wiring a cigarette lighter. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-13-2010, 03:25 PM   #1
madkat
Fan#: 57666
What I Drive: 2008 Vista Blue Coupe
FF Reputation: 1 madkat Good Standing Member
I need to add a cigarette lighter behind my dash for my new HD radio (it's standalone, and I don't want another plug on my dash (plus I'm doing a professional install. I HATE wires snaking around, I tore my center out to hide my aux cable for my iPod.
madkat is offline
Old 03-14-2010, 04:55 AM   #2
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Are you wiring this radio so you can take out when you park the car ? If not why not just cut off the plug end of the radio and wire it straight in?.
iroc34 is offline
Old 03-14-2010, 06:25 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Ok, the easiest thing to do is going to be to find the wiring to the cig lighter in the dash. Then get you some Scotch inline connectors which allow you to tap into a wire with another wire without stripping. You basically put it over the top of the wire to be tapped, then insert the wire you want to tap with in the other side, and close the connector. If I had more time I'd find you a pic of what these look like. You can purchase them at hardware stores or automotive parts stores. It's more expensive than other methods- but easier, and if done correctly- very effective. Knowing your wire size is very important. Most things in car dashes are 16 ga or less.
OF course, don't forget to remove the negative terminal from the battery before doing any electrical work that involves splicing in a vehicle.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-15-2010, 12:28 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,391, Level 75
Points: 13,391, Level: 75 Points: 13,391, Level: 75 Points: 13,391, Level: 75
Level Up 36% Completed
Forum Activity 99%
To magnify the first comment, if you don't plan on removing the unit hard wiring it will avoid the PITA of the plug in regularly coming loose/wearing out over time.
And if you remove it occasionally without using it in another vehicle I'd recommend using a two wire flat plug connector (avail. at auto parts or radio shack) that is "polarized" (you can't plug it in backwards) as this won't come loose or get hot due to poor connection as cigarette plug styles do.
If you do this, make sure the "hot" side on the vehicle end is the "shielded" one, so when not plugged it it can't short to ground by accident.
sailor is online now
Old 03-16-2010, 07:00 PM   #5
madkat
Fan#: 57666
Thats what I have.
I want to put the plug behind the radio so I don't see it. I also want it to turn off when I turn the car off (It stays on unless I turn it off).
Can I just splice in with the 12v switched and ground from the radio and be ok?
madkat is offline
Old 03-18-2010, 01:24 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
That should be a low-draw, so wiring & fuse should be OK for that added load - so go ahead!
(any key-on power source should work..)
Old 03-18-2010, 11:17 PM   #7
flipwilly2
Fan#: 57010
What I Drive: '08 Silver Frost Metallic SES
FF Reputation: 2 flipwilly2 Good Standing Member
Check the fuse panel below the steering column-there is a pull off panel covering it up. My '08 had several fused unused circuits in the panel (check your owner's manual). I put a Ford Escape lighter plug (w/cover) in my trunk for a 12V cooler. I used an unused 20A circuit in the fuse panel and a mini fuse tap on the "out" side of the fuse. Couldn't have been easier!
My "Pocket Rocket": '05 Silver Metallic Escape XLT, 3.0L V6, 4X4, MAC SRI, custom 2-1/4" catback w/turbo muffler, SCT XCal3 93 octane ECU tune, approx. 240 hp, 4X4 fuse pulled (rice humiliator)
Wife's: '08 SES, Airaid SRI, no resonator, SCT tuned
flipwilly2 is offline
