From NA to TURBO engine modification steps - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: Which is cheaper NA or Turbo?
Turbo 6 40.00%
Normaly Aspirated 10 66.67%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Closed Thread
Old 08-19-2004, 01:58 PM   #1
autocrossman
autocrossman's Avatar
Fan#: 9968
What I Drive: 04 zx5 2.3L
FF Reputation: 1 autocrossman Good Standing Member
Can someone post a good list of steps to convert a Normaly Aspirated engine to a Turbocharged engine?
autocrossman is offline
    Quick reply to this message
Old 08-19-2004, 02:16 PM   #2
kaiten2
Fan#: 9696
What I Drive: 2004, red, zts
FF Reputation: 1 kaiten2 Good Standing Member
an N/A is cheaper cuz thats the way the car comes stock. so its already N/A as for a list on how to do that would probably be a fairly long list I dont think anyone has posted that though. But iv never done a conversion myself so sorry cant help you out.
-Performance- FC CAI, Custom 2.5" Exhaust, F2 4-1 Race Header, MM BS Delete, SCT ECU Reflash, F2 flywheel and centerforce clutch, EBC slotted and dimpled rotors and brake pads, Fuzion ZRi tires.
kaiten2 is offline
Old 08-19-2004, 06:35 PM   #3
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
Buy-Sell-Trade Rating: (6)
i actually seen a turbo handbook at fry's electronics by my house. it was only like $15 and had over 350 pages of turbo information such as what kind of piping and cfm velocity ratios and stuff... might wanna look into that kinda material so you got a complete understanding of what's going on....
at least this is what i would be doing....
Foci_Fosho is offline
Old 08-24-2004, 09:09 PM   #4
autocrossman
Fan#: 9968
TURBO CONVERSION LIST.. GOOD READ!!!
This is not going to be lengthy or overly technical but we hope it gives you a bit of insight. Different approaches are required with different engines. If you have a Honda or Acura you will have to beef everything up more than someone with a Nissan 240SX or Toyota Supra. As with all things in print, this is our opinion. It is based on years of hands on experience and many, many Turbo projects. At least let it be food for thought.
Engine
Normally aspirated engines are not happy with the heat and pressure of turbocharging. You need to lower the compression to a level manageable by the engine and ignition control you are using. Generally 7.5:1 to 8.0:1 will do what you want on today's terrible pump gas.
Pistons and Rings
Always use Forged Pistons that are properly designed for the engine you are building. We use JE Pistons and Total-Seal Rings in all our engines. If you cannot afford the forged pistons and you are building an engine that has a factory Turbocharged equivalent then use the factory Turbo pistons. They are never all that great for serious duty use but they are a good affordable alternative to normally aspirated high compression pistons. We use Total-Seal rings because they have proven to keep all the power in the cylinders and minimize blow by under hard boost conditions.
Block
Generally the block is fine for streetable boost levels. Very high boost pressures or race applications are a different story. If a steel shim gasket is available for your particular application, use it. They are expensive but well worth the money.
Cylinder Head and Porting
Good quality valve jobs and Stainless Steel valves. If Stainless Steel valves are not available or not in your budget at least get the stock ones high heat coated. This is generally in-expensive and will extend the life of the valve considerably. Porting varies with the head and engine. Generally for most street applications a nice clean up port with most of the attention being paid to the bowl area around the head of the valve and good match porting of the manifold and head surfaces. We try to do a high polish on the exhaust port to promote exhaust flow and minimize buildup and a swirl finish on the intake for better fuel atomization.
Ignition Timing Control
This is the key to Turbo cars running on pump gas. You cannot use a normally aspirated ignition distributor or engine control for a Turbo application. You will detonate and hurt even the best of pistons and rings. Most factory Turbo cars have excellent ignition systems with very conservative timing curves which are great for higher boost applications. If you are doing a normally aspirated to Turbo conversion you need to either incorporate the ignition into your fuel injection or use a timing control such as an MSD or JACOBS to insure you have proper boost retard for the level of boost you are running.
Fuel Management
We do not believe in Turbocharging any car without it being Fuel Injected first. Yeah, we know it's not impossible to have a carburetted Turbo system, we've even done it ourselves plenty of times, but it will have driveability and heat problems not to mention float and seal failures ( Just ask someone that owns a Maserati Biturbo ). Programmable management is really the answer to a simple and effective installation on a normally aspirated car. We use either the Electromotive TEC-II or the HALTECH F9A units. Retrofitting a factory F.I. system into a normally aspirated car or into a car with a different style of management is not impossible but it is very complicated, so be sure and have a very good working knowledge of the cars electrical system before undertaking such a task. We recommend an on-board air fuel ratio monitor in all applications to make sure you do not lean out the engine under boost and put big holes in things. We use the HALMETER AF/30. It is almost always necessary to install a larger volume high pressure fuel pump and some form of Boost Referenced Rising Rate Fuel Pressure Regulator to insure proper fuel delivery under boost.
Turbo System Components
This is a somewhat abbreviated list of the components and services we offer for misc. turbo projects. For specific fitment and application questions please contact us.
Turbonetics Turbochargers
T3-T66 and all the stuff in between.
Mitsubishi Turbochargers
TD05-TD06 12g-20g
Wastegates
Turbonetics Deltagates and HKS Race Gates. Adjustable Internal Wastegate Actuator
Compressor Bypass Valves
HKS Std., Racing, Sequential
Blow-Off Valves
HKS Adjustable
Boost Controllers
Manual VBC, Superchips Boost Graphic, HKS, Turbonetics.
Spearco Intercoolers
Any size, any shape, any configuration. Contact us for pricing and availability based on your requirements.
Intercooler Plumbing
Mandrel bent plumbing and pipe kits. Silicone Hose and couplers. Elbows and misc.
Turbo Exhaust Manifolds
Cast and custom made tubular header style
Turbo Fuel System Components
Fuel Injectors
Bosch, Lucas, Rochester, Siemens, Any size. High or Low impedance.
Fuel Pumps
Bosch High Flow pumps.
Fuel Regulators
Adjustable, Rising Rate, Boost Referenced, Etc.
Throttle Bodies and Fuel Rails
Sidedraft, Downdraft, Factory Replacement. Custom Enlarging. Custom Fuel Rails
Intake Manifolds
TWM Induction, Factory Manifolds.
Air Filters
K&N and ITG
Auxilliary Injector Controllers
Haltech F5, HKS.
Old 02-29-2008, 12:58 AM   #5
Slo_Focus
AKA Fast_Focus
Slo_Focus's Avatar
Fan#: 17238
What I Drive: 2007 LG ZX4, 2007 Yamaha Blue R6
FF Reputation: 14 Slo_Focus Great Standing Member
Turbo will be the cheapest alternative for the most power but it all depends on what you want to do with it and what your trying to accomplish
R6 runs 10s in 1/4 mile
FOCUS runs 10s in 1/8 mile
LOLZ!
Slo_Focus is offline
Old 02-29-2008, 07:04 AM   #6
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
holy back from the ages batman!
http://www.full-race.com/r14-fire-video.html
honhon is offline
Closed Thread
Similar Threads
The Ultimate 03-09 Focus Thread, SUPER LARGE AMOUNTS OF INFO. honhon DURATEC Performance (2008-2011) 59 08-04-2013 11:41 PM
Wagamos' turbo rebuild inc. engine Wagamos General Forced Induction 310 08-29-2010 05:28 PM
General Specs on the 2.3L Duratec b16sir1991 General Technical Chat 0 04-18-2007 11:21 AM
General specs on the SPI b16sir1991 General Technical Chat 0 04-18-2007 11:20 AM
supercharger vs turbocharger? FordFocusFreak General Forced Induction 6 04-07-2004 01:05 AM
