Getrag Fluid -Warning to synchromax users - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 04-18-2010, 01:23 PM   #1
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
FF Reputation: 3 paulg127 Good Standing Member
Many different theories of the correct Getrag fluid for our SVT. The comment that the trans is the same as the mini cooper is partially correct. The mini uses 2 different manuals and an auto. The cooper-S uses our SVT (285) trans. I believe there is much mis-information about using similar fluids to the mini cooper as the base cooper uses a 252 Getrag.
WD40 has linked a page from his SVT manual that indicates ATF fluid. My 2003 manual makes no mention of that, and I suspect it is not correct.
When comparing the fluid specs, it is apparent that the synchromax type fluids are not the correct spec for this trans. I listed in order below my choices based on similarities with the Ford spec fluid. For the boosted SVT's the second choice of Amsoil Severe Gear is probably pretty safe. For the NA vehicles, looking at saving friction to get the most FE and power leads to the Amsoil Synth Man trans lube. I keep picking the Amsoil based on their website info and the lack of competitors similar comparison data. You can decide for youself, but look at the specs first. The Kinematic viscosity at 40C and 100C show the thickness of the fluids at those temps, lower is better for friction reduction, but unsure of protection. The 4-ball wear is a standard test, with lower is better numbers, some motor oils have .32 ratings. The falex test involved load carrying capacity where higher is better and 2500 appears to be the top area.
The Ford perscribed WSD-M2C200-C (75W90 Gear oil) fluid has specs as follows (from the Ford pubilcation):
Kinematic Viscosity Visc
Fluid cSt 100 cSt 40 Idx 4-ball wear Falex
WSD-MC2 15.4 76 211 ? ?
Amsoil
Synt Man Tr 14.7 84.5 151 .45 ?
Amsoil
Severe gear 16.7 109.1 165 2500
Amsoil
Long Life Gr 16.6 129.7 137 2000
Royal Purp
Max Gear 19.1 132
Amsoil
Synchromesh 9.6 47.1 194 .40
Royal Purp
Synchromax 7.7 35.3 196
As you can see the synchroxxx fluids are substantially thinner than the Ford spec fluid. You may want to seriously reconsider using the synchroxxx fluids in this trans.
Does anyone have specs on other fluids that may be lower in viscosity and within spec for this trans? Always looking to reduce friction and increase HP.
paulg127 is offline
Old 04-18-2010, 01:29 PM   #2
paulg127
Fan#: 55998
How do you get spaces right in this space?
----------------Kinematic Viscosity---------Visc
Fluid -----------cSt 100-------cSt 40-------Idx-----------4-ball wear-------Falex
WSD-MC2--------15.4-----------76 ---------211--------------?-------------?
Amsoil
Synt Man Tr------14.7-----------84.5---------151-----------.45------------ ?
Amsoil
Severe gear------16.7-----------109.1--------165------------?----------- 2500
Amsoil
Long Life Gr------16.6------------129.7--------137------------?----------- 2000
Royal Purp
Max Gear---------19.1------------132-----------?-------------?-------------?
Amsoil
Synchromesh -----9.6 -------------47.1 --------194 ----------.40-----------?
Royal Purp
Synchromax -------7.7 ------------35.3 --------196------------?------------?
The Royal purple site also call for 10w40 for the SVT fluid, but I could not find the specs on that.
paulg127 is offline
Old 04-18-2010, 02:46 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Those name brands of oils are a waste of money in my opinion , I have found no longer life or less ware from those brands
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-18-2010, 03:26 PM   #4
TheMac
TheMac's Avatar
Fan#: 41499
What I Drive: 2004 CD Silver 5 Door SVT
FF Reputation: 1 TheMac Good Standing Member
Buy-Sell-Trade Rating: (7)
Tom, what do you use?
2004 Focus SVT 5-Door Build Number 1012, Born on 3/30/04
TheMac is offline
Old 04-18-2010, 04:31 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
That depends on many thing , where you live , NA or FI , DD or track
My SVT that I use for 300+HP DD/Track I use Syn engine oil
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-18-2010, 04:50 PM   #6
paulg127
Fan#: 55998
The Amsoil is half the price of the Ford WSD-M2C200-C, so I was figuring on save a few bucks and getting .001 HP ;).
At this point with the service grading, pretty much any oil (as long as it is the correct grade for your car) should be pretty reliable.
Tom,
In some of the tuner mags, they are constantly quoting ~5hp from wizz-bang synthetic over mineral based oil. Have you ever looked at any HP gain on the dyno using one oil vs another?
paulg127 is offline
Old 04-19-2010, 11:31 AM   #7
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
What I Drive: 2003 Red SVT
FF Reputation: 1 Dads03SVT Good Standing Member
I run Royal Purple 10W-40 in mine...& change it around 30,000 miles..I now have 103,000 & no problems.
Dads03SVT is offline
Old 04-19-2010, 02:07 PM   #8
djo90
because race car
djo90's Avatar
Fan#: 60957
What I Drive: 2007 ms3
FF Reputation: 6 djo90 Good Standing Member
I've been using RP for a while. I'm probably just gonna use something a bit cheaper next, I don't think it makes enough of a difference for the extra cash
2007 Mazdaspeed 3 black mica metallic
1988 Jeep Comanche (MJ) blue/gray. 4.0 5 spd
Rice, It's what's for dinner.
djo90 is offline
Old 04-19-2010, 06:26 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Tom,
I 100% like the synthetic oils and feel there can be gains from using them , Just so there is no confusion about this I do not mean oils like rp , amsoil etc , I mean std on the shelf syn oils
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-19-2010, 06:29 PM   #10
Broncoboy80
#MattinglyBuilt
Broncoboy80's Avatar
Fan#: 59885
What I Drive: Stanced 02 SVT
FF Reputation: 13 Broncoboy80 Great Standing Member
Buy-Sell-Trade Rating: (8)
Tom, whats your opinion on what fluid i should use on a stock tranny with a cammed motor? For the svt....
CREATOR OF THE CLEANEST FOCI's
Instagram - #MattinglyBuilt
Originally Posted by HaveBlue83 View Post
^yo, that bitch is LOW and clean!
Broncoboy80 is offline
Tags
getrag, svt, svt trans fluid
