift knob to my auto shifter, found a regular zx3 shift boot and made my atx into mtx....sort of,lol.
now im about to show how it can be done with ANY shift knob, not just some knobs some say can fit perfectly with some fittings(like that expensive $100 Mono automatic shift knob). i'm show u that you too can be like me.
i was fortunate enough to come across this idea on how to make practically most knobs fit for ur automatic focus. now with this mod will need:
*universal shift boot u can get a shift boot at any stores that sells them or online, whichever you prefer.
*3-4 inches of some sort of tube to stick in the shaft of the shifter with This is crucial cause in order for the shift knob to work, it needs to press the shifter button inside the shaft. so this can range any where from a pen to the spare antenna i had laying around in my garage. whatever it is, it must fit within the hole, move around and be about 3" to 4"
*scissors
*screwdriver
*Hex key set u can find this at any store really (walmart, home depot, any auto parts store, etc.)
*and the most important piece, THE SHIFT KNOB. now i know i said any shift knob can work but with 2 exceptions:
*it must fit over the shaft of the shifter
*and must have some room at the bottom to attach the boot onto like this knob:
you can see that it the bottom of it is dented in to allow the top part of the boot to sit in.
Okay STEP 1:
Remove the automatic shifter with a hex key. the bolt is going to be on the left side of the shifter. the size is #2.
Next, get your screwdriver and take out the three bolts holding down your center console
Get the shift boot. most universal shift boots comes with a draw string to tighten the top part of boot with or some elastic band that automatically adjusts, if yours happen to come with a zip tie then don't adjust it yet.
Step 2:
get the shift knob, the tube (or whatever it is you found) and stick the tube inside the shifter. Then stick the knob over it. get on the driver seat and put in ur keys and turn on ur car to the acc position, you do not need to start your car for this. then move the around the gear lever, get a feel for it and see how its moving. if it free flowing, as in if its not getting stuck after u stick into position or after you shift it into park then it will it work. then turn off the car and process to step 3
Step 3:
So this is one of the crucial parts for the whole mod. get your knob out, get your boot and tie the top end of it tightly on the end of the knob. I said tightly cause the tighter it is, the more "in-place" the knob will be in. the base of the boot, when held down by the placement of the console and the gear letter placement is what going to keep the knob stabilized and not to fall off.
Step 4:
Yet another crucial part of the mod, raise the center console up a little bit to fit in the shift boot over the base. make sure the boot covers it and sit ur knob over the shaft. make sure ur car is in park. also make sure there's a good amount of slack with the boot, especially when it's in park.
base: (do not remove it like i did)
Step 5:
get in the driver seat if u aren't, turn the key to acc. (accessories), push ur foot on the brake and move the knob. make sure the gear selector locks in the appropriate gear selections. when you move the selector it should not move out of park or when its in drive/ neutral position on its on after the knob has been pressed down.
look at my guide to get an idea.
park[locks in place/press knob to move]
reverse[press knob to move]
neutral[can move in between w/o pressing in the knob]
drive [same as above]
2nd[must press to get to gear]
1st[must press to get to gear]
after making sure that the knob/boot combo does fit in properly, then your all done. Clean up and enjoy ur new driving experience
*the combo that i used was a zx3 manual boot, with a saleen shift knob.
**in order for that particular combo to fit, i had to do a bit more modding to make the boot fit properly w/ some slack. if you like more info on that, shoot me a pm. if there's enough replies, ill add more directions on how to make that work.
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 05-07-2010, 01:00 AM   #2
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
25 views and no reply?
ChuckDee is offline
Old 05-07-2010, 01:32 AM   #3
alexdc
alexdc's Avatar
Fan#: 51995
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 2 alexdc Good Standing Member
good thread. its worth to be in the how to archive!!!
alexdc is offline
Old 05-07-2010, 01:36 AM   #4
Brutality
Brutality's Avatar
Fan#: 67712
What I Drive: DragginWagon
FF Reputation: 3 Brutality Good Standing Member
So you just push the knob down to move out of park?? Very cool idea!
Brutality is offline
Old 05-07-2010, 01:49 AM   #5
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
^^yep thats the idea! thanks
ChuckDee is offline
Old 05-07-2010, 01:55 AM   #6
03black&bluSVT
03black&bluSVT's Avatar
Fan#: 74084
What I Drive: 03 black svt
FF Reputation: 1 03black&bluSVT Good Standing Member
wow thats pretty sick. nice work.
driving is like sex... and speeding tickets are the std
03 black w/blue interior SVTF - 63 made that year with that color combo - K&N drop-in, Hawk HPS brakes, HIDs
86 Dodge Ram Charger - Lifted 6 inches on 36 inch tires
03black&bluSVT is offline
Old 05-07-2010, 02:00 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Massive FAIL!!!!!!! j/k someone had to say it lol. All this does is remind me that I need to put a shift boot on mine lol.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 05-07-2010, 12:26 PM   #8
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
^^haters gon hate
ChuckDee is offline
Old 05-07-2010, 02:12 PM   #9
firelink74
firelink74's Avatar
Fan#: 58474
What I Drive: 2001 silver se
FF Reputation: 1 firelink74 Good Standing Member
looks clean
SPI last of a dying breed
firelink74 is offline
Old 05-07-2010, 04:22 PM   #10
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
thanks man. so far alot of ppl are looking but not responding, hmm...
ChuckDee is offline
