Springbuck's SVT Turbo build - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-25-2010, 10:52 AM   #71
Springbuck
Fan#: 23301
What I Drive: 03 CD Silver SVT 5DR
FF Reputation: 1 Springbuck Good Standing Member
Ok, I am just about ready to start it up. Apart from priming the oil feed is there anything I need to check/ setup? The BOV or WG or boost controller?
Just to check, I have a turbonetic's WG, the bottom feed is from my vacuum block and the other goes to the boost controller if I read the instructions correct. Do I block off the 3rd port on the boost controller or leave it open? I have the Profec type S
03 SVT Focus, STS,
2011 Fusion SEL -Bone Stock and staying that way
Springbuck is offline
Old 08-25-2010, 07:34 PM   #72
Springbuck
Fan#: 23301
Anyone that can help me with the vacuum hookups? Mine is connected as follows:
From boost controller (COM) it goes to top port on Turbonetics WG.
From NC port on controller it is teed in between vacuum block and bottom port on WG.
BOV is connected to vacuum block
Fuel is connected to vacuum block as is boost gauge
Another question, do i block off the 3rd port on the boost controller (NO) or just leave it open?
03 SVT Focus, STS,
Old 08-25-2010, 10:47 PM   #73
pitchedblack04
Bewst Anyone!!!
pitchedblack04's Avatar
Fan#: 62993
What I Drive: 2004 turbo'd svt
Points 3,266, Level 35
Points: 3,266, Level: 35 Points: 3,266, Level: 35 Points: 3,266, Level: 35
Level Up 44% Completed
FF Reputation: 7 pitchedblack04 Good Standing Member
that port should be left often to vent the excess pressure.
Car is for sale. Pm me for details.
pitchedblack04 is offline
Old 08-26-2010, 12:30 AM   #74
Springbuck
Fan#: 23301
What should I log for the tune?
03 SVT Focus, STS,
Old 08-27-2010, 11:47 AM   #75
Springbuck
Fan#: 23301
Hello guys,
Right above the lever where the IMRC cable for the intake dual runners connects is a vacuum source. After I removed my JRSC it is now open. Where is it supposed to be connected to or should I blank it off?
Thanks
03 SVT Focus, STS,
Old 09-05-2010, 11:11 AM   #76
Springbuck
Fan#: 23301
Well I am at a standstill for a while. My XCAL2 took a dump and nothing is open around here for me to buy a X2 or X3 :(
Was just going to start tuning for WOT too :(
03 SVT Focus, STS,
Old 02-15-2011, 12:16 PM   #77
Springbuck
Fan#: 23301
Well after a few mishaps it is finally running good. I now have a built block after it started blowing all the oil into the catch can :) and after putting in the new block the clutch plate broke. The plate holding in the springs on the clutch broke and the springs came out. Car runs fine on 10psi (for now). I will dyno it after the new clutch is broke in.
03 SVT Focus, STS,
Old 03-12-2011, 08:27 PM   #78
Springbuck
Fan#: 23301
Almost done tuning, but now I have a new (niggling) issue. After a 2 hour freeway drive at a constant 70mph I now have a rather loud tac-tac sound coming from the intake side of the engine. It sounds just like a loose "tappet", but these have no rockers, just those buckets. Now I measured the valve clearance and on number 3 and 4 intake side valves and the clearance is 0.209mm. The manual I have says it should be 0.11 to 0.18. Now my question is can that small a difference cause a loud valve train noise? Only change I recently made is to change oil (Only had 10W30 available so that is what I used).
03 SVT Focus, STS,
Old 03-12-2011, 10:52 PM   #79
bmylez
bmylez's Avatar
Fan#: 64637
What I Drive: 2003 350Z Track
FF Reputation: 23 bmylez Great Standing Member
The clearances on my intake cam on my SVT were pretty big. It was extremely loud clacking. Definitely could be the culprit.
1992 Eagle Talon TSi - sold (POS)
2002 Mustang GT - sold
2002 SVTF - sold
2008.5 Mazdaspeed3 GT - cursed
2003 350Z Track - basically stock, and it runs
bmylez is offline
Old 03-13-2011, 03:26 AM   #80
Springbuck
Fan#: 23301
The car drives fine, it is just this loud clacking that is an issue. It's just too loud when driving. Sounds like the car is about to fall apart in traffic :)
03 SVT Focus, STS,
