2010 Focus SES Sedan Fusebox Location? - Focus Fanatics
Old 02-05-2010, 08:39 AM   #1
teddystacker
Fan#: 72716
What I Drive: Ford Focus Sedan SES 2010
FF Reputation: 1 teddystacker Good Standing Member
Hi All,
I just got a new 2010 Focus SES Sedan last Saturday.
Checked the manual for the Fuse box location (Says same as my old 2002 Focus, ie Behind panel , near drivers left knee under dash).
But despite me searching all under the drivers side dash with a flashlight I cannot seem to find it.
Any ideas where they moved it to in the 2010 models?
Thanks in advance..
teddystacker is offline
Old 02-05-2010, 04:23 PM   #2
2009SEL
Fan#: 66343
What I Drive: 2009 Bright Silver Metallic, SEL
FF Reputation: 2 2009SEL Good Standing Member
Teddy...,
First off, welcome to the site.
Second, nice car - similar to ours.
Thirdly, I believe I can help.
I wondered the same thing and the dealership had to help me out.
I wanted to know how to do it in case I needed to.
Look under the steering wheel.
There is a fairly large panel, it has a small panel which is the
access for the OBD (On Board Diagnostics) plug - ignore it.
You CAN get at the fuses by looking under the large panel and dash
but it easier to deal with when the panel is off.
So, for the large panel, put fingers (one left, one right)
at each of the upper two corners.
Apply gentle outward pressure, toward the seat.
The two top clips will release.
The panel will come away and pivot on the bottom two.
Then slide the panel toward the seat and out of the way and viola,
you have access to your fuse panel.
Just reverse and it'll go back in.
Try it a couple of times and you'll get used to it.
Hope this helps.
Let us know how it goes.
2009SEL
Disclaimer: it worked on ours; it could work on yours.
2009SEL is offline
Old 02-05-2010, 05:57 PM   #3
teddystacker
Fan#: 72716
@2009SEL
Thanks very much indeed for your help here..
Will give it a try as soon as I can get the 12"-18" of snow, (which we are expected to get overnight) shoveled out of the way.
Will let you know how I get on..
Regards and thanks again,
Teddy
Old 01-22-2012, 11:11 AM   #4
dwells
Fan#: 94130
What I Drive: 2010 ford focus silver
FF Reputation: 1 dwells Good Standing Member
Fuse Panel Location 2010 Ford Focus
I too am having issues locating the fuse box on my 2010 Ford Focus.
If I remove the panel as suggested there is a metal plate with four hex bolts.
I did not remove these as this seems kind of absurd to make a fuse this difficult to either check or replace.
If someone could post photos on how to find to get to the fuse box it would be ideal.
Thanks,
Dave
dwells is offline
