removal of crankshaft pulley bolt? - Page 4 - Focus Fanatics
Old 04-29-2010, 01:51 PM   #31
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by Missourileo View Post
Keep in mind, if the air compressor that you are using only puts out, let's say 60 psi, then you aren't getting the full potential of the impact. It doesn't matter if you have a 50,000 ft. pound impact, if there is not sufficient air.......it's useless. You can put a breaker bar,short extension combo on the bolt, lower the car on the breaker bar and it will break it loose. Do this slowly with a jack.
thanks! ...yes I realise that but nice of you to point it out just in case I didn't know
the_doc735 is offline
Old 04-29-2010, 01:53 PM   #32
the_doc735
Fan#: 74469
Originally Posted by disciplerocks View Post
Not sure if I missed something, but is this the pulley for accessories or timing belt? If its for the accessories then there is a how to from focushacks. basically brace your rachet against frame, remove spark plug wires and crank it over.
Posted via FF Mobile
timing!
Old 04-29-2010, 02:05 PM   #33
the_doc735
Fan#: 74469
Originally Posted by a_2000_se View Post
He mentioned it was a double pulley so I guess it could be both.Who would have thought to check the "How-to's". Sometimes it's more fun to reinvent the wheel - I know I like to do that, lol.
But what torque is now on that bolt is anyone's guess. And that 1.6 liter engine probably doesn't have a big starter - but then it, isn't my car.
I'm kind of leaning toward the 'jack method', clean and controlled. Just make sure you put the wrench handle on the 'correct' side of the bolt.
Actually I thought we just might be trying to increase the 'hits' on FF !
It has a double auxiliary pulley (a small one with a bigger one behind it). The small one had no belt and the larger one had the auxiliary belt (alternator etc) around it. Behind this is the lower timing belt cover; behind that is the crankshaft timing sprocket, = 3 in total. I've looked at how to's as well. The torque is the SAME as the pulley has not moved in either direction yet. It has a Smallish starter! Considering jack method at moment. No, not just trying to increase hits on FF ~ actually I wish that's all it was - lol ~ I assure you it is a real bolt with a real attitude problem - lol.
Old 04-29-2010, 02:11 PM   #34
the_doc735
Fan#: 74469
surely the crankshaft will simply rotate as there appears to be no way of keeping it still?
Old 04-29-2010, 03:24 PM   #35
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
It sounds like you may not have good, solid crankshaft countertorque. The best/safest method is to yank the starter and "jam" the flywheel. There is a "Ford" tool that engages about three or four teeth of the starter ring gear.
Grumpy is offline
Old 04-29-2010, 04:02 PM   #36
the_doc735
Fan#: 74469
many thanks! ~ any links [url] please?
Is this right? (1.6 cc) ti vct = zetec se = sigma ? (i.e. same thing)
If yes? ... is this the tool please ... http://www.tools4trade.com/d-4505976...rd-VS4834.aspx
cheers!
Old 04-29-2010, 04:17 PM   #37
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
Originally Posted by the_doc735 View Post
timing!
I see. well sorry I have not dug that deep so i don't have any advice then. Good luck.
04 ZX3 Mostly Stock [3/13 ROTM]["Best Non-SVT" FITF '12][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 04-29-2010, 05:06 PM   #38
the_doc735
Fan#: 74469
many thanks for your interest
Old 04-29-2010, 05:52 PM   #39
disciplerocks
Fan#: 59330
You know what I would do. Find iminhell or 03OrangeSVT and ask them.
Old 04-29-2010, 06:07 PM   #40
Grumpy
Fan#: 43791
The single lug/tooth design tool should hopefully do the job for you, but you would hate to snap off a gear tooth or break the tool, considering that your's seems to be really tight. The two or three lug/tooth design tool will just distribute the load over more teeth. I've seen both designs.......surely you can locate/buy/rent one at your location in Britain.
Grumpy is offline
