AEM wideband to xcal3 question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2010, 06:25 PM   #1
devanZX3
devanZX3's Avatar
Fan#: 72782
What I Drive: 2002 grey ZX3
FF Reputation: 2 devanZX3 Good Standing Member
Tom said to make a post on here. I need to know where to get the firewire cable or if its something i can get local. and how to wire it to the xcal3
2002 ZX3,eagle rods,probe 9:1 pistons,,bbk TB,adjustable fidanza cam gears,sportscams,shorty header with 2.5" exhaust,xcal3 and AEM wideband,specstage3 clutch,torsen center
devanZX3 is offline
Old 02-19-2010, 06:34 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,811, Level 100
Points: 51,811, Level: 100 Points: 51,811, Level: 100 Points: 51,811, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
I would like to see a sticky done about the fire wire , how its hooked up and the setting to make the gauge match the log
I get 2 to 3 emails a week about this and a sticky would help
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-20-2010, 12:52 AM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
I just finished doing this and had the same questions. Hope this helps.
Purchase a firewire cable available at most computer stores. Both ends should be identical.
Cut off one end near the connector and strip away and expose the inner wires. There will be six.
Here's the part that gives the most difficulty. Each coloured wire corresponds to a small brass pin in the other connector end. We need to determine which pin position corresponds to each wire colour. There are a couple of different colour schemes used depending on who makes the cable.
Make yourself a diagram.
Strip each wire end and then get out the handy multimeter and map each pin to its colour like so.
The result is something like that shown below. We can pick either of the two colours - in this case, red or yellow - that correspond to the firewire pins the SCT scanner uses for analog inputs. Red is Channel 2; yellow is Channel 1. We only need a single channel.
I chose red which corresponds with analog input Channel 2. Trim the other wires.
Crimp a connector on it and tape it up. You can solder it if you want; just make sure it's secure.
Now connect it to your AEM gauge harness. Use the white wire (to which I've already crimped a female connector).
Connect the rest of your wiring as shown here to power the AFR gauge. The interior fusebox is your best 12V power source and the unpainted metal fusebox housing can act as your ground. Put proper connectors on the exposed wire ends. You probably want a fusible link on the 12V power source.
Fit the unmodified Firewire cable end of your butchered Firewire cable into SCT scanner (at the top), the large SCT scanner cable end into the OBD II port of the car and a USB cable from the SCT scanner to your notebook computer, if you're using one to datalog.
When preparing to data log, go to "Data Logging" then "Set Up" in the SCT scanner menu and configure scanner analog inputs, when prompted i.e. "Configure Analog Inputs? Y/N" will appear on the screen. Select Channel 2 (or 1 depending on the wire you chose) and specify "Wideband" and then "AEM" from the scrollable list presented. This will apply a formula to the raw voltage generated by the sensor located in the exhaust stream and convert it into a more recognizable AFR ratio - the same as the in dash gauge will display - in the resulting logs.
You can datalog to the scanner itself or to the notebook using the Livelink software package.
When you've finished with the SCT data logging, simply disconnect the white analog input wire and cap it. Tie it up near the OBDII port out of sight until it's needed. Store your Firewire cable in a safe place ready for future use.
This set up worked for me without problem. Let me know if I've made any errors and I'll fix 'em.
BC_ZX3 is offline
Old 02-20-2010, 01:19 AM   #4
mikealicious
'Merica
mikealicious's Avatar
Fan#: 47077
What I Drive: 2002 Black SVT (gone), 2012 SEL
Points 8,576, Level 62
Points: 8,576, Level: 62 Points: 8,576, Level: 62 Points: 8,576, Level: 62
Level Up 43% Completed
FF Reputation: 8 mikealicious Good Standing Member
Buy-Sell-Trade Rating: (10)
Awesome write up man! One question for ya. Since I'm lazy and usually would mess something like this up, when the time comes, would you make me one and send it to me? Haha (I'd obviously pay for the cable and your time)
Visit here to see fast cars and races. ---> YouTube: mikealicious2k5
mikealicious is offline
Old 02-20-2010, 02:09 AM   #5
badass3
FocusXtreme
badass3's Avatar
Fan#: 54096
What I Drive: 2001, Pitch Black, ZX3
FF Reputation: 7 badass3 Good Standing Member
Buy-Sell-Trade Rating: (17)
sticky this so i can find it later lol
Hatch Nation #24
Zetec Crew #270 ATXF #49
badass3 is offline
Old 02-20-2010, 06:42 AM   #6
devanZX3
devanZX3's Avatar
Fan#: 72782
This has got to be the most informative and descriptive write up,on how to do something i have ever seen. Very,very helpful.
devanZX3 is offline
Old 02-20-2010, 07:13 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,186, Level 100
Points: 138,186, Level: 100 Points: 138,186, Level: 100 Points: 138,186, Level: 100
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
This is nice. I'm going to do this tomorrow.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 02-20-2010, 08:54 AM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
The fire wire SCT sells is it a direct plug and play ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-20-2010, 12:08 PM   #9
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
Thanks guys. I'm glad you found it useful.
I had a look on SCT's web site for an appropriate cable before doing this and most of the cables shown are for earlier flasher models and/or purposes. Also the prices and shipping wait times put me off. Link
Some other SCT vendors do sell a firewire cable and mention wideband data logging but they do state modification of the wire is required. This one even has a pinout diagram.
Link
I had a spare firewire compter cable hanging around home so I didn't have to buy anything.
BC_ZX3 is offline
Old 02-20-2010, 09:15 PM   #10
Juantron
Juantron's Avatar
Fan#: 56983
What I Drive: '03 SVT-5
FF Reputation: 3 Juantron Good Standing Member
What an awesome write-up man!!! I couldn't have said it better myself ;)
Juantron is offline
