How how lowering your suspension affects suspension geometry - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-27-2010, 12:37 AM   #1
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 23,955, Level 94
Points: 23,955, Level: 94 Points: 23,955, Level: 94 Points: 23,955, Level: 94
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Cool How how lowering your suspension affects suspension geometry
This subject came up in my D23 race engine build thread, so I needed to spin-off this subject to the suspension forum!
While I'm waiting to get my hands on the valve seat cutting tools from a friend, and the block is still out at the machine shop, we might as well cover this whole suspension drop issues and how it impacts the suspension geometry. There are tons of books and internet references to this, but I'll take a stab at it on my own here.....
Here's why lowering a Focus (or any car)can "tamper" with the suspension geometery, and specifically its impact on camber.
FYI -
Camber is the tilt of the top of the tire as viewed from above, tilt the top outwards for positive camber, tilt the top inwards, you have negative camber.
Camber "gain" is the change created in this angle as the suspension moves through it's range motion. If the top of the tire angles outwards as the suspension compresses, this is "positive camber gain", and when the top of the tire angles inwards, this is "negative camber gain".
Ususually you want to have a "negative camber gain" as the vehicle rolls onto the outer wheels and compresses the suspension, to help offset the body roll and keep the tire sitting a flat as possible.
if the LCA on a mac strut car is angled down when static, (like it is on our Foci) as the car turns, rolls and compresses the suspension, the LCA swings through an arc that moves the Lower Ball joint a small distance in the outwards direction. This changes the angle of the strut/spindle/wheel increasing Negative Camber. (I.E. Negative Camber Gain)
If you drop the suspension so the LCA sits horizontal when static, as the car turns, rolls and compresses the suspension the LCA will continue to swing through it's arc. But it is now moving the ball joint inwards as the arc is curving up and inwards away from its static horizontal position. As the ball joint is moving towards the center, so is the lower portion of the tire. This causes the top of the tire to angle away from the car producing "positive camber gain" making it more difficult to keep the tire flat on the track.
as wrc_fan suggests, most drivers will never worry about the little differences with these dynamic angles etc, but on the track or autocross its as important as having a few points more of horsepower.
While you can just crank up the static camber to an extreme negative number to keep the tires flat on turns, this dramatically reduces your braking abilities, and can make it difficult to keep tire temps where you want them. It also affects your ability to put power down mid corner becuse the inside tire is just touching on a small area on the inside edges of the tread.
Our simple single LCA and strut design of the front suspension does not offer any "tricks" of geometry provided by more advanced multi-link front suspension like seen on honda, acura, BMW, and countless other cars that have moved on from a simple strut design. So the best you can do (when allowed by the racing class) is raise the inner pivot points to set the LCA in a slight "droop" condition when sitting at static ride height. This helps recover that little camber gain effect as the suspension rolls and compresses the suspension so the LCA is horizontal when the turn/roll/compression is at it's peak, and you get the most camber gain possible.
This allows a milder static camber adjustment, producing better braking effectiveness/stability, and a bit more rubber in contact with the track on the inboad wheels to help power out of a turn.
And all of these benefits help keep tire temps more uniform etc.
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is offline
Old 01-27-2010, 12:48 AM   #2
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
Excellant write up. Stickied
norcalfocus01 is offline
Old 01-27-2010, 12:56 AM   #3
tb1999
tb1999's Avatar
Fan#: 44261
That didn't take long! Thanks......
tb1999 is offline
Old 01-27-2010, 01:17 AM   #4
norcalfocus01
Fan#: 55603
How do you move the pivot points on the front LCA?
Old 01-27-2010, 09:31 AM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Sure makes a lot more sense when you explained it here. Nice.
jetrinka is offline
Old 01-27-2010, 10:14 AM   #6
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Nice writeup! I love hearing from people that knows what they are tallking about. Unless of course your copy and paste skills are as good as mine....
Posted via FF Mobile
scrammer is offline
Old 01-27-2010, 10:44 AM   #7
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,581, Level 37
Points: 3,581, Level: 37 Points: 3,581, Level: 37 Points: 3,581, Level: 37
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 23 wrc_fan Great Standing Member
One other thing to note is that the body roll of a vehicle also adds positive camber to the outside tire while you are in a turn. So we have suspension compression and body roll contributing to the camber angle of the tire.
Stiffer sway bars can help to reduce this body roll impact, but the tradeoff is lift up and spin of the inside front tire on corner exit (even with a torsion style differential) from the weight transfer by the sway bars. Stiffer springs can help reduce the body roll, but you can compromise suspension motion.
Long story short, suspension modification is a constant battle of trade-offs.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 01-27-2010, 07:35 PM   #8
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,359, Level 47
Points: 5,359, Level: 47 Points: 5,359, Level: 47 Points: 5,359, Level: 47
Level Up 5% Completed
Forum Activity 5%
FF Reputation: 35 thenorm Great Standing Member
I've been dealing with these tradeoffs too. my car is quite low, probably too low, but it looks good dammit.
My plan to deal with the loss of camber gain was huge static camber. I bought LCR plates to do this. I found, as you mentioned above, that i had lost too much acceleration and braking traction.
My solution was to swap the camber plates from driver to passenger (and vice versa) and rotate 270. What this did for me was to give me enough negative camber adjustment for my needs, but also gave me appeciable castor.
So now, when i auto-x. i have good straight line accel and braking, and when i corner, the castor provides more camber than I lose through the position of the control arm.
win-win in my opinion.
I dont have any alignment printouts from this setup, because I do my alignments (mostly toe adjustments) in my driveway, and now I'm on my winter springs. So in the spring when i go back to coilovers and LCR's. i can put it on a rack and let you know.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 01-27-2010, 11:08 PM   #9
ChrissyL
Trying to Focus
ChrissyL's Avatar
Fan#: 64813
What I Drive: '13 Performance Blue ST3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 13 ChrissyL Great Standing Member
A good, clear discussion. Well worth the sticky. Thanks, and rep given!
All my relations, Christine
NW Posse #17
"Straight roads are for fast cars. Curvy roads are for fast drivers."
ChrissyL is offline
Old 01-28-2010, 01:17 PM   #10
Auto-X-ZTS
Fan#: 54278
What I Drive: 2000 ZX2 S/R
Points 318, Level 6
Points: 318, Level: 6 Points: 318, Level: 6 Points: 318, Level: 6
Level Up 36% Completed
FF Reputation: 7 Auto-X-ZTS Good Standing Member
The reason MacPherson strut equipped cars have this problem is because the angle of the lower control arm relative to the chassis changes as you lower the car. Lower too far and the arm tilts the "wrong" way (up), lower on the chassis side and higher on the strut side--and the rolling of the car has a greater mechanical advantage on the strut causing it to compress the spring easier as the weight shifts to the outside. That change in geometry is what changes the roll center.
When you lower a car with MacPherson struts the roll center lowers farther/faster than the CG. So if at the stock height the roll center is, for example, 4 inches below the CG, when you lower the car 2" the CG drops 2" but the roll center drops say 6". The actual tendancy of the car to lean during cornering then increases. To counter that tendency you need MUCH larger springs. Not ordinary lowering springs in the 200-400lb range--but 500-600lb race springs.
"If you can imagine picking up a barbell with a weight on just one side---if you pick it up close to the weight it's easy to lift/handle, but if you pick it up at the opposite end of the weight (which is a great forearm workout) it becomes more difficult as you lose mechanical advantage. The length or arm length creates a greater "polar moment of inertia" (distance from roll center to Center of Gravity). So with stock geometry your CG and roll center are close together (like grabbing the bar next to the weight which requires less effort or less springrate to control the roll) but as you lower the car the roll center drops quicker than the CG creating more mechanical advantage (makes the car top heavy)/longer arm/requiring more spring rate"---like I said above, quite a bit more.
Here is a good illustration:
http://www.modified.com/tech/0508_sc...t_3/index.html
Here is a real-world example http://buildafastercar.com/tech/Roll-Centers : ...go back to the example earlier where we found that lowering a Subaru WRX STI drops the front roll center by 2.6 times as much as the chassis height (which also means 2.6 times as fast as the chassis's center of gravity). As it turns out, a one-inch lower ride height actually increases the vehicle's roll couple by about 18%, which means body roll will also increase by 18% unless firmer springs are used to resist this force. The springs would need to be 18% firmer just to maintain stock-like chassis roll numbers. Again, that's 18% just to break even!
Erik B.
(_/\_-Head)
www.waiautox.org
___/\_____/\_____/\_____/\___
Auto-X-ZTS is offline
