Swirlplates. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-01-2010, 10:47 AM   #1
Prestidigitator
Fan#: 73085
What I Drive: 68 Mustang/64 Falcon Wagon
FF Reputation: 1 Prestidigitator Good Standing Member
2005 Swirlplates.
Reading in the threads around here when I came upon this one posted by S2 (Thanks S2 good read).
What caught my eye was the parts that I bolded.
2.0L Duratec 136hp (101kW) 136lb-ft (184N-m)
- Standard on the (non-ST) 2005+ Focus.
The Duratec 2.0 '993' is a 2.0 L (122 CID; 1998 cc) version built in Chihuahua, Chihuahua, Mexico. Bore is 87.5 mm (3.44 in) and stroke is 83.1 mm (3.27 in).
It is used in the US/Argentinian Focus and the Brazilian Ford EcoSport. (European Fiesta ST, Ford Focus and Focus C-Max, Mondeo, S-Max, Transit and Galaxy use Duratec HE engines). On the 2007 Focus, output is 136 hp (101 kW) at 6000 rpm with 136 ftlbf (184 Nm) of torque at 4250 rpm. The 2007 Focus sold in the US states of CA, NY, MA, VT and ME comes with the required PZEV emissions 20E version which produces 130 hp (97 kW) at 6000 rpm with 129 ftlbf (175 Nm) of torque at 4000 rpm. The PZEV is available as an option in border states. The compression ratio for both versions is 10:1. It has an aluminum engine block and aluminum DOHC cylinder heads. The cylinders are lined with cast iron. It uses SFI fuel injection, has 4 valves per cylinder and features fracture-split forged powder metal connecting rods, a one-piece cast crankshaft, and a cast aluminum or reinforced plastic intake manifold. It does not have variable valve timing. The power output is less than the Mazda version which does have VVT.
The plastic intake manifold on early versions has a major fault due to poor quality materials. The manifold has swirlplates mounted on a square shaft at the aperture where it mounts to the cylinder head. Early 4 cylinder Duratec engines can be ruined when the swirlplates break off and enter a cylinder. Most cases are of single swirlplates but also the shaft can wear and break. Early signs of this fault are evidenced by a ticking noise emanating from the front of the engine. This can occur as early as 25K miles, with failure typically occurring after about 90K miles.
I noticed that it states "early versions".
My question is does anybody know at what point they corrected this flaw and/or the safe cutoff date for the 2005?
The reason I ask is that I'm in the process of looking for a Focus and if I come across a 2005, buying it would be predicated on knowing that I'm NOT purchasing one with this design flaw.
Thanks again everyone.
Prestidigitator is offline
Old 03-01-2010, 11:54 AM   #2
Egz
Sckn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
I have never heard of them breaking and falling into the engine. At least no one on any board I read has experienced it.
Edit: I even just checked the TSB and Recall database, and there are zero references to this at all. Who wrote this?
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 03-01-2010, 12:05 PM   #3
mtadd162
Proudly Daily Driven
mtadd162's Avatar
Fan#: 47890
What I Drive: 2005 Focus ST
Points 5,921, Level 49
Points: 5,921, Level: 49 Points: 5,921, Level: 49 Points: 5,921, Level: 49
Level Up 86% Completed
FF Reputation: 9 mtadd162 Good Standing Member
yea, that is news to me...kinda scary if this is true because it pretty critical. Its also pretty amazing that i havent heard of this happening to anyone though, so i wouldnt worry about it.
Unless all that ticking we blame for the fuel injectors is actually this
05 Focus ST-Sold but missed
-ST Crew #73 N/A FTW!
Feb. 09' ROTM
SSR - Silver Sedan Revolution Member #1
Cams Installed, great made my car into a VTAK
mtadd162 is offline
Old 03-01-2010, 12:07 PM   #4
Prestidigitator
Fan#: 73085
S2 and right here on FF. "General History and Information"
http://www.focusfanatics.com/forum/showthread.php?t=179098
Scroll down to post #2
Old 03-01-2010, 12:17 PM   #5
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Well 05 wasnt the earily duratech. 03 and 04 was. So if your buying a 05+ I think you should be fine.
norcalfocus01 is offline
Old 03-01-2010, 12:30 PM   #6
Egz
Sckn' n Blown
Egz's Avatar
Fan#: 442
I'd like to know his source on that.
Egz is offline
Old 03-01-2010, 08:49 PM   #7
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 02 SVT, 2 7.3 L Diesel Excursions!
Points 27,869, Level 98
Points: 27,869, Level: 98 Points: 27,869, Level: 98 Points: 27,869, Level: 98
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
actually, i have heard that, i think it was through 05.
Now I rive 2 7.3 L diesel trucks!
mlbbaseball is offline
Old 03-08-2010, 07:02 PM   #8
Prestidigitator
Fan#: 73085
Swirlplates.
I originally posted this in the general forum with only a couple of responses and it was suggested to me that I re-post it specifically here.
If you have read this already sorry for the re-post.
While reading up on the focus I came across this article written in this forum.
Old 03-08-2010, 08:12 PM   #9
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,716, Level 78
Points: 14,716, Level: 78 Points: 14,716, Level: 78 Points: 14,716, Level: 78
Level Up 67% Completed
Forum Activity 14%
FF Reputation: 90 goinloco1 Excellent Standing Member
This is the only article ever seen about it and absolutely no one has had a problem like this that I've ever heard of. it sounds like if there was a problem it was 03-04. But as I've said, I've never seen nor heard of it at all. Notice theres no references where the article came from? a search also turned up nothing. Oh, and if the plate did break off it would fall to the bottom of the manifold, there is no way it could enter the cylinder as large as it is.
In other words, get the car and don't worry about it.
goinloco1 is offline
Old 03-08-2010, 09:17 PM   #10
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
Points 32,363, Level 100
Points: 32,363, Level: 100 Points: 32,363, Level: 100 Points: 32,363, Level: 100
Level Up 0% Completed
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
x2 I've moderated this forum for years and was active in it for years before that and have never heard of this happening.
I own an early duratec and never had an issue.
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
