Springbuck's SVT Turbo build - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2011, 12:06 AM   #91
Springbuck
Fan#: 23301
What I Drive: 03 CD Silver SVT 5DR
FF Reputation: 1 Springbuck Good Standing Member
I also thought it was a clearance issue, but both block and pistons are STD. I cannot complain about the place I bought the stuff. They have been fair to me all along. I thought it was valvetrain related as well until I saw (very small) metal pieces in the bottom of the sump so I took the head off. If it was a lubrication issue I would think the rod bearings would go first, but that was not the case. Also the edges where it broke is not "burned" or smooth, it is very rough like it was just broken off. I also cannot understand why the worst scoring is at the bottom of the cylinder almost like the piston got stuck canted to one side. I was lucky that the broken piece did not damage my turbo. It looks like it went out without hitting anything. All the blades look fine. The seals from the intake are also all still there so it was not those that could have blocked the intake port. In any case if one of those got loose I would expect 1 cylinder to be affected not 3 of the 4.
This has been a bit of a ordeal. First the stock SVT breaks its ring lands, then one of the spings on the SPEC clutch plate breaks a loose and I have to take it all apart, then it starts running nicely and this happens. This is the 4th time I had to pull the motor or transmission out.
I am going to use the original SVT block once I get new pistons, but I am going to ask for some local help to put it all back together again. I am tired and its a pain doing it all alone :)
03 SVT Focus, STS,
2011 Fusion SEL -Bone Stock and staying that way
Springbuck is offline
Old 03-22-2011, 12:40 AM   #92
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,180, Level 56
Points: 7,180, Level: 56 Points: 7,180, Level: 56 Points: 7,180, Level: 56
Level Up 15% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
That sucks man. Sorry to see all that. To me is almost looks like you had defective pistons. It seems like the pistons weren't perfectly round and the two spots were rubbing the cylinder walls. Just a guess.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 03-22-2011, 01:17 AM   #93
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
Points 9,232, Level 64
Points: 9,232, Level: 64 Points: 9,232, Level: 64 Points: 9,232, Level: 64
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
Spec clutches are junk your not the first ive seen that happen to.
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 03-22-2011, 01:28 AM   #94
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Was there any valve or head damage?
iroc34 is offline
Old 03-22-2011, 10:46 AM   #95
Springbuck
Fan#: 23301
I saw no valve or head damage.
03 SVT Focus, STS,
Old 03-22-2011, 02:55 PM   #96
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,537, Level 100
Points: 52,537, Level: 100 Points: 52,537, Level: 100 Points: 52,537, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
I still feel this was heat related , Cyl temp not water temp
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-22-2011, 03:20 PM   #97
Springbuck
Fan#: 23301
Quite possible Tom, but from what I was told in the case of that kind of heat issue you are talking about there would be score marks in the middle of the piston skirt in addition to burn marks on the pistons and cylinder walls. All references I found with the seize marks on either side of the skirt (thus 4 clear seize marks) the number 1 issue is incorrect piston clearance. I am not saying that is the issue, I am going to check if that was a factor. I am taking the block and pistons to have that checked. In the mean time I am going to rebuilt my original SVT block.
03 SVT Focus, STS,
Old 03-22-2011, 05:37 PM   #98
iroc34
iroc34's Avatar
Fan#: 69289
I cant believe that with the amount of scoring and damage that the engine was still running. And good enough that you believd it was only needing a bucket adjustment...Sounds like your on the right trail, pistons over sized and a stock bore...
iroc34 is offline
Old 03-22-2011, 07:04 PM   #99
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
When a piston gets as hot as I think yours did they will distort and change shape , what we need to find is what caused this
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-22-2011, 07:18 PM   #100
bmylez
bmylez's Avatar
Fan#: 64637
What I Drive: 2003 350Z Track
FF Reputation: 23 bmylez Great Standing Member
I remember John had a chunk of piston melt off because his J&S malfunctioned and made his EGTs skyrocket. Plausible?
1992 Eagle Talon TSi - sold (POS)
2002 Mustang GT - sold
2002 SVTF - sold
2008.5 Mazdaspeed3 GT - cursed
2003 350Z Track - basically stock, and it runs
bmylez is offline
