2000 SE W/ Split Port 2.0L runs rough - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-22-2010, 05:32 PM   #1
Mr. Ford Focus SE
Fan#: 72956
What I Drive: 2000, F/K Gold, Focus SE, Wagon
FF Reputation: 1 Mr. Ford Focus SE Good Standing Member
hello all,
I have a 2000 Ford Focus SE with 150,000mi on it.it has the 2.0L Split Port engine in it. it runs rough at idle and low speeds. somewhat smoothes out once at highway speed. prior owner already changed plugs, plug wires, all filters, fuel system and intake cleaning. it kinda seems to me that the timing may have jumped a tooth. i have not been able to read the codes yet. plan to tonight. any ideas please let me
Mr. Ford Focus SE is offline
Old 02-22-2010, 06:49 PM   #2
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Could be a timing thing...or it could be the dreaded spi problem of the valve seat dropping. Unfortunatly you do have a lot of miles on it, so I would not be surprised if it is the problem. But rough doesn't necessarly mean that. Maybe get it checked out like get the compression checked or make sure everything is running as it should.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 02-22-2010, 07:43 PM   #3
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
movede to spi section maybe better help here.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 02-23-2010, 11:05 AM   #4
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Except you put it in the owner's lounge, which is even more obscure than the SPI Performance Chat
Anyhow, to the OP, does it get any better when the car warms up ?
Mine acted like that until I replaced the upstream o2 sensor because the heater circuit was bad. After that it was replaced with an inferior aftermarket sensor which made the cold running issue go away (good heater circuit) but it didn't run like it used to when warm. Now with an oem identical sensor it's good.
Anyhow, if the o2 sensor is original it may need to be replaced. The MAF sensor also controls fuel trim and if you have the ability/specs to test it, it would be a good idea too.
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
Old 02-25-2010, 09:06 AM   #5
Mr. Ford Focus SE
Fan#: 72956
Update: pulled Codes P0302 Cylinder 2misfire
- pulled all plugs performed compression test
- good compression in cylinders 1, 3, 4
- NO compression at all in cylinder #2
- added a little oil to cylinder no improvement
- added compressed air to cylinder through plug hole turned engine to close both valves
- noted no air leaking through valves
- Used bore scope to perform internal cylinder inspection
- Noted hole in piston and damaged cylinder wall
- most likely cause due to running engine with to hot of a spark plug or wrong plug.
- needs new engine...:(
Old 02-25-2010, 06:54 PM   #6
2003focusowner
Fan#: 51939
What I Drive: 2003 Focus SE SPI
Points 5,246, Level 46
Points: 5,246, Level: 46 Points: 5,246, Level: 46 Points: 5,246, Level: 46
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 2 2003focusowner Good Standing Member
I have an '03 2.oL SPI with 135,000 and it does idle rough. Just started doing that...runs normal during standard driving. 80k on the platinum plugs I put in a while back......getting ready to change those.......
2003focusowner is offline
Old 03-02-2010, 01:03 PM   #7
dsmuts
dsmuts's Avatar
Fan#: 56574
What I Drive: 97 Black SHO
FF Reputation: 9 dsmuts Good Standing Member
I'll bet it dropped a valve seat and then the valve hit the piston and put a hole in it.
"Don't make me angry, you wouldn't like me when I'm angry"
dsmuts is offline
Old 03-02-2010, 02:55 PM   #8
2003focusowner
Fan#: 51939
And will be connecting a scan tool on it tomorrow night. These symptoms are also evident of a bad egr or MAF sensor.
Old 03-02-2010, 07:54 PM   #9
Mr. Ford Focus SE
Fan#: 72956
not real sure of what caused the failure yet.. I am switching the engine out though I am not putting in another SOHC. I am switching it over to a DOHC Zetec 2.0L that i just purchased with 50,000 miles on it. after i complete the swap over i plan to tear down the SOHC to just inspect the engine for the cause of failure. I have noticed that the valve seat dropping issue seems to be a major flaw in that engine. so you are most likely right.
Old 03-02-2010, 09:38 PM   #10
dsmuts
dsmuts's Avatar
Fan#: 56574
Assuming its an auto you'll need more than just the motor. you'll need wiring harness, ecu, pass motor mount, exhaust manifold, and i'm prob leavin a few things out but make sure you have everything before you rip into it and good luck
dsmuts is offline
