funky thumping from front end - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2003, 03:59 PM   #1
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
OK-
so, i've had this problem that's been getting worse and worse. it started before i put the suspension in, but it seems to be getting worse now. the front end of the car has some weird vibrations going on. they don't make any sounds, but i can feel them mainly through my feet, especially my left foot when it's on the dead pedal. the vibration turns into a steady light thumping when in the corners. i thought it might be a torn CV boot, but everything looks OK. i did have the alignment done on the car after the install, so that probably isn't it (althugh the car does pull ever so slightly to the left, but you have to be going pretty fast to notice it). i even had the tires rotated and balnced yesterday to eliminate that possibility, but it's still there. here are some other things that might help with the diagnosis:
-the car has almost 20K and the stock firestones have almost had it. they're not bald, but i probably won't get more than another 5K out of them at this rate.
- when i put the suspension on, i lifted both sides of the front end at the same time. i noticed that the sway bar link on one side went in pretty darn easy, and the other took some "convincing" to get it in. basically i had to have one friend hold down the sway bar while i tried to stick the end link through the hole. he didn't push on it that hard, so i doubt he bent it, but it doesn't seem right that one side would be so easy and the other wouldn't.
i know some of the focii were prone to have wheel bearing issues, but i thought that mainly dealt with the ones in the back. anybody have any ideas?
Mike
just visiting now....
whiteboyslo is offline
Old 10-27-2003, 12:57 PM   #2
gibsontaylor
gibsontaylor's Avatar
Fan#: 511
What I Drive: 2002 ZX3 pwr premium midnight grey
FF Reputation: 1 gibsontaylor Good Standing Member
The only thing I had a problem with that seems close was my fender wells were rubbing up on my tires making some grinding noise. Probably not the same issue here.
Do you have an aftermarket front installed on your car? If so is it properly mounted? You described where you feel the vibrations but do they happen on turns only? What about high/low speeds only? What needed replacing on your 20K checkup that you didn't tend to? What needs replacing on your 25K?
Some of these questions might help you answer what's going on. If vibrations are happening on turns only, check fender wells for any debris or friction marks on tires. If vibrations are happening on high speeds, check tire balancing (again) & bearings. Worst case, take it to a mechanic or a dealership for a mechanic's educated guess (did I just use mechanic & educated in the same sentence?).
good luck on your troubleshooting
Bigger, Faster, & Fuzzy Dice
gibsontaylor is offline
Old 10-28-2003, 05:48 PM   #3
bfocused
bfocused's Avatar
Fan#: 63
What I Drive: I now drive a 2009 Focus SES
FF Reputation: 2 bfocused Good Standing Member
Whiteboy
I was at the dealer today, chatting with a tech about my SVTF, and this issue came up. He showed me a new TSB which addresses a "creaking, rubbing or groaning" noise from the front end. It covered all ZX3's from 00 to 03. The repair is to replace the strut bearing. This is the bushing type thingy that the strut passes through. You know the three bolts on top of the fender apron. Anywhoo I will get the TSB# and post it here.
bfocused
"The present day composer refuses to die"
Edgar Varese 1883-1967
bfocused is offline
Old 10-28-2003, 05:54 PM   #4
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
It is probably, and hopefully, just the tires. Mine is doing it at 18,000 miles and it is def. the tires on mine. Look for scalloping in the tire tread..One block being slightly lower than the one next to it... or look for this in the front...it can cause alot of noise...hopefully its the tires.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 10-29-2003, 02:35 AM   #5
whiteboyslo
Fan#: 180
funny you should mention that viney, bc i was just going to jump on and say that i think i found the culprit. the tires are gone. i mean GONE gone. the outside still has a little tread, but the inside on at least one is completely bald. i blame this on my over-inflating the tires for a couple thousand. the suspension hasen't been on long enough to chew up the tires that bad, and i had the alignment done afterwards, so i don't think that's causing the problem either. looks like i'm in the market for new tires sooner then i thought. oh, cryptkeeper... (aka whoa)...
Mike
Old 10-30-2003, 08:25 PM   #6
bfocused
bfocused's Avatar
Fan#: 63
As promised, I have the TSB to post. This TSB is #03-20-2. It addresses (and I am quoting here) Suspension-- "Creaking,crunching,grinding,or rattle noise from front suspension at slow speeds over bumps and/or while turningIssue- Some 2000-2003 Focus vehicles may exhibit a front end creaking, crunching,grinding and/or rattling noise from the front suspension at slow speeds and or/while turning.
Service procedure is to inspect front strut fasteners, and confirm they are tightened to correct torque. Well it goes on and on, I won't bore you to death with it, go to your local Ford Service Dept and ask for them to check this out if you have this noise.
My car is doing it big time. And I have an appointment to have this done.
This TSB supersedes TSB # 03-15-3. And remember this is a Technical Service Bulletin, not a recall. Normal warranty coverages apply--- 3 yrs 36k, unless you have an Extended Warranty.
Hope this helps
bfocused
bfocused is offline
Old 10-30-2003, 08:42 PM   #7
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
bfocus: from what he says...that wouldn't be it, it could have been a flat spot (depending on the tire rotation machine, it wouldn't notice that) or a bent wheel...as for the CV boot, unless the cv's r clicking and don't have slack up/down front/back movement...but i'm glad ya found your problem. nice man
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 10-30-2003, 10:25 PM   #8
whiteboyslo
Fan#: 180
well, i'm guessing that's the problem. once i get my new wheels next week (courtesy of whoa), we'll see. i did have one tire replaced, though, bc it did have a flat spot and the thing was just too bald for me to feel safe. it seemed to get rid of a little of the problem. i got lucky bc the tire store down the street had just finished replacing some tires on a focus earlier that day and had a firestone with some decnt tread left. keep you guys posted.
Mike
Old 12-07-2003, 06:40 PM   #9
focalPoint
Fan#: 409
FF Reputation: 1 focalPoint Good Standing Member
Talking what a racket
Hi,
Just thought I'd let you all know about the funky front end noise in my 2001 Focus ZTS.
So, winter arrived on the Canadian prairie and almost right away the roads were bumpy with ice. And almost right away the car would rattle horribly driving ove the ruts. I checked the forum - what else can I do - read a few things and took my car to the dealer and suggested the few things I'd learned from the forum. Anyway they said thanks but they'd start from scratch. Good on them for knowing their business.
Anyway, my funky rattle was because the sway bar links had snapped. They were replaced (about $200.00 CAD) and the car is great again.
Again, kudos to Maclin Ford in Calgary.
Later,
focalPoint is offline
Old 10-19-2005, 11:04 PM   #10
Hillyard
Supercharged
Hillyard's Avatar
Fan#: 10982
What I Drive: 2002 ZX3 SVT, 2004 Ford Ranger 4x4
Points 13,364, Level 75
Points: 13,364, Level: 75 Points: 13,364, Level: 75 Points: 13,364, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 2 Hillyard Good Standing Member
Buy-Sell-Trade Rating: (27)
Hope this helps
bfocused
Oh man! I am out of warranty and I have the exact sypmtoms of the TSB...Can you explain what it replaces?
#3788 InfraRed SVT
Hill <><
Hillyard is offline
Similar Threads
SVT Front End Bra/Hood Mask Sonic SVT Focus SVT 13 07-21-2006 04:39 PM
STOLEN! front end. I needfront front body kit(hood bumper and fiberglass fenders! dwnshfter Archive 17 03-14-2006 04:18 PM
zx3 with 350Z front end drtyzx3 Photos & Camera Fanatics 15 07-27-2005 09:35 AM
popping in the front end melabean General Technical Chat 3 07-01-2004 01:16 PM
what front end???? ZtsFocus MK1 Focus 9 10-11-2003 02:22 PM
