removal of crankshaft pulley bolt? - Page 26 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 06-03-2010, 08:20 PM   #251
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by Grumpy View Post
I guess I missed the "=90%" in all that.
NO you didn't miss it at all. I did it again as you suggested. This time I actually put 90 degrees on it NOT 60 as previously! See amended post #242.
cheers!
the_doc735 is offline
Old 06-03-2010, 11:30 PM   #252
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
Timing the camshafts to the crankshaft is strictly a mechanical job using the specified rig/timing pin and bar......nothing fancy or electronic required......but following the correct procedures is necessary. From what you've described with your final checking of the timing......#1 piston at TDC and the camshafts alignment/timing bar perfectly aligned with the remaining unbroken side of the camshaft slots......you should be bang on.
Grumpy is offline
Old 06-04-2010, 09:50 AM   #253
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Points 11,076, Level 69
Points: 11,076, Level: 69 Points: 11,076, Level: 69 Points: 11,076, Level: 69
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 99%
FF Reputation: 76 sailor Excellent Standing Member
Posted via FF Mobile^^^^ At least as good as factory assembly with the care you used, MORE precise than keyed sprocket engines, Checked & rechecked, No worries mate! (grin) Most common OOPS! I know of is tightening cam sprockets B4 tensioning timing belt, so when the belt is tightened the timing changes. Even that would be caught by the recheck after hand rotation, which also tests for any smaller variations accidentally introduced - you`re totally covered- well beyond any minimum standards of precision!
sailor is offline
Old 06-04-2010, 06:04 PM   #254
the_doc735
Fan#: 74469
Great!!! ~ how will I know if it's NOT [bang on] though?
All the remaining: tubes, pipes, cables, plugs have been reconnected, oil filled up and battery reconnected!!!
Now all I have to do is be brave enough to 'turn the key' ...and 'I bottled it' big time; just walked away - unsure what will happen?!?!
"HELP!" ~ apprehensive about all this?
Erm ~ the broken cam timing 'EARS'; I can only find one of them, been all over the engine bay and floor with a magnetic pick up tool and torch; but still can't find the other one? Surely it can't be inside the engine or cylinder head? I literally have no idea where it could have ricocheted to!!!!!!!! I did run the magnetic pick up tool over the cylinder head BEFORE I put the rocker cover back on though!!!!
Cheers!
Old 06-05-2010, 05:18 PM   #255
the_doc735
Fan#: 74469
...'bump'!
...what are the signs of incorrect timing please?
cheers (anyone)
Old 06-05-2010, 11:13 PM   #256
Grumpy
Fan#: 43791
Can run the gamut from not starting to running like crap/poor performance, won't idle or idles like crap. Has it lit off yet?
Grumpy is offline
Old 06-06-2010, 01:29 PM   #257
the_doc735
Fan#: 74469
Yes ~ it has 'lit-off', does start very well, runs smooth and idles fine, instant throttle response - in the driveway! Up to normal running temperature!
Now, I suppose I have to drive 'round the block' and see what happens next?
Hope it goes OK?
Thanks for your 'bad-timing' tips 'above'!!
Cheers!
Old 06-06-2010, 01:41 PM   #258
the_doc735
Fan#: 74469
I hope this thread will remain on here for a long time, as in my own opinion - it is an extensive archive and an important reference point for anyone with similar issues; it details lots of scenarios and pitfalls that anyone could unwittingly fall into themselves. This material should help quite a few fanatics in the future to resolve those issues without too much time and expense! Quite a few good helpful photos [as they say: a picture is worth a thousand words] to assist the dialogue in progress.
This repair would not have been possible without the help of Grumpy, Sailor and anyone else's advice and encouragement to date! You deserve the highest accolade for your humour, perseverance and persistence! For which I am personally and truly indebted. THANK YOU ONCE AGAIN! Keep up the good work!!
Cheers!
Old 06-06-2010, 01:41 PM   #259
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Hooray!!
Can't wait for more good news!!
sailor is offline
Old 06-06-2010, 02:22 PM   #260
Grumpy
Fan#: 43791
It's just too bad that from the start it seemed to be difficult to obtain accurate info on the Sigma engine (even from UK websites/forums etc.), and the confusion with obtaining the correct/applicable tooling, did not help. I'm glad that it "lit off", and it's running. You did very well, especially with where you were having to work.
Grumpy is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
