Go Back   Focus Fanatics > Regional Forums > Southern Fanatics > Fanatics: Texas
Fanatics: Texas Regional discussion Forum for planning events and sharing information with all Members in the Texas (Lonestar) areas.
Old 01-26-2013, 12:22 AM   #19881
jmiller_1974
Fan#: 57165
What I Drive: a car
FF Reputation: 27 jmiller_1974 Great Standing Member
Buy-Sell-Trade Rating: (14)
Originally Posted by Blue5ive View Post
^coughing, stuffy head, runny nose and sneezing.
Haha
Originally Posted by sleepyboy View Post
Before it cause a fluctuating idle, or a high or low idle. Right now though I think it's causing my off idle lean issue and every since I seafoamed it, it's gotten better and worse. Now it almost sits there and wants to die till it kicks in and jumps the idle up and settles back down. I'm thinking it's getting suck and is probably gummed up. This is all on the Ole' Yeller' the SVT was fine after using a little tb cleaner on it. What issue are you having?
Basically exactly what you described. It is erratic, fluctuating between 800-1000 rpm and feels like it wants to die when I stop. It does it consistently but it never quite dies, happens for a few seconds and then is fine...Seems if I leave it in gear and ride the clutch is doesn't act up, only out of gear.
jmiller_1974 is offline
Old 01-26-2013, 12:25 AM   #19882
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2008 Edge SEL
FF Reputation: 32 tukaniSVT Great Standing Member
So, did you clean the TB as Paul suggested yet? Sounds like that would help with the issue.
Ray
22ND FF PHOTO CONTEST HAS BEGUN
CLICK HERE TO JOIN IN TO THE PHOTO FUN. ALL ARE WELCOME.
Hatch Nation Member: #147
TeamFocalize Head Honcho
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 01-26-2013, 12:32 AM   #19883
jmiller_1974
Fan#: 57165
What I Drive: a car
Yeah, I cleaned it about 3-4 weeks back and it helped significantly. This feels different. I've also noticed an uneven idle as it is warming up, a kind of fast surging. I will also be changing the fuel filter, as I have no idea when or if it has ever been changed. What I really need is a tune, but that's just not in my budget, yet.
Old 01-26-2013, 12:34 AM   #19884
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
That could help.
If it is surging at idle ... have you checked for any vacuum leaks. I will say one time I couldn't find my vacuum leak and it was doing that. And Paul put his finger over a spot and voila, my surging stopped. Lol. It was just a single tube that came off too ... thankfully.
Ray
Old 01-26-2013, 12:34 AM   #19885
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
I would also suggest a fuel injector cleaning. Some solution from the Auto Store will suffice.
Ray
Old 01-26-2013, 12:39 AM   #19886
jmiller_1974
Fan#: 57165
What I Drive: a car
Also not a bad idea. I wouldn't even know where to start looking for a vacuum leak, but that would make sense. My Z did the same thing and I know there were several vacuum leaks on that old beast, lol. Seafoam will be applied tomorrow. That should piss my neighbors off, hehehe
Old 01-26-2013, 12:45 AM   #19887
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
haha ... yeah.
Just don't do it too much or too often. Just once would do really. Too much can be damaging also. Since it is essentially eating away at the dirt and grime. But that doesn't mean it won't turn to your engine once it finds a good amount of dirt grime.
Ray
Old 01-26-2013, 12:52 AM   #19888
jmiller_1974
Fan#: 57165
What I Drive: a car
Very true. I suppose I should wait til after the seafoam to change the fuel filter, huh?
Old 01-26-2013, 12:54 AM   #19889
tukaniSVT
tukaniSVT's Avatar
Fan#: 5521
well, if you are not seafoaming at the fuel tank, then you should be fine.
There have been a few people who have just got the one that sprays through the intake.
Ray
Old 01-26-2013, 01:01 AM   #19890
jmiller_1974
Fan#: 57165
What I Drive: a car
Well, I figured if I'm gonna clean the fuel system I may as well clean the whole thing, from every angle. A capful through the fuel rail, and half the can in 1/2 tank of gas. I did that to my old spi and it really brought it back to life, what little life an spi has, anyhow.
