Go Back   Focus Fanatics > Model Specific Discussions > Focus SVT > SVT Interior Mods & Upgrades
SVT Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2002-204 SVT Focus.
Old 05-06-2010, 06:51 PM   #1
GrndZero
GrndZero's Avatar
Fan#: 9630
What I Drive: 2002 Silver ZX5
FF Reputation: 3 GrndZero Good Standing Member
Advice on seat wiring needed.
Ok, this is what I have so far. I was going to take the car in for inspection but just recently (figures it always happens around that time) my wiring has come loose on my SVT seats in my non-SVT ZX5.
I am going to paste some info I have from a wiring diagram.
Code:
For the Driver seat:
svt pin 1: driver side-airbag signal: wire to driver seat harness pin 9
svt pin 2: driver side-airbag return: wire to driver seat harness pin 10
svt pin 3: not used
svt pin 4: not used
svt pin 5: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 6: heated seats switched power: wire to driver seat harness pin 5 (green and red wire)
svt pin 7: seatbelt buckle sensor signal: wire to driver seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to driver seat harness pin 4
svt pin 9: powered seat-height power: wire to constant power
svt pin 10: powered seat-height ground: wire to ground
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 5
svt pin 12: seat heaters ground: wire to passenger seat harness pin 8
svt pin 13: seat track position sensor signal: wire to driver seat harness pin 1
svt pin 14: seat track position sensor return: wire to driver seat harness pin 2
For the Passenger seat:
svt pin 1: passenger side-airbag signal: wire to passenger seat harness pin 9
svt pin 2: passenger side-airbag return: wire to passenger seat harness pin 10
svt pin 3: seatbelt pretensioner switched power: wire to passenger
seat harness pin 5
svt pin 4: seatbelt pretensioner signal return: wire to passenger seat
harness pin 6
svt pin 5: heated seats switched power: wire to passenger seat harness pin 1 (green and blue wire)
svt pin 6: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 7: seatbelt buckle sensor signal: wire to passenger seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to passenger seat harness pin 4
svt pin 9: not used
svt pin 10: not used
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 6 (red and orange wire to accy power)
svt pin 12: heated seats ground: wire to passenger seat harness pin 8(to black wires on switches)
svt pin 13: not used
svt pin 14: not used
And this is a diagram of the seat connectors.
Problem I have is I took my wires out of my connectors on the "Square Connector" image above so I no longer know which wires of what numbers. It seems to be stemming from my passenger seat. There are 2 yellow wires, one with a thick brown strip and one with a thin black stripe. The other 2 are green with and orange stripe and a black with a red. I need to know what numbers those 4 wires are off of the normal "Square Connector" so I can fix my problem.
I need to get this done pretty quickly. I am going to Tampa on sunday and would like to get it done before then.
If anything I hope this post will help anyone with seat wiring problems at the same time. I have noticed there really isnt a guide for this since these 2 items I have posted have never been found in the same post for some reason.
2002.5 Silver Euro ZX5
GrndZero is offline
Old 05-07-2010, 01:56 PM   #2
GrndZero
GrndZero's Avatar
Fan#: 9630
Anyone? All you have to do is go in your car and look at 4 wires near the front of the seat, its not that hard.
GrndZero is offline
Old 05-10-2010, 08:46 PM   #3
blackfocus2k4
blackfocus2k4's Avatar
Fan#: 49069
What I Drive: 2004 black ZX3/& 2010 Ster grey SES
FF Reputation: 4 blackfocus2k4 Good Standing Member
Buy-Sell-Trade Rating: (10)
I just got done wiring my svt recaro seats in my non svt and i cut the square box and spliced the wires to the seats harness. the seats still had the rectangle socket in it and all you have to do is match the colors 4 wires each side. no airbag or issues with the seatbelt light!
blackfocus2k4 is offline
