Go Back   Focus Fanatics > Model Specific Discussions > Focus SVT > SVT Interior Mods & Upgrades
SVT Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2002-204 SVT Focus.
Old 02-21-2010, 08:28 PM   #11
ottotroll
ottotroll's Avatar
Fan#: 63610
What I Drive: Now -2002 svt.....build #3789
FF Reputation: 4 ottotroll Good Standing Member
I put the svt seats in my 06 also..... much nicer!
ottotroll is offline
Old 03-01-2010, 08:44 PM   #12
ptruong
Fan#: 49035
What I Drive: 07 CD Silver ZX5
FF Reputation: 1 ptruong Good Standing Member
Nice, I have SVT seats in my 07. Is your airbag light on, now? The wiring is different from 05-07's...I haven't gotten around to fixing mine.
ptruong is offline
Old 03-01-2010, 11:47 PM   #13
insaneaudio
insaneaudio's Avatar
Fan#: 63306
What I Drive: 2008 SES Sedan, 06 ZX3
FF Reputation: 4 insaneaudio Good Standing Member
Nope, I swapped the plugs in my car to the svt plugs and all works, Found the howto on this site and matched everything up. My car did not have seat airbags so all I had to wire in the drivers seat was the seatbelt and seat position sensors and heat. The passenger seat was harder however, I had to swap the pressure pad from the 06 seat pan to the svt seat pan and wire it all up, otherwise my gauges would not work for some reason. So on the pass seat i had to wire the pressure sensor, heat and then swapped the seatbelt buckel from my 06 to the svt seat and wired it all to the plug.
“I believe if life gives you lemons make lemonade…then find someone that life gave vodka to and have a party.”
insaneaudio is offline
Old 03-02-2010, 03:40 AM   #14
ptruong
Fan#: 49035
Ah, interesting. Do you happen to remember where the thread/howto is on the boards? I want to wire mine up sometime soon, I don't really care about heated seats, more so about the side airbags.
ptruong is offline
Old 03-02-2010, 04:04 AM   #15
insaneaudio
Fan#: 63306
This is all thanks to mjmallon
http://picasaweb.google.com/lh/photo...eat=directlink
For the Driver seat:
svt pin 1: driver side-airbag signal: wire to driver seat harness pin 9
svt pin 2: driver side-airbag return: wire to driver seat harness pin 10
svt pin 3: not used
svt pin 4: not used
svt pin 5: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 6: heated seats switched power: wire to driver seat harness pin 5
svt pin 7: seatbelt buckle sensor signal: wire to driver seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to driver seat harness pin 4
svt pin 9: powered seat-height power: wire to constant power
svt pin 10: powered seat-height ground: wire to ground
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 5
svt pin 12: seat heaters ground: wire to passenger seat harness pin 8
svt pin 13: seat track position sensor signal: wire to driver seat harness pin 1
svt pin 14: seat track position sensor return: wire to driver seat harness pin 2
For the Passenger seat:
svt pin 1: passenger side-airbag signal: wire to passenger seat harness pin 9
svt pin 2: passenger side-airbag return: wire to passenger seat harness pin 10
svt pin 3: seatbelt pretensioner switched power: wire to passenger
seat harness pin 5
svt pin 4: seatbelt pretensioner signal return: wire to passenger seat
harness pin 6
svt pin 5: heated seats switched power: wire to passenger seat harness pin 1
svt pin 6: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 7: seatbelt buckle sensor signal: wire to passenger seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to passenger seat harness pin 4
svt pin 9: not used
svt pin 10: not used
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 6
svt pin 12: heated seats ground: wire to passenger seat harness pin 8
svt pin 13: not used
svt pin 14: not used
Old 03-02-2010, 04:11 AM   #16
insaneaudio
Fan#: 63306
oh by the way, if you are not gonna hook up the heated seats, wanna sell the bottom heating pad???
Old 03-02-2010, 03:22 PM   #17
ptruong
Fan#: 49035
insaneaudio,
Thanks...I'll look into it when it gets a little bit warmer around here. I would be willing to part with the heating pads, I really have no plans to hook them up.
ptruong is offline
Old 03-02-2010, 11:46 PM   #18
norcalfocus01
Fan#: 55603
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
The entire how to section is posted at the top of every modding topic forum. It will be under the first or second thread at each forum. Really take some time and look through there, theres a ton of really cool ideas on what to do for modding your car.
To the OP, those seats look really good, but when I read your title I thought I was going to see an entire SVT interior in a 06, kind made me sad when I didnt see it.
norcalfocus01 is offline
Old 03-03-2010, 10:05 AM   #19
Lowe9
Fan#: 69518
What I Drive: 2005 Pitch Black ZX3
FF Reputation: 3 Lowe9 Good Standing Member
When you swapped your 06 leather wrapped wheel for the SVT wheel, did you use the SVT airbag, or the airbag out of 06?
Lowe9 is offline
Old 03-03-2010, 01:38 PM   #20
insaneaudio
Fan#: 63306
Yes, the 06 air bag is on the svt wheel.
