Do you warm your car up in Winter? Poll.. - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
View Poll Results: Do you warm your car up?
Yes 120 64.52%
No 66 35.48%
Voters: 186. You may not vote on this poll
Old 02-03-2010, 02:14 PM   #71
Executionerhk
Executionerhk's Avatar
Fan#: 55338
What I Drive: 2000 VW Passat TDI
FF Reputation: 3 Executionerhk Good Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by cdsilver02 View Post
I am still going to warm mine up...
I think I am going to do that as well.
because i do feel like cold engine sounds louder and run like crap.
Midwest Crew #23
Zetec Crew #287
Bone Stock Yellow ZX3"SOLD"
"REBORN" w/ AZFS22C Gap 0.060and Ford Racing Wire
Executionerhk is offline
Old 02-03-2010, 02:23 PM   #72
mwalsh
mwalsh's Avatar
Fan#: 56630
What I Drive: 2003 Focus ZTS | 2005 Focus ZX3
FF Reputation: 2 mwalsh Good Standing Member
I don't pre-warm modern cars - they are more or less ready to go as soon as you turn the ignition key. But older cars with a manual choke, I do pre-warm them. Because they are just so much easier to drive if you do. However, I only open the choke wide to get 'er going and then close it until the car will barely maintain an idle, to avoid having excess gas getting past the piston rings. I'll then let it sit for around 5 minutes.
mwalsh is offline
Old 02-03-2010, 11:41 PM   #73
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Originally Posted by Executionerhk View Post
this is interesting...
but cars do run a little different, a little worst when you just start it up.
how could this be explained?
i really want to know because if i buy a car. i really wanted to keep until it dies..
Cars run a little different when cold vs. warm because of machining tolerances. Heat expands, Cold Contracts. A few thousandths or ten thousandths of an inch can make a noticeable difference especially if it was in the right/wrong part/place - compression/timing.....
Machining and tolerances have gotten better and more consistent compared to decades ago, engines are tighter now. Newer cars use thinner weight oils as proof of this. Couple that with better fuel delivery, F.I. vs. carbs and you have two of the biggest reasons why.
The car was designed to run at its best when at the higher normal operating temperature, when the tolerances were the smallest - before wear widens the gaps.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 02-04-2010, 11:34 AM   #74
Executionerhk
Fan#: 55338
so a_2000_se,
will letting the car warm up until the needle of the temp. gauage moved be better off for the car in terms of wear and tear?
or driving it under 2.5K rpm is better off?
Thanks,
Steven
Midwest Crew #23
Zetec Crew #287
Old 02-04-2010, 11:33 PM   #75
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
so a_2000_se,
Thanks,
Steven
Nope. Not on a properly maintained newer car. Just a waste of gas, time, money and contributing to the pollution problem.
As long as you got good oil pressure, good fluid levels, and a daily driver (not one that's been sitting for an extended period or one that's waiting for the green light on the 'xmas tree' at the strip on a -10 F day just after start-up) you can put it in drive and drive away.
insert disclaimer here.....
60k+ miles.
Old 02-08-2010, 10:31 AM   #76
coppertits
coppertits's Avatar
Fan#: 22585
What I Drive: 07 silver MS3 gt
FF Reputation: 3 coppertits Good Standing Member
Today I sure did! Sat in there with it running for a good five minutes!
~zoom-zoom~
coppertits is offline
Old 02-08-2010, 02:24 PM   #77
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
This months issue of "My Ford" magazine explicitly asked this question of whether you need to let your car warm up before you drive it and the answer is no. This is my 2cents, but if anything, prolonging the period where your car idles with cold fluids is going to be more detrimental than getting the car moving and the engine revving some. The sooner the internals reach normal operating temp, the better. With modern cars it probably doesn't matter either way, but except for getting the interior comfortable and defrosting windows there seems to be no reason to let your car sit and idle. I think it comes down to a matter of preference, but you won't be harming your car by getting in and driving it right away.
Why would our cars idle high on cold start up if not to get the internals moving and fluids warming up faster?
6SPD_soul is offline
Old 02-08-2010, 04:53 PM   #78
coppertits
coppertits's Avatar
Fan#: 22585
Makes sense! ^
~zoom-zoom~
Old 02-08-2010, 06:08 PM   #79
brachiopod9898
brachiopod9898's Avatar
Fan#: 64886
What I Drive: 2013 Black-Pack Hatch (and a 2005)
Points 609, Level 12
Points: 609, Level: 12 Points: 609, Level: 12 Points: 609, Level: 12
Level Up 18% Completed
FF Reputation: 3 brachiopod9898 Good Standing Member
Warm it up for one to two minutes in the winter only.
Additionally, half of that time is spent in gear {ATX} with the parking brake set.
I figure it's not a bad idea to circulate the ATX fluid as well.
2005 ZX5 SES ATX
brachiopod9898 is offline
Old 02-08-2010, 06:45 PM   #80
lyonsroar
Guest
Fan#: 63166
What I Drive: 2009 Volkswagen GTI
FF Reputation: 31 lyonsroar Great Standing Member
Pshhh. That's childs play. It's 5'F here right now and it's only 5:45PM.
Coldest it's gotten this winter is -22'F. Car starts first crank, but it makes funky noises when it's that cold!
lyonsroar is offline
