Ford Racing Suspension Applications defined - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-20-2010, 12:36 AM   #1
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
I think I have put a dent in the confusing Ford Racing shock/strut and spring combinations. If anyone has any comments or further clarification please chime in.
Shocks:
M-18000-zx3 00-05 Stock SVT shocks & struts (comes with mounts, bearings, etc)
M-18000-zx3b 06-07 Stock SVT shocks & struts ( " " " " )
The above two shocks are combined with the M-5560-ZXM or M-5560-ZX3 springs below (depending on model year) to create what is commonly referred to as the FRPP kit.
M-18000-zxm 00-05 Dynamic Design by Tokico
M-18000-zxm1 06-07 Dynamic Design by Tokico
M-3000-ZXM 00-05 Multimatic by Dynamic (springs and shocks -INVERTED DESIGN)
Springs:
M-5560-zxm 00-05 1.5" drop
M-5560-zx3B 06-07 1.5" drop (Spec Focus Spring for 06-07)
M-5560-zxm1 06-07 1.5" drop (can't find out how this differs from zx3b spring)
Spring/Shock Kits:
M-3000-zx3 00-05 Stock SVT kit w/rear sway, w/o strut top mounts
M-3000-zx3A 00-05 Stock SVT kit w/o rear sway, but with strut top mounts
M-3000-zxm 00-05 Multimatic by Dynamic (inverted design) with springs
NOTE: Based on info I received from a spec focus racer (and as also shown in recent pictures of Dynamic Design built by Tokico struts posted in the FF suspension section) the Dynamic Design by Tokico does not have the large inverted strut rods/shafts that come on the Multimatic by Dynamic struts. The Tokico design is exclusively for 06+ cars and the Multimatic is built for 00-05 cars only. The Multimatic is the preferred shock for 00-05 spec focus cars. There are rumors circulating that the Multimatic may be phased out.
Geezer is offline
Old 02-20-2010, 12:42 AM   #2
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Instant sticky! Great info Geezer.
norcalfocus01 is offline
Old 02-20-2010, 12:56 AM   #3
CopperMach
CopperMach's Avatar
Fan#: 42945
What I Drive: 2002 Copper Mach Audio Focus ZTS
Points 501, Level 10
Points: 501, Level: 10 Points: 501, Level: 10 Points: 501, Level: 10
Level Up 2% Completed
FF Reputation: 10 CopperMach Great Standing Member
I recently purchased the M-3000-zxm kit for my car, but I am waiting for the roads to improve so I can put back on my summer wheels/tires (currently have the svt suspension on.) The pistons on the Dynamic struts are massive. Could you shed some light on what is different about the "inverted design."
CopperMach is offline
Old 02-20-2010, 01:09 AM   #4
Geezer
Fan#: 1427
The shaft is a hollow tube not solid. Because of its size it's stronger without a major weight penalty a solid shaft that size would have. The valving is not attached to the bottom of the shaft like other solid rod shafts. Its located within the tube (usually at the top of the strut hence the term inverted design). As a result there is more shock travel, especially for compression, and can maintain more travel with shorter springs all while minimizing the chance of damaging the valving if the shock should bottom out.
Geezer is offline
Old 02-20-2010, 01:17 AM   #5
CopperMach
CopperMach's Avatar
Fan#: 42945
Thanks for clarifying that for me. Also I noticed that there is a nut on the bottom of the strut assy. I guessing that the strut is rebuildable. Thoughts?
Old 02-20-2010, 01:25 AM   #6
Geezer
Fan#: 1427
That I can't comment on other than I wouldn't touch it unless I knew exactly what it was for.
Geezer is offline
Old 02-20-2010, 02:00 AM   #7
CopperMach
CopperMach's Avatar
Fan#: 42945
Was not planning on messing with it, just curious. Thanks for the info.
Old 02-21-2010, 12:08 AM   #8
MaroonZX3
Fan#: 49579
What I Drive: 2003 Red ZX3
FF Reputation: 12 MaroonZX3 Great Standing Member
Is monotube another name for the inverted design? I'm thinking so, but I could easily be wrong about that.
MaroonZX3 is offline
Old 02-21-2010, 02:56 PM   #9
Geezer
Fan#: 1427
No, a monotube shock can be found with standard design shocks (valving at bottom of shaft/rod). For example, most Bilsteins are monotubes and are not inverted design. A monotube design costs a little more because they require better seals and valving as they use higher internal gas pressures.
Geezer is offline
Old 03-06-2010, 04:31 AM   #10
kamann
Fan#: 6269
What I Drive: 02 Black SVT Focus
FF Reputation: 2 kamann Good Standing Member
I have a question. How would these springs, M-5560-zxm 00-05 1.5" drop, and, M-18000-zx3 00-05 Stock SVT shocks & struts, perform together? Is this basicly the FRPP kit that Hillbish puts together? I want the drop but I like the way my SVT feels. I don't want stiffer like Dynamic. Just curious, thanks.
kamann is offline
