SVT P0125 code - Page 2 - Focus Fanatics
Old 08-30-2012, 06:07 PM   #11
pak7176
pak7176's Avatar
Fan#: 65790
What I Drive: '04 InfraRed SVT ZX5
FF Reputation: 3 pak7176 Good Standing Member
Has anyone else had this problem too? My 04 SVT just started throwing this code. Before this code I had the code for spark plug misfire in bank #1. Replaced plugs and wires. A week later, the p0125 code and engine light popped on. thermostat or temp sensor? or?????
Paul G. in Sumter,SC
What I drive:
2012 Ford F-150 SuperCrew 5.0 V8
2004 Ford Focus SVT Zx5
2002 Harley Davidson Heritage Softail Classic
pak7176 is offline
Old 08-30-2012, 07:02 PM   #12
IH84DZ
Fan#: 101801
What I Drive: 03 CD silver SVT 5 door
FF Reputation: 5 IH84DZ Good Standing Member
This code means your car hasn't reached 180* or so in a specified time. It means your thermostat is stuck open 99% of the time. You could also have some resistance in the ECT sensor or wiring. More temp = less resistance with thermistors so more resistance would make the PCM think it was a lower temperature.
The sensors measure poorly in air as well so a low coolant level may cause an air bubble to form near the sensor...but these aren't difficult motors to "burp".
I only have luck with Ford thermostats. I've had two Autozone stats stick open on me. I find the oil temp runs cooler than the coolant temp when this happens. Unless I really rev the motor the oil temp always was a little lower on the gauge.
IH84DZ is offline
Old 12-24-2012, 10:38 AM   #13
spatchel
Fan#: 87816
What I Drive: 2003 SVT Focus 5 door Pitch Black
FF Reputation: 1 spatchel Good Standing Member
I just want to make sure I understand the system here. My 2003 SVT is giving me the P0125 code too. It is not running what I would call cold at just below the halfway point on the temp gauge. The thing I want to make sure of is that the sensor for the computer is the same as the one for the gauge. It appears the one on the thermostat housing is for the fan. I disconnected the sensor and the gauge did not change. I appreciate any help I can get with this. The car seems to run fine but that yellow light is something I can not deal with!
spatchel is offline
Old 01-09-2013, 03:28 PM   #14
spatchel
Fan#: 87816
I no longer have a check engine light! I had the low coolant temp code (P0125) for the last month or so. I tried three different thermostats. The last one had the water temp gauge running just below half way and that was not good enough for the computer. As a last resort I bought a Ford thermostat from the dealer and the problem is gone. The aftermarket thermostas were rated at 195 F. They were Stant and Duralast. The Ford unit has 92 C stamped on it, which is just under 198 F. My suggestion to anyone changing a thermostat is to spend the extra money on the Ford one. It was $16 versus $8.
spatchel is offline
Old 09-05-2013, 06:31 PM   #15
spatchel
Fan#: 87816
Light came back on
For 7 months after I changed to the Ford thermostat the light and P0125 code did not appear. It came on and the temp indication did seem lower than normal. I changed the coolant temp sensor and now everything is the way I remember it being and the temp levels are consistant. In my case the coolant sensor was the probably the issue all along.
spatchel is offline
