removal of crankshaft pulley bolt? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2010, 09:07 AM   #11
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by sailor View Post
Posted via FF MobileJust covering all bases w/reverse thread question... (would turn out) Why NOT use impact? Normal tool when you can get at it with one... Reversing directions with an impact helps remove stuck bolts - Same as with wrench but more so as impact gets a better "hit" when you catch it`s mechanism just right - back & forth gets you that extra impact ...
To loosen the crankshaft pulley bolt you have to turn it counter clockwise. I just recently did this when I changed my timing belt. I used an impact on mine and it took it right off of there without any issues.
...So, I won't "shear the head off the bolt" then? AND back to the original question: HOW MUCH TORQUE DO I NEED FOR THIS OPERATION? Is a 450Nm wrench sufficient for the job in hand?
cheers! ~ many thanx!
the_doc735 is offline
Old 04-28-2010, 11:41 AM   #12
the_doc735
Fan#: 74469
what was the torque on your 'impact' ???
Old 04-28-2010, 11:49 AM   #13
the_doc735
Fan#: 74469
I bought the 450 Nm 'impact' for 120 from machine mart shop and the guy said it would take that bolt right out - no problem at all !!
I went at it for 20 minutes backward/forward; backward/forward .... AND IT STILL REFUSED TO MOVE!!! ~ complete waste of money from the NO RETURNS MACHINE MART SHOP!!!
This bolt is becoming very expensive to remove. Well if I lay out another 300 I can get an 'impact' with 1000Nm !!! But that's far too expensive for me.
the impact is a clarke: http://www.clarkeinternational.com/pages/clarke-home. Some say crap?
Old 04-28-2010, 01:18 PM   #14
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
450 NM is 332 ft-lbs. I'm betting your crankshaft bolt torque is less than 100ft-lbs. Mine is 88 ft-lbs.
Strap wrench worked for me to hold the pulley while I removed/installed the bolt. Who knows what kind of torque is on it now (450 NM back and forth).
Methods heard used in the past but wouldn't endorse either:
- Extension/breaker bar on a wrench against the ground - then bump the starter. (ouch!).
- same as above but save the starter and bump/rock the car.
- same as above but, - parked on a hill?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 04-28-2010, 02:08 PM   #15
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 99%
Posted via FF MobileI`ve heard those suggestions too... can`t vouch for them from experience...The hiil versionsounds like it would solve ALL your problems..... If your Machine Mart is like our Harbor Freight - cheap import junk mostly.... My experience from others buying their electric impacts is that most wouldn`t budge a wheel lug much less a stuck bolt...ratings quite optomistic.... The breaker & bump sounds best if you have a MTX - Luck!
sailor is offline
Old 04-28-2010, 02:35 PM   #16
the_doc735
Fan#: 74469
mtx?
Old 04-28-2010, 02:58 PM   #17
the_doc735
Fan#: 74469
more thoughts:
http://www.locostbuilders.co.uk/view...tion=printable
http://www.tegger.com/hondafaq/cranktool/index.html
Old 04-28-2010, 03:11 PM   #18
Juantron
Juantron's Avatar
Fan#: 56983
What I Drive: '03 SVT-5
FF Reputation: 3 Juantron Good Standing Member
Buy-Sell-Trade Rating: (10)
MTX= Standard/Manual Transmission
Juantron is offline
Old 04-29-2010, 02:41 AM   #19
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Is the car still drivable? If so take it to a garage and ask them to loosen the bolt for you and then tighten it back up enough to get you home!! I havnt had much luck with electric impacts for high torque bolts. My Ingersol 1/2" impact is rated at over 750 ft lbs. That`ll get r done. One way or another..
iroc34 is offline
Old 04-29-2010, 03:09 AM   #20
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
As for the torque behind it, I have no idea. It's just an old impact gun that my dad has. I will ask him tomorrow what the torque setting is on his impact gun if he even remembers lol. I have also removed these bolts from other cars using two people, one person to hold the pulley and another person with a short 6 point socket and breaker bar with an extention on the breaker bar. Just had to use short tugs at it to loosen the bolt up but it came out fine in the others as well.
zetecDon is offline
