Instrument Cluster Light Bulbs - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-11-2010, 04:46 PM   #11
plex07st
plex07st's Avatar
Fan#: 46577
What I Drive: 2007 Pitch Black ZX4 ST
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
Level Up 46% Completed
FF Reputation: 1 plex07st Good Standing Member
Well, obviously, '07 has to be different. I have 5 bulbs that all look the same. Took 1 of them with me to Advance Auto and looked like they would match up with the #74 bulbs. Oh no, they are not the same! The #74's are slightly fatter. They fit into their little sockets but spreads them out slightly and will not fit into the circuit board. Sooo... what size are these bulbs? Do I have to resort to going to the dealer and pay, what... $5-10 per bulb???
plex07st is offline
Old 04-11-2010, 06:08 PM   #12
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
When I need to do this.... Ill paint my needles
fhh02a is offline
Old 04-12-2010, 07:03 PM   #13
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
I believe the correct size you need is #37. I just tried replacing my HVAC lights with some new #74 bulbs and had the same problem with the base spreading open a little and you couldn't push it back together. I looked around and saw the #37 bulb as a cross reference. I don't know if it's physically smaller or not but I'm going to check the auto part store and see if they carry these.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 04-14-2010, 08:39 PM   #14
focus-spi
Fan#: 70882
What I Drive: 2003 white 4 door SE
FF Reputation: 1 focus-spi Good Standing Member
had to change my odometer bulb today, took about 20 mins to get the cluster in and out. I used a small pair of needle nose pliers to twist the bulb socket out. The trick was figuring out how to loosen that black clip holding the connector in...once I figured that out, piece of cake
focus-spi is offline
Old 07-01-2012, 09:34 PM   #15
N4niner206
Fan#: 99796
What I Drive: 2007 Oxford White Focus ZXW
FF Reputation: 1 N4niner206 Good Standing Member
I know its an old thread, but did anyone figure out what bulbs fit the 07? As mentioned above, 74 is too bulky. I also tried 37s and they also spread the fitting too much to fit back into the socket. Specifically, im changing two bulbs in the environmental air conditioning panel... 2007 ZXW.
N4niner206 is offline
Old 09-24-2012, 12:40 AM   #16
OhWellAlright
Fan#: 104171
What I Drive: 2001 green focus se
FF Reputation: 1 OhWellAlright Good Standing Member
i was looking for LEDs to replace the bulbs in my 2001 focus se but im having trouble finding ones that are #198. ive found plenty that are #194 but im not sure if those will work or not?
OhWellAlright is offline
Old 09-24-2012, 08:27 PM   #17
2003 Ford Focus
2003 Ford Focus's Avatar
Fan#: 91951
What I Drive: '03 Focus SE and '03 ZTW
Points 1,312, Level 20
Points: 1,312, Level: 20 Points: 1,312, Level: 20 Points: 1,312, Level: 20
Level Up 12% Completed
FF Reputation: 4 2003 Ford Focus Good Standing Member
Smile
Don't know if any of this helps, but I believe the 198 cross references to 1157 or 1034 (never heard of 198 until I found this cross reference)
http://www.imperialsupplies.com/pdf/D_VehicleLightingBulbCrossReferenceChart.pdf
This site has an LED version of the 1157:
http://www.superbrightleds.com/searc...d-lights/1157/
First Ford: '62 Falcon Futura 2-door / Modified Production 302 / 270 HP / Close Ratio 4-speed / 3.50 ratio 8" Fairlane Differential (289-271 HP cam / heads / exhaust / medium high rise / 600 CFM Holley / dual-point) Low 15's at 90+ MPH
2003 Ford Focus is offline
Old 09-25-2012, 10:01 PM   #18
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
Sorry this is so old, but to replace my 2000's dash lights, just follow the instructions, pop out the old lights, put in new blue leds (74 and 198) and re install?
Will the blue leds shine blue then on my numbers? Thanks for the help guys. Any pics of this done by anyone?
calebstubstad is offline
Old 10-10-2012, 02:42 PM   #19
OhWellAlright
Fan#: 104171
i tried putting blue LEDs in my dashboard but it didnt turn out as i expected. the numbers light up a really dim greenish blue color and everything has a blue outline on it. it doesnt actually turn everything blue because of the green tint that was already in the dashboard. im gonna try green ones next and see how that goes.
it is if u want it to be
Old 10-10-2012, 08:06 PM   #20
calebstubstad
Chef Boyardee
Fan#: 103240
Did you sand the numbers to let only blue through? Its the only way unless you buy a aftermarket gauge face
