Nightly Boredom thread for the Night Stalking TX Crowd - Page 1473 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > Southern Fanatics > Fanatics: Texas
Fanatics: Texas Regional discussion Forum for planning events and sharing information with all Members in the Texas (Lonestar) areas.
Old 06-09-2012, 04:42 PM   #14721
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,543, Level 22
Points: 1,543, Level: 22 Points: 1,543, Level: 22 Points: 1,543, Level: 22
Level Up 44% Completed
FF Reputation: 4 Chris_HT Good Standing Member
thank you man for advice, I did use wd-40 on it, i used long bar with extension so I had comfortably at my arms level, but it did strip anyway, it sits super tight there, I will try the same with extractor socket, just more WD-40 and more patience.
Blue SVT 2002
Our Lady of blessed acceleration
Originally Posted by Black&Tan View Post
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
Old 06-09-2012, 05:07 PM   #14722
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
FF Reputation: 6 craigsfocus Good Standing Member
It happens. Worse case scenario, you are gonna have to cut or grind down the bolt/ stud and drill out the bolt. Use a drill bit slightly bigger than the stud so you don't break the drill bit and so you don't expand the original hole. Use WD-40 while you are drilling to ease the drilling process and save your drill bits. Make sure you hold your drill straight up and down, if you can get your hands on a Machinist Square or Carpenters Square, that will help you out a lot.
Good Luck!
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 06-09-2012, 05:17 PM   #14723
Chris_HT
Chris_HT's Avatar
Fan#: 86229
what about screwing another nut over damaged one, and welding em together?
Blue SVT 2002
Chris_HT is offline
Old 06-09-2012, 05:23 PM   #14724
craigsfocus
Fan#: 97985
I have seen people do this. But it would need a very strong weld and since you have WD-40 down you run the risk of a fire. I wouldn't suggest it.
Old 06-09-2012, 06:05 PM   #14725
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,593, Level 100
Points: 138,593, Level: 100 Points: 138,593, Level: 100 Points: 138,593, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (11)
Oh those bolts. You should be able to get it off using the above method. At least you have lots of space to work with the bolt. Sometimes they strip or break and it's in the worse place.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 06-09-2012, 07:27 PM   #14726
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
anyone got a FULL seat of seats for a Hatchback?? they do need to be grey and i dont care if they are stock..
i just to replace mine ASAP..
pm me or TEXT me (806) 281-8541
i can pay you some...lol
fhh02a is offline
Old 06-09-2012, 07:40 PM   #14727
joesperformance
joesperformance's Avatar
Fan#: 92411
What I Drive: 01 Focus SE Sedan, Zetec
FF Reputation: 3 joesperformance Good Standing Member
I like PB Blaster a ton better then WD-40....
Also heat helps break a bolt lose ALOT easier.....
but I wouldnt use heat on it, after u've done sprayed it down with WD-40, otherwise u better have a fire extigiusher handy, lol
http://www.firebirdnation.com/forums/uploads/1341751582/gallery_13330_2406_139330.png
Sedan Revolution #232
joesperformance is offline
Old 06-10-2012, 12:27 AM   #14728
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
my seat welds are broken..
fhh02a is offline
Old 06-10-2012, 03:19 AM   #14729
Chris_HT
Chris_HT's Avatar
Fan#: 86229
fuuuuuk.........
I decided that I don't want to drag you guys here again to spend long hours trying to retime my blue bitch and hoping for the best of luck, after all Paul deserves some time with his family and his own car :) So I went asking smart people (Tom) about that tensioner, and was told that if it travels a little but is not jerking around like crazy then it should be fine, especially if I already put 350 miles on it and it didn't get worse but actually a little better, and CEL never came up.
So what I did that day was:
Take off right wheel, mount and covers to turn engine by ckrankshaft a few times and see how tensioner moves, and it moved a little up and stayed there, behave good, and Tom said if it does behave good while turning by hand, just leave it as it is.
So I did, I put back all covers, replaced right mount, put the wheel back on, then went to the other side to change transmission mount but was held back by stripped nut.
By that time it was already late and I had to go to work, decided to continue next day, so i got ready to work, started up my car and already felt that changing even one motor mount reduced vibrations, so all happy set on to my short trip to work... and then I almost cried.... car had no power, CEL came up, every time I would let go of accelerator car would abruptly jerk and slow down rapidly.. yes I felt that before :(
I spent all evening at work thinking where is the fun in owning SVT, after spending all day on my blue bitch to make her happy, she is just biting back. And how is it possible that just turning engine by hand would frak the timing ?!?!?!?!?!
So I decided to get ZX3 for now to have reliable car, and later just tubo it when I want to have some fun, and the idea of getting Mitsubishi Lancer was also lurking there, very tempting.
Late at night came back home doing 30mph, swearing all the way, parked car in driveway, and decided to have a look under the hood once again before going to sleep, turned on the flashlight, looked around.... and yelled "Fuuuk" so loud all the dogs in the neighborhood started to make noise too :P
there it was.... after removing air filter box to get to engine mounts.... I forgot to plug MAF back in !!!! I almost cried again, this time feeling so happy it wasn't cam timing :D
but it made me think... "what else did I forget" after a few minutes, yep, I found another thing... I drove around with wheel lugs that I just got hand-tight while still on jack-stand, and forgot to tighten em up after i dropped the car.
ya.... i'm a noob, and lucky one i may say, aaand i still love my blue bitch :)
Blue SVT 2002
Chris_HT is offline
Old 06-10-2012, 03:36 AM   #14730
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 57%
You had my heart skip a beat when reading half way through that..
Moderator for
Technical Chat
