Reverse Flip Hood - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-28-2010, 11:43 AM   #1
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
Reverse Flip Hood
Front Reverse Hood
Here are the basic instructions and pictures you need to turn your hood into a corvette style hood. This is also known as reverse opening hood or suicide hood. Do this at your own risk!
The main question I get asked is "What do I need to buy for supplies?" All you will need to buy is hood pins. Hood pins can be picked up off of eBay or at local automotive stores. They range from $6-25 depending on the style and quality but that’s up to you.
First thing you will need to do is remove your hood from the car completely. There are two hinges: one on each end of the upper part of the car which will need to be unbolted from the hood. You will need some help to hold up the hood. Then you can sit your hood aside for now.
Now remove those hinges that were attached to the hood from the car. There will be another two bolts per hinge to the right that will need to be removed also. Now what you will have to do is remove the stock latch from the front of the car. It is bolted between the headlights and held on by 4 bolts.
Now that you have removed everything, you are ready for the tricky part. MEASUREMENTS: You will need exact measurements on where to drill. You will have to move those stock hinges that were near the window up to where the latch was.
The picture below shows you where these should be exactly and how they should look.
Then you will bolt them into the metal and to the hood. Personally I recommend drilling three holes on each hinge to the hood as shown in the picture. Make sure everything lines up perfectly before this is done or you will regret it. You don’t want to drill holes in the wrong spots. I recommend at least two people doing the drilling and measuring to make sure things are done right.
Now you will need to put on the hood pins. Those must be drilled in near the wiper blade as shown in the next picture. As for the rest of the installation of the hood pins it all depends on the style of hood pins you bought. Instructions should be included with them and the process is not too difficult.
Now the final step is to find a place to drill a hole where the arm can hold the hood up.
Here is an example:
This picture gives you an idea of where I drilled the whole. Just use the arm to decide the best spot. ALL DONE!! Now that wasn’t so hard. Have fun showing off that engine.
I hope you have something worth showing off if you are doing this trick to your car. Or at least a cool paint job!
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 02-28-2010, 12:41 PM   #2
blkfocuszx3
Hotswapzzz or Bust
blkfocuszx3's Avatar
Fan#: 51657
What I Drive: 1984 Rabbit L
Points 5,400, Level 47
Points: 5,400, Level: 47 Points: 5,400, Level: 47 Points: 5,400, Level: 47
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 3%
FF Reputation: 5 blkfocuszx3 Good Standing Member
Buy-Sell-Trade Rating: (8)
EW absolutely not.
It looks great on that cavalier and sunfire......................
Facebook.com/PlastiDipisNOTaMod
Plastidipisnotamod.com
IG: @PlastiDipisNOTaMod
blkfocuszx3 is offline
Old 02-28-2010, 03:00 PM   #3
Flashypants
Flashypants's Avatar
Fan#: 70173
What I Drive: 2001 Green Wagon
FF Reputation: 2 Flashypants Good Standing Member
Buy-Sell-Trade Rating: (6)
LOL not a good idea
Half 01 half 05 with some Roush in it
Flashypants is offline
Old 02-28-2010, 03:07 PM   #4
NOWAY
NOWAY's Avatar
Fan#: 49590
What I Drive: 03comp.O svt ZX3/13ingot silver ST
Points 321, Level 6
Points: 321, Level: 6 Points: 321, Level: 6 Points: 321, Level: 6
Level Up 43% Completed
FF Reputation: 3 NOWAY Good Standing Member
some one had that on a focus at one point cant remember who it was tho....
The Guild of Calamitous Intent
NOWAY is offline
Old 02-28-2010, 04:02 PM   #5
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,233, Level 41
Points: 4,233, Level: 41 Points: 4,233, Level: 41 Points: 4,233, Level: 41
Level Up 42% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Would like to see it on a focus. Looks to me that the only thing on the focus you could mount the hinges to would be the radiator support and that sits pretty far back from the front on the hood. I thought, and it might be on fj, that someone did a hood that opened to one side of the car, that was weird.
I now drive a Japanese Ford.
macdiesel is offline
Old 02-28-2010, 04:54 PM   #6
TaylorinAlaska
TaylorinAlaska's Avatar
Fan#: 62423
What I Drive: F-dub soon-to-be
FF Reputation: 17 TaylorinAlaska Great Standing Member
This wont work on an 05-07 without 2 brackets or a custom mount...
Thanks for this though, a lot of people miss out on the good mods because this section is full of "what stickers should I get?" lol
TaylorinAlaska is offline
Old 02-28-2010, 05:00 PM   #7
zx360
zx360's Avatar
Fan#: 32439
What I Drive: 2005 black zx3 ses
Points 16,894, Level 83
Points: 16,894, Level: 83 Points: 16,894, Level: 83 Points: 16,894, Level: 83
Level Up 9% Completed
FF Reputation: 44 zx360 Great Standing Member
Buy-Sell-Trade Rating: (33)
someone on here has done it...
FocusFest 11' "Best in class" • Oct'11 HOTM • FITF'12 "Best Show & Shine" • July 12 ROTM
instagram @360DSGNS
zx360 is offline
Old 02-28-2010, 05:15 PM   #8
NOWAY
NOWAY's Avatar
Fan#: 49590
Points 321, Level 6
it was a black sedan i believe....
NOWAY is offline
Old 02-28-2010, 05:34 PM   #9
zx360
zx360's Avatar
Fan#: 32439
yeah brandon something if im not mistaked
instagram @360DSGNS
zx360 is offline
Old 02-28-2010, 05:36 PM   #10
02Zetechse
02Zetechse's Avatar
Fan#: 65832
I was hoping that people who want to be custom with out dropping xxx amount would like this. I am the kind of person who likes anything I can do myself without chunking my budget. it is a do at your own risk mod i am not held responsible.
