Need help datalogging!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-05-2010, 09:52 PM   #1
borchey12
borchey12's Avatar
Fan#: 66057
What I Drive: 2009 Sangria Red SES coupe
Points 130, Level 2
Points: 130, Level: 2 Points: 130, Level: 2 Points: 130, Level: 2
Level Up 60% Completed
FF Reputation: 1 borchey12 Good Standing Member
I just got off of a Teamviewer session with Tom (where he controls my computer) and we're having a couple of problems. First, When we started to datalog My AEM Wideband is datalogging at a constant 10 no matter what the gauge face is reading. We made sure we selected AEM from the list of equations. Then Tom even selected the LM1 equation just to check and there was no change. I followed a write-up on here for wiring it in. I will double-check the wiring tomorrow (it's getting dark out and I don't have a garage)
Second,we had a really weird error show up. It was new to Tom. It was "Transfer failed 1073741807 ( Unload jungo driver )." I have no clue what that means. Any help would be greatly appreciated.
For the technical info: I'm running Livelink 6.1 on Windows Vista trying to datalog a 2009 Focus with an AEM wideband with an Xcal3.
Thanks in advance for any help
borchey12 is offline
Old 04-05-2010, 11:20 PM   #2
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
You sure you wired your firewire correctly? You might be using the wrong channel
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 04-06-2010, 12:40 AM   #3
CarDemon
CarDemon's Avatar
Fan#: 63700
What I Drive: 2003 Silver ZTS
FF Reputation: 3 CarDemon Good Standing Member
Buy-Sell-Trade Rating: (18)
Here are a couple of ideas:
Since you’re using Windows Vista, SCT reports that you have to open each of the “Application” files in LiveLink, right-click and open “Properties,” and under the “Compatibility” tab check “Run in Windows XP SP2 Mode” and “Disable Desktop Composition.” You also need to turn your User Account Control OFF in the Windows Security Center.
Make sure under the “Module” tab that you’ve checked “Rapid Packet Enabled.” This allows monitoring much closer to real-time and makes real-time recognition of an analog signal possible (such as a wideband A/F gauge).
I believe the "jungo" message is a driver issue. If I recall correction, that's the name of SCT's driver file for the XCals. I wonder if a re-install of the software and hardware might fix this. It seems to me that I had a similar issue at one point and that remedied it.
If these don't work, send a pm to Blivit on this site. He's a tech guy with SCT.
Who by worrying can add a single hour to his life?
CarDemon is offline
Old 04-06-2010, 07:19 AM   #4
borchey12
borchey12's Avatar
Fan#: 66057
Points 130, Level 2
PSU...I've looked at a couple of threads on here and followed them. I ran the orange wire from my firewire to the white (output wire) on my wideband. I've also tried to log both analog 1 and 2 and neither of them give me any signal...I've seen in threads that you've been able to datalog yours...what all did you hook up?
CarDemon...I looked into what you said about the compatibility mode and have seen it before, but it is not in the properties menu for Livelink. Rapid Packet is enabled. ECM #1 is selected...should it be ECM #1 & #2 (x3 & LW). I will re-install everything.
Thanks for the help so far guys.
Old 04-06-2010, 07:10 PM   #5
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Ok you have an 09, sorry man didn't see that before. Here's what you have to do:
On device datalogging does not work with the 08+ focus...USING THE FILES THAT ARE ON THE DEVICE. You will have to create your own file, load it to the device then go through the exact process you have done so far but using the file you created. The 08+ focus uses a different communication protocol and the files that are on the device are for every other vehicle.
Open livelink and have only the X3 connect through usb and not to a vehicle. Press the configure datalog button, let it fail because it is not connected to a vehicle and type in the first 5 digits of your vehicle strategy in the box that pops up(probably something like FDGJ0, you can use the X3 to read strategy beforehand.) Select your list but DO NOT CHOOSE ANYTHING UNDER ANALOG, you will do that on the device. Once done, press ok then under the file menu there is a option to add file to x3. Choose that, add the file then take the device out to your vehicle and do what you have done before and it should work.
PSUrivie is offline
Old 04-06-2010, 11:58 PM   #6
borchey12
borchey12's Avatar
Fan#: 66057
Points 130, Level 2
Thanks...That helps a lot...I fidgeted with the wiring and got a signal to livelink (using the green wire), but it constantly goes back and forth from my a/f to 10.00...I will try that in the morning before work and hopefully it'll help...
Old 04-07-2010, 12:32 AM   #7
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Just about 100% that's whats up. If you go to monitor the analog channel on your DEVICE, it will read 10 and thats why it's reading 10 in livelink. You need to create your own file and load it to the xcal then it will work
PSUrivie is offline
Old 04-07-2010, 01:29 AM   #8
borchey12
borchey12's Avatar
Fan#: 66057
Points 130, Level 2
PSU...I think you just effectively ended my problem. I followed your advice and logged to the device then imported the datalog to Livelink and it looks like everything is good. I appreciate all the help. You're a lifesaver.
p.s. I'd rep you, but I don't have enough posts as of now :(
Old 04-07-2010, 03:15 PM   #9
PSUrivie
PSUrivie's Avatar
Fan#: 67329
Lol, don't worry about it man. Glad you got it workin.....
PSUrivie is offline
Old 08-17-2011, 11:29 PM   #10
09FFC
09FFC's Avatar
Fan#: 85454
What I Drive: 2009 Coupe SES Silver
FF Reputation: 1 09FFC Good Standing Member
Hate to bring back an old thread, but I'm having similar issues.
I setup everything just like the directions said. I even made my own .DLF to work with my certain strategy.
When I try to start datalogging, the values show INVALID or sometimes 0. After about 4 seconds of "log" time, it stops and shows "Communication Failed".
Using LiveLink to do such returns a similar issue, it just shows "Device Initialization Failed". LiveLink recognizes my X3 Plus / Improved, so I just don't get it.
2009 Focus Coupe SES | Brilliant Silver Metallic | 35%/15% Tint | Tom's Tune | Kenwood Sound
09FFC is offline
