hfc causing rough idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-26-2010, 05:24 PM   #1
BgJeff23B
Fan#: 50917
What I Drive: 2002 pitch black svt
FF Reputation: 1 BgJeff23B Good Standing Member
ever since i put the hfc and hks exhaust on i have been having rough idle and alot of backfiring popping going on. sometimes when i come to a stop it will have a rough idle. do you need a re tune when you do this?
BgJeff23B is offline
Old 02-26-2010, 06:41 PM   #2
djo90
because race car
djo90's Avatar
Fan#: 60957
What I Drive: 2007 ms3
FF Reputation: 6 djo90 Good Standing Member
a tune would likely fix your problem. Also check your O2
2007 Mazdaspeed 3 black mica metallic
1988 Jeep Comanche (MJ) blue/gray. 4.0 5 spd
Rice, It's what's for dinner.
djo90 is offline
Old 02-27-2010, 09:57 AM   #3
svtcliff
svtcliff's Avatar
Fan#: 61169
What I Drive: 2004, SONIC BLUE, FOCUS SVT
FF Reputation: 8 svtcliff Good Standing Member
Buy-Sell-Trade Rating: (7)
are you throwing any CEL's. if its back firing it sounds like its running really rich so i also agree with the above that you need to check o2's. a tune would also help but i have an exhaust with ORP and dont have any issue with a stock tune so its not required. did you reset the pcm when you installed it. if im not mistaken anytime you do a modification to a focus you need to remove the negative batt terminal for 15 mins to reset the pcm. then when you reconnect it and crank it up the pcm goes throu and learning stage for a few miles. it normally does run the greatest or have the most optimum performance but it relearns the car and mods. i know that for my orp and TB it was suggested in the instructions to reset the pcm. just some ideas.
2004 FOCUS SVT w/JRSC & FFRP BBK #1709 of 1978
2000 FOCUS ZX3 (project car)
1987 MUSTANG GT 5.0
svtcliff is offline
Old 02-27-2010, 10:15 AM   #4
bmylez
bmylez's Avatar
Fan#: 64637
What I Drive: 2003 350Z Track
FF Reputation: 23 bmylez Great Standing Member
Backfiring doesn't mean you're running rich. With my previous tune, my car would sometimes backfire like a banshee and according to my AFR gauge, I was running leaner than 18:1. A HFC should not cause a rough idle at all. Something else mechanical or electrical is going on.
1992 Eagle Talon TSi - sold (POS)
2002 Mustang GT - sold
2002 SVTF - sold
2008.5 Mazdaspeed3 GT - cursed
2003 350Z Track - basically stock, and it runs
bmylez is offline
Old 02-27-2010, 10:19 AM   #5
BgJeff23B
Fan#: 50917
ive replaced plugs and wires. im thinking maybe the pcv valve may be bad. i do have a p0420 code.
Old 02-27-2010, 11:13 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,900, Level 100
Points: 51,900, Level: 100 Points: 51,900, Level: 100 Points: 51,900, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Most any mods need a tune , Adding a HFC the engine leans out so a tune not only will help the lean issue but you will have a scan tool where you can fine any other issues that show up
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-03-2010, 12:13 PM   #7
xDEViiLx
Fan#: 71630
What I Drive: 2000 Silver ZX3
Points 758, Level 14
Points: 758, Level: 14 Points: 758, Level: 14 Points: 758, Level: 14
Level Up 58% Completed
FF Reputation: 1 xDEViiLx Good Standing Member
I'm actually having the same problem. My engine runs really rough at idle and sometimes stalls out. I have no cat on my car. So doing a tune would fix it?
Posted via FF Mobile
xDEViiLx is offline
Old 04-03-2010, 12:56 PM   #8
bmylez
bmylez's Avatar
Fan#: 64637
Not necessarily. You could have a mechanical/electrical problem.
Has the car *always* run like that after putting the ORP on? If the problem just developed recently, doesn't sound tune related. Dirty MAF, fouled spark plugs, bad front O2 sensor, bad coil pack, etc, can cause problems.
2002 SVTF - sold
bmylez is offline
