"How To" SVT & Zetec Power Steering Pump & Line Replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2010, 10:01 PM   #1
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 4,146, Level 40
Points: 4,146, Level: 40 Points: 4,146, Level: 40 Points: 4,146, Level: 40
Level Up 98% Completed
FF Reputation: 11 SVTF4243 Great Standing Member
Parts
Pump | PS line | PS line fitting
TOOLS
Get metric crescent rachets 8,10,18 or at least stubbys
Pully puller get one from ford or the kind that applies force to the center rather that grabbing the rim of pulley.
5, 10 & 12 mm sockets w/extentions
Jack up car on 2 stands under front
Dump Old Fluid
1 Unbolt the coolant tank; popup with screwdriver in back slot (leave hoses attached!) & out of the way,
2 Pull the PS reservoir out of the slots (no screws, just rubber grommets)
3 Unclamp the small return hose on PS pump
Dump the reservoir fluid in a milk jug.
Pull Sepentine belt with 8 cresent & pipe for leverage on the tensioner
Pull PS pump
Pump is above ac pump
4 Unbolt 2 12mm along PS line on top of header,
Pull clamp for return line
Pump Unbolt 4 10mm
Trick on lower driver side bolt is to loosen first ;
pull other 3; then you can pull the pump out as you unbolt.
Maneuver pump through top of engine
Pull PS Line
Unbolt pressure line with an 18 crescent wrench. I clamped that bad boy down, it's on there.
Getting to PS LINE underneath the rack by:
Option 1 pulling out the dogbone trans mount and rocking the bottom of the motor forward
and holding it in that position with a jack or block of wood.
Option 2 Pulling driver tire
Unbolt the plate holds both the pressure & return line to the rack
Pull line from that end.
Unbolt 5mm bolt that holds the return & pressure lines in place
(I got to it from the top with a long extention.)
Reinstall Pump
Remove pulley with pulley puller & put on with supplied bolt & nut
Position lower driver side bolt first then
Put in black O-ring in the pump and bolt line fitting on pump; torque it well.
Bolt the pump in place
Reinstall PS LINE
Push in the tapered tip in Pump Fitting till it clicks in.
Push-in connection at the rack and bolt plate attached to the pressure line.
OPTIONAL-Replace both the pressure and return line o-rings at the rack while you're in there.
Bolt 2 12mm along PS line on top of header,
Clamp return line
Bolt Pressure line from bracket
Put in plastic braket & bolt 5mm bolt
Fill the reservoir with new fluid,
I left the car up on BOTH jackstands
pull Fuse 12, and crank the engine for about 5 seconds while turning the wheel stop to stop. Fill the reservoir and crank again.
Repeat the "crank, turn and fill" until the fluid going to the jug is clear and clean - should take a over a quart. On the last crank leave the reservoir barely empty. Put the return hose back on, replace the reservoir, fill it, and replace the coolant tank. Plug the fuse 12 back in and run the car, turning the wheel. Check the PS fluid level is between min & max.
Replace Serpentine Belt & Cover
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
Old 03-21-2010, 08:49 AM   #2
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,559, Level 43
Points: 4,559, Level: 43 Points: 4,559, Level: 43 Points: 4,559, Level: 43
Level Up 5% Completed
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
great write up, I'd sticky this
NJSVTGUY is online now
Old 04-18-2010, 01:38 AM   #3
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
Doing a WOT will also prevent the vehicle from starting and eliminates the need to pull fuse 12. The WOT crank is there for flooded cleanout.
paulg127 is offline
Old 11-18-2010, 04:29 PM   #4
DPDISXR4Ti
Fan#: 43470
FF Reputation: 1 DPDISXR4Ti Good Standing Member
Would this procedure pretty much hold true for a '08 Focus?
Brad
DPDISXR4Ti is offline
Old 11-18-2010, 05:02 PM   #5
2003SilverSVT
Fan#: 77592
What I Drive: Read my user name...
FF Reputation: 1 2003SilverSVT Good Standing Member
Agree.....STICKY Please
Nice write up
2003 CD Silver SVT
0007 of 3985
1972 Chevelle SS Supercharged 468 BB
1991 Pontiac Formula 5.7, 2010 F250 KR V-10
2003SilverSVT is offline
Old 08-20-2011, 09:42 PM   #6
Kauai Guy
/人◕ ‿‿ ◕人\
Kauai Guy's Avatar
Fan#: 58297
What I Drive: Car
Points 6,484, Level 52
Points: 6,484, Level: 52 Points: 6,484, Level: 52 Points: 6,484, Level: 52
Level Up 67% Completed
FF Reputation: 17 Kauai Guy Great Standing Member
Buy-Sell-Trade Rating: (17)
Also in for the sticky.
The line and fitting are sold seperately, so do you need to flare the new line or do you just put the new fitting on?
Sedan Revolution #150 Hatch Nation #26
Originally Posted by norcalfocus01 View Post
Because I'm on a boat and I just had sex
Kauai Guy is offline
Old 10-21-2012, 08:19 PM   #7
FLZ_Boy
Fan#: 104842
What I Drive: 2000 Red ZX3
FF Reputation: 1 FLZ_Boy Good Standing Member
I'm currently replacing the powersteering pump on my 2000 ZX3. I notice this post shows an O - Ring being placed in the union bolt hole on the power steering pump:
I looked through the factory service manual and didn't notice any O-Ring being placed there. Anyone replaced their power steering pump lately can elaborator on this??
Also, I tried using the new powersteering pump without the O-Ring and it leaks through the union bolt pressure line (attached to the bolt). The O-Rings supplied by the new pump did not fit in the union bolt hole. Or am I suppose to replace the the entire powersteering high pressure line??
Thanks!
FLZ_Boy is offline
Old 10-21-2012, 10:07 PM   #8
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
The fitting provided should look like the OEM one below. If you look closely, it has two O-rings; the white one about mid way that seals the fitting against the pump body, and a black O-ring in the bore of the fitting (you can just see it at the top) that seals the ps line against the fitting bore.
iirc, the ps line has a narrow groove machined in it and the fitting has a tiny circlip below the black O-ring in the bore (not visible) that clicks into the groove of the ps line to hold the fitting positively on the end of the line.
When I came time to relocate my ps line, I replaced a section of the pump end of the line with a new ps line and fitting and used a compression fitting to join the new and old line (so I didn't have to mess with the rack end.)
You're dealing with very high working pressure in the ps line so the leak proof sealing of the components isn't always as simple as it seems.
Not sure if that helps any.
BC_ZX3 is offline
Old 10-21-2012, 10:44 PM   #9
FLZ_Boy
Fan#: 104842
Thank you! That answers alot on how the union bolt is stoping the PS fluid from seeping out between the union bolt & pressure line. My new powersteering unit didn't come with a new fitting, I think they just gave me an O-Ring and hope I somehow stick the O-Ring in the old fitting.
How the heck did you remove the circlips when the union bolt is on the PS line? It's such a tiny opening to work with!
FLZ_Boy is offline
Old 10-22-2012, 12:26 AM   #10
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Perhaps "circlip" wasn't the best term; it's more of a very thin closed C-shaped wire with some springiness in it. You can't use traditional circlip pliers on it, for example, to compress it. (It's a bit like those plastic parts with one way tabs that snap together one time only during assembly.)
If I were you, I'd proceed by buying the fitting first - Ford part # F5RZ-3R608-B about $ 6-8 bucks - just to be safe. I say this because I think the fitting is intended to be installed once only and removing it will probably destroy or damage the circlip/ C-clip. Could be wrong on that though.
I would also suggest you remove the fitting from the ps line by carefully applied brute force. I didn't have to do that operation - I had a new fitting and new OEM ps line (parts came separately) - so anyone else who with experience on that can chirp in.
BC_ZX3 is offline
