How To Make Your Own Wiring Harness For Fog Lights - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2011, 02:45 PM   #41
FuhFuh Focus
Stuff about Florida
FuhFuh Focus's Avatar
Fan#: 67230
What I Drive: 2002 Mazda Protegé ES
FF Reputation: 7 FuhFuh Focus Good Standing Member
Ive done it finally! They work :)
Thanks alot to fhh02a and everyone else who gave me advice.
FuhFuh Focus is offline
Old 07-22-2011, 11:52 AM   #42
Semir
Fan#: 85484
What I Drive: 01 FlatBlack ZX3 shell, 07 interior
FF Reputation: 1 Semir Good Standing Member
I have an 07 zx3, and i bought a oem switch from a local junkyard for $7. IT was from an 02, and i thought it would just pop in..i was wrong. I noticed that the housing was all the same. so i took off the front cover from my stock one, and then the front cover from the one i bought. I used the housing from the older focus, and just had to swap some piece, and it all fits and works. I just have to wire up the fogs/relay...no biggie
Semir is offline
Old 09-01-2011, 02:21 PM   #43
anthonyruff
Fan#: 89454
What I Drive: 2004 1.6 lx
FF Reputation: 1 anthonyruff Good Standing Member
fog light wiring
hello from england, i have a 2004 1.6 lx this is the model that does not come with front fogs as standard. ive got the fogs and switch from a breakers yard, but cannot find the wiring loom, having searched the internet ive discovered focus fanatics, and even better this post on how to wire them up if the weathers good tomorrow i am going to atempt this project, im going to use the factory switch and tap into 83b wish me luck, tony
anthonyruff is offline
Old 09-01-2011, 03:09 PM   #44
anthonyruff
Fan#: 89454
im from england and have a 1.6 focus, that has no front fog lights as standard, ive got a set and a switch from the breakers yard, ive looked under the car for the wiring loom but cannot locate it, after searching the internet ive found focus fanatics, and com across this post that answers all my problems, if the english weather is good tomorrow i am going to tackle this project, im going to use the standard ford switch, and tap into no 83b and hope i get a result, the original switch that anly pulls out once for the rear fog light has the same amount of wires coming out the back, thats why i think the wiring loom is there already, wish me luck, best regards tony
Old 09-01-2011, 03:23 PM   #45
anthonyruff
Fan#: 89454
hi ive just joined the forum i have a 1.6 lx and am trying to fit front fogs, ive got a new ford switch and there are the same amount of wires coming out of borh switches, my question is did you have to go through the firewall or did you pick it up inside the engine bay, ive looked allover the car for the extra loom dut had no luck, all the best tony
Old 09-01-2011, 03:31 PM   #46
saznat
Fan#: 86647
What I Drive: 1999 Black MK1 Focus CL
Points 54, Level 1
Points: 54, Level: 1 Points: 54, Level: 1 Points: 54, Level: 1
Level Up 8% Completed
FF Reputation: 1 saznat Good Standing Member
Hi Tony. I have a 1999 Focus CL and had the same problem as yourself. The extra wire for front fogs was in the plug that connected to the light switch. After hunting for ages, I concluded that the loom for the fogs wasn't there and had to make one. I have no idea where that wire from the light switch goes. I couldn't follow it without taking the dash apart and I wasn't going to do that so I ran a wire through the firewall and used a skotchblock to join it to the foglight wire on the switch and it all works fine. I'm afraid you'll probably have to do the same. Hope this helps!
saznat is offline
Old 09-01-2011, 03:43 PM   #47
anthonyruff
Fan#: 89454
fog lights
hi thanks for the reply did you tap into 83b and did you use a relay and inline fuse, sorry to sound silly, all the best tony
Old 09-01-2011, 03:59 PM   #48
saznat
Fan#: 86647
Points 54, Level 1
Yes, I did just tap into 83b using a skotchblock. The Haynes wiring diagram shows this wire just running directly to the fog lights so I just ran the wire directly to the fogs and all is fine. Again, looking at the diagrams, there is no additional fuse for fogs, although I did put a 15amp fuse inline. Not because it is needed but to protect the light switch from damage should my home made harness somehow short out. That way my fuse cops it before the switch does. I picked up my grounds from within the engine bay. The nearside one is grounded to the -ve terminal of the battery and the offside one is grounded with the nearside lights to an earth point near the offside front of the engine bay.
Here is how I got the wire out to the engine bay. Maybe not the best way but I didn't want to drill holes and I couldn't find anyplace or grommet I could just shove it through.
http://www.youtube.com/watch?v=6RXDHrjusHw
saznat is offline
Old 09-01-2011, 04:08 PM   #49
anthonyruff
Fan#: 89454
frot fogs
Hi thanks for getting back so soon, do I still have to run from the battery and use a relay or do I just come from 83b then a fuse straight to the fogs its confusing me a bit now.best regards tony
Old 09-01-2011, 04:48 PM   #50
saznat
Fan#: 86647
Points 54, Level 1
No relay is required. Just run from 83b to the fogs. There's no need for the fuse really. I just put that in as an extra safety feature.
saznat is offline
