removal of crankshaft pulley bolt? - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2010, 12:12 PM   #151
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Holy 15+ post of the same thing lol. And I thought it was bad when I double posted sometimes. This one has definately got to take the cake. I see you ran into a bit of problems there doc. Hope everything comes out well for you man.
zetecDon is offline
Old 05-10-2010, 12:15 PM   #152
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 99%
Posted via FF MobileDoc - I give excess detail at times - leave it as Glad it`s out now. 2. Many engines have cam sprockets keyed or locked to the cam in one position - was just asking the "stupid" question to confirm yours are adjustable as ours are - sprockets turn freely when attachment bolt loosened. Grumpy - trying to visualize why movement of sprocket while tightening crank bolt would be a problem. wouldn`t that be tightened B4 locking the cam bolts to finalize timing?
sailor is offline
Old 05-10-2010, 12:22 PM   #153
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 12:31 PM   #154
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 12:49 PM   #155
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 01:06 PM   #156
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 01:27 PM   #157
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 01:47 PM   #158
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
sailor is offline
Old 05-10-2010, 01:47 PM   #159
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by Grumpy View Post
More photos would be nice, but no VCT is good news. Forget the request re the piston position.......when you rotated the camshafts, if there was no real resistance other than the normal resistance as would be expected as the valves were being opened.......AND......as the valves were closing, that their associated cam followers (buckets) "followed" (up) the cam lobes as the valves were closing. Get my drift? An "interference" engine is one that when the crank and the camshaft(s) get out of time (ie. when the timing belt breaks) a piston can come up and smack an open valve. Still not sure about your engine. The reason for the pulley removal was because the timing belt cannot be weaseled out from "behind" the crankshaft pulley after the belt is slid off the camshaft sprockets? Is the exhaust manifold on the front side of the engine or on the firewall side?
my engine: yamaha/sigma/alloy.
"The reason for the pulley removal was because the timing belt cannot be weaseled out from "behind" the crankshaft pulley after the belt is slid off the camshaft sprockets?" - yes!
Exhaust is firewall side.
"when you rotated the camshafts, if there was no real resistance other than the normal resistance as would be expected as the valves were being opened.......AND......as the valves were closing, that their associated cam followers (buckets) "followed" (up) the cam lobes as the valves were closing. Get my drift?" - yes!
cheers!
the_doc735 is offline
Old 05-10-2010, 02:00 PM   #160
the_doc735
Fan#: 74469
Originally Posted by iminhell View Post
So can the timing pin be removed?
(really hoping it's a simple yes and it's already removed)
Rotate the crank after removal just to make sure it's free and doesn't bind. Then go about install process.
In regard to your question about the cam gears,
So when you go to set the timing you do the tensioner first to take up any slack in the belt then tighten the cam bolts. If you do the cam bolts first then the tensioner there is a better chance of changing cam timing (just slightly, but slightly can have a negative effect). There is also the case of tightening the cam bolts with the cam bad in place that the tensioner will not take up all the slack in the belt, in which case the belt may be loose and timing could jump (very off chance but still a chance).
Just go through the steps to best eliminate any possibility of error.
"So can the timing pin be removed?"
Don't know yet - been raining ''here', so ~ "rain stops play"
