Need Help Bleeding Clutch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-06-2010, 03:38 PM   #1
M2eclectic
Fan#: 8112
What I Drive: 2002 Blue ZX5
FF Reputation: 1 M2eclectic Good Standing Member
I'm having trouble bleeding the hydraulic clutch on my 2002 Ford Focus.
I hung a bottle of brake fluid above the reservoir to create a constant flow & have no chance of introducing air bubbles.
I then attached a vacuum line to the bleeder valve on the slave cylinder bleed screw. The fluid is sucked out of the hydraulic system and into a vacuum chamber.
The brake fluid runs pretty clear but I am still getting some small bubbles.
The clutch pedal feels ok, but the car doesn't want to go into first gear or reverse gear.
I bled the brakes first, and the brake pedal is solid.
The fluid level in the reservoir is staying steady. I filled it exactly to the max-fill line and it has not lost any fluid after driving the car around town for 2 weeks.
Any ideas?
P.S. If I figure out how to upload a jpg file, I'll show you some pics of the vacuum setup.
M2eclectic is offline
Old 02-06-2010, 04:10 PM   #2
Mikeb23ft
Fan#: 42013
What I Drive: 2002 Infra Red ZX3
FF Reputation: 1 Mikeb23ft Good Standing Member
Hm. Is the throwout bearing rattling around really badly?
Un-focused :(
Mikeb23ft is offline
Old 02-06-2010, 04:45 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,456, Level 75
Points: 13,456, Level: 75 Points: 13,456, Level: 75 Points: 13,456, Level: 75
Level Up 52% Completed
Forum Activity 99%
Lubing the bleeder screw threads (I use never-seize) will reduce (or eliminate) false bubbles if you don't open it too far.
Sorry no other helpful thoughts right now...
Sounds like you are doing good bleeding job.
Oh! - did you try pumping fluid through with the pedal? (only other bleeding related thought..)
sailor is online now
Old 02-06-2010, 05:55 PM   #4
M2eclectic
Fan#: 8112
Here are some pics of the setup.
Anti-seize compound is a good idea. I use it on everything else I take apart.
I don't know about the throw-out bearing.
Old 02-06-2010, 05:59 PM   #5
M2eclectic
Fan#: 8112
did Photos go through?
http://s849.photobucket.com/albums/a...eding%20Clutch
Old 02-06-2010, 06:10 PM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Originally Posted by M2eclectic View Post
No, for photobucket you use the IMG tags instead of URL tags. The easiest way is to copy the IMG tag from the pic from PB, then come here and paste it in the thread. Now if you have the URL, use the little symbol up above that looks like a postcard, and it will insert the IMG tags for you. I'll edit this one.
If you can't get into 1, 2 or 5, R, but you can get into 3,4- then the problem is not the clutch, it's the shifter or the shifter connection to the transmission.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-06-2010, 06:12 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
Apparently swapping tags doesn't work, go back and copy the IMG version under the pic.
Be eclectic.
Old 02-06-2010, 11:21 PM   #8
MisterJohnson
M0derator Monkey
MisterJohnson's Avatar
Fan#: 51724
What I Drive: '04 ZX3 D23
Points 62,373, Level 100
Points: 62,373, Level: 100 Points: 62,373, Level: 100 Points: 62,373, Level: 100
Level Up 0% Completed
FF Reputation: 30 MisterJohnson Great Standing Member
Buy-Sell-Trade Rating: (18)
Look under your hood and check the shift linkage to make sure it's not loose and hasn't come out of an attachment point
15.07 @ 93.49 Team Duratec #149
MisterJohnson is offline
