How To Make Your Own Wiring Harness For Fog Lights - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-20-2012, 11:00 AM   #61
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
No no no, find the wire that goes to pin 83B, and then tie the power wire into that one. You'll still want the relay. If you run through the factory wires your fogs will not be able to come on with the hi beams.
norcalfocus01 is offline
Old 01-20-2012, 11:34 AM   #62
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,747, Level 73
Points: 12,747, Level: 73 Points: 12,747, Level: 73 Points: 12,747, Level: 73
Level Up 75% Completed
Forum Activity 81%
Activity: 81% Activity: 81% Activity: 81%
FF Reputation: 10 SvviftSVT Great Standing Member
Buy-Sell-Trade Rating: (6)
well i had the fog light mod installed before they stopped working. so that took care of the fogs/high beams.
the wiring kit i have has an inline fuse and inline relay.
and 83b is not getting any power as it is now. checked it last night with a volt meter.
Track build has begun.
slow and steady.. but its going
SvviftSVT is online now
Old 01-20-2012, 11:35 AM   #63
jay-rod05
Fan#: 24351
FF Reputation: 5 jay-rod05 Good Standing Member
Originally Posted by SvviftSVT View Post
so could i just repin my headlight switch with the power to the fogs?
my oem wiring is shot.
so just pull out the existing wire and run this one into it. and get rid of the relay all together, since the fog lights will only turn on on the "pull" of the switch?
edit:::
also, which wire is the ground in the headlight switch?
Correct me someone if I'm wrong but pin #3 in the fog lamp switch can't be used to power the lights, you need a power source direct from the battery?
Basically what happens is when you pull out on the light switch to activate the fog lamps:
The switch sends voltage to the relay (86) and says "Hey Mr. Relay, the driver requests to have the fog lights turned on"
The relay then says "You got it Mr. Switch" and then the relay says to the power from the battery "Can you go send 12 volts to the fog lights?"
The power says "You got it Mr. Relay, just flip your internal relay switch and we'll go where ever you send us!"
The relay then proceeds to switch itself to allow 12 volts to go to the fog lights.
Then the fog lights say "Thanks Mr. Power, Mr. Relay, and Mr. Switch. Couldn't have done it without you!"
Then they live happily ever after
Below is a modified picture of the ford dealer add on kit, i just took out the extra relay that makes the fogs cut off when high beams are on. This is basically the same thing as what the OP is doing just in an easier to read format.
To note, this is NOT the DOT approved way:
jay-rod05 is offline
Old 01-20-2012, 11:38 AM   #64
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 81%
lol i love the "convo"
and i was meaning to toggle portion for my switch.
i will try to tackle this on sunday, if i get the time.
Old 01-20-2012, 12:08 PM   #65
jay-rod05
Fan#: 24351
This may also help too:
Old 01-20-2012, 12:18 PM   #66
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 81%
this should be no problem. esp with those pics. thanks a bunch.
and there is a green/black wire in pin 3, at least in mine.
Old 01-20-2012, 12:30 PM   #67
jay-rod05
Fan#: 24351
So if that wire is there, according to the pictures you could just cut the GRN/BLK wire about 3 or 4 inches down from the switch, use a red wire splice and splice in whatever wire you have to run to the relay. Then just tape off the cut end of the GRN/BLK wire and fold it away.
Doing it that way you wouldn't have to take apart anything.
Old 01-20-2012, 01:00 PM   #68
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Forum Activity 81%
awesome.
i've gotten pretty good/quick at removing the driver-side dash components to get to the switch.
thanks again.
Old 03-21-2012, 04:57 PM   #69
daveuk
Fan#: 96676
What I Drive: 2005 black focus
FF Reputation: 1 daveuk Good Standing Member
Wire
Duh I just re-read your question and the part about 83b. I didn't connect to a OEM fog light switch, but I would say you should be able to get a female slip connector to fit on that pin.
You can either...
go through the fire wall, which there are holes already there to slide the one wire through.
or go behind the fender and through the plastic plug in the door jamb.
Hi what do you call the fender ??
daveuk is offline
Old 11-28-2012, 01:16 AM   #70
jaytheillest
Fan#: 106716
What I Drive: 2000 silver SE
FF Reputation: 1 jaytheillest Good Standing Member
Originally Posted by Mr.Bergner View Post
Okay, 20 years later and today was the first free day in awhile to wire up these badboys.
A quick addition to the how-to:
If you want to wire up a factory fog light switch, you will want to tap your fog light power into pin 83b. This will be the wire coming from pin 86 on the fog light relay. I tested each lead with a volt meter while turning the fog switch on and off. 83b was the only one that gave power when the fog light switch was pulled.
and....finally! I used cheap ebay fog-light houses. The old ones I got from a junk yard were yellowing beyond repair. These are nice and crystal clear, I also covered them in 3M clear bra material.
Camera makes it look like 14k HID's, but they're just the cheapest bulbs I could find.
how did you get the grill like that?
jaytheillest is offline
