Free Tunes !!!! Why Wait - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Focus-Power Tuning
Focus-Power Tuning Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Focus-Power
Old 03-31-2010, 09:09 AM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
Originally Posted by IslandFocus View Post
Since there is such a big difference in octane, it may be a good idea to have a street tune and race tune. However, based on the tune, I'm pretty sure the computer can just add timing when it detects the higher octane fuel. For example, on my turbo setup, the higher the octane I use, the more timing the computer adds and the more power I make. Now the only question I have is would it be better to do a new tune for 110 octane where you set the timing higher from the get go so the computer only needs to add maybe 1-3 degrees of timing or just keep the 93 octane tune and let the computer add all that it wants to, maybe 4-8 degrees of timing?
It would be best to do 2 tunes
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-31-2010, 09:14 AM   #12
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,049, Level 33
Points: 3,049, Level: 33 Points: 3,049, Level: 33 Points: 3,049, Level: 33
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 11 hEaT Great Standing Member
The computer won't just keep adding timing for a higher octane. It doesn't know there is higher octane, just that there is no knock. The ECU will never add more timing than with is in the Max Allowed table. You might see a degree or two added going from 91 to 93 on a 91 octane tune, but you definitely won't see the full benefit of going from 93 to 110 without a tune made specifically for the 110.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 03-31-2010, 09:38 AM   #13
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
I dont know that I would say that , If the knock adder was already raised and the AF stayed the same for both the 91 and the 110 then you really wouldnt need a tune just because of the timing and 110
The biggest this is it would depend a lot on what year Focus were talking about , most of the Knock Sensors on the Focus are EXTREMELY good at what they do , the correct changes done in the software and you could easly run 1 tune for both 91 and 110
Me I would run a slightly leaner AF with 110 that I would with 91 , thats why I said above to do 2 tunes
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-31-2010, 05:19 PM   #14
slowduratec
slowduratec's Avatar
Fan#: 59069
What I Drive: 2006 Toreador Red ZX3
FF Reputation: 10 slowduratec Great Standing Member
Wow! Is this only offered for a short time or is this how you always roll?!
IT'S SLOW (KANYE WEST IS GAY!!!)
Team Duratec #236
slowduratec is offline
Old 03-31-2010, 06:10 PM   #15
o_so_slo
Drunkinmonkey
o_so_slo's Avatar
Fan#: 55470
What I Drive: 00' Turbo zx3, 12' Optima LX+
Points 19,670, Level 88
Points: 19,670, Level: 88 Points: 19,670, Level: 88 Points: 19,670, Level: 88
Level Up 64% Completed
FF Reputation: 67 o_so_slo Excellent Standing Member
quick question before i go on my NEW motor (PRE BOOST) consits of stock block bored and honed to accept my JE pistons at 9:0:1 compression, eagle h-beam rods, oem bearings, arp main/head studs the head consits of stock head ported and polishes with 3 angle valve job, stock valves, ford racing high lift valve springs, stock cams, fidanza adjustable cam gears, 65mm TB...i have 60lbs deka injectors but i was told not to install them with an N/A build...will also have stok flywheel and a bully stage 3 clutch....will also be running stock oem zetec header with a 2.25 exhaust (not sure on make) and an AEM cold air intake...also have 1 step colder motorcraft spark plugs with taylor thundervolt wires...what else do i have ....180* t-stat....i believe thats it so far?? will i need a tune for this????
if i tune it what will i pay and then when i install the turbo kit will i have to pay extra?????
oh yea forgot ill be running the jay racing PCV plate with catch can if that matters
cams will also be set to zero
if i dont HAVE to id rather not as it will be boosted with in a monthish time..i have everything for the boost pretty much i just wanna break the motor in a bit so everything isnt new
Zetec Crew # 260
TURBO
October 2013 & 2014 ROTM
Instagram @o_so_slo
Formerly drunkinmonkey
o_so_slo is offline
Old 03-31-2010, 06:21 PM   #16
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
My customers have been recieving this for over a year now
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-31-2010, 06:26 PM   #17
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
The best deal for you would be the 550.00 FI Tune 379.00 xcal3 shipped , I would go ahead and do the 60lb Inj now . This gets you a NA tune for now and FI tune when you go boosted
There is no shop that can beat these prices or offer you a better , safer Tune
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-31-2010, 06:45 PM   #18
o_so_slo
Drunkinmonkey
o_so_slo's Avatar
Fan#: 55470
^^^if i dont go with the tune till i got boosted will it kill the engine????should i bother installign the wideband now or wait to till i can get the turbo on so i dont waste the bung??? like i said it'll be a very short time NA
Zetec Crew # 260
TURBO
Instagram @o_so_slo
o_so_slo is offline
Old 03-31-2010, 06:58 PM   #19
jmiller_1974
Flipping Rockstar
Fan#: 57165
What I Drive: Black 02 SVT #2998
FF Reputation: 28 jmiller_1974 Great Standing Member
Buy-Sell-Trade Rating: (14)
Couple of quick questions.
1. What is the difference between the Predator and the XCAL3(other than $24, lol)? More just wondering which would be better for Me(D23) and why.
2. Would it help , hinder or make no difference to hit a local dyno(post tune) for extra info in case You need to tweak things a little? I have access to a dyno locally and can get deeply discounted rates, but if I don't NEED it, I'd rather put the money towards other GO stuff...
Thanks in advance.
dreamspeed
jmiller_1974 is offline
Old 03-31-2010, 07:06 PM   #20
FiFoci
FiFoci's Avatar
Fan#: 59433
What I Drive: 11' Mustang GT 5.0,01' Twilight Zx3
Points 7,198, Level 56
Points: 7,198, Level: 56 Points: 7,198, Level: 56 Points: 7,198, Level: 56
Level Up 24% Completed
FF Reputation: 6 FiFoci Good Standing Member
Buy-Sell-Trade Rating: (20)
i would let tom tune the motor both n/a and when u go FI just for safety.
I have been a Tom Tune customer for almost a year now and i love his service. I turbo'd my car then went back to NA then i returbo'd my car and he was there to retune it with more boost this time... Speaking of which where are u Tom? I tired to IM you. I want to turn the boost up to roughly 14psi by friday night. Ill be hitting the dyno saturday.
Fully Built, Topspeed manifold, CompTurbo: 364hp, 317tq...
^old and Busted^
2011 Mustang GT 5.0 Kona Blue: Bolt On's 440hp, 385tq
^SOLD^
'96 F-250 SCEB PowerStroke
FiFoci is offline
