HOW TO: IMRC Removal and Repair - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2011, 01:59 AM   #61
bostonman
Fan#: 83471
What I Drive: 2003 silver focus SVT
Points 24, Level 1
Points: 24, Level: 1 Points: 24, Level: 1 Points: 24, Level: 1
Level Up 47% Completed
FF Reputation: 1 bostonman Good Standing Member
Fixed my IMRC... difference story
I took my IMRC out and found the problem and fixed and got my inspection sticker.
This is how I fix the circular crack problem found.
bostonman is offline
Old 06-11-2011, 04:49 PM   #62
spvensko
Fan#: 68819
What I Drive: 2004 Red SVTF
FF Reputation: 1 spvensko Good Standing Member
Nice guide! I was following it but unfortunately got stuck. I was able to remove the headlight, upper portion of the air filter box and even get the end of the cable from the lever but got stuck once I realized that I couldn't remove the cable from the bracket next to the lever. It appears it's supposed to slip off the side but I couldn't get it to slip off. I tried spinning it, thinking maybe I had to unscrew something but that didn't work. I also just trying to slip it off using light force but it didn't seem to budge and I didn't want to break anything.
Any tips?
spvensko is offline
Old 06-11-2011, 05:14 PM   #63
Joshuasvt
Joshuasvt's Avatar
Fan#: 27135
What I Drive: '03 Black/Red Flake SVT #1218
Points 3,105, Level 34
Points: 3,105, Level: 34 Points: 3,105, Level: 34 Points: 3,105, Level: 34
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 3 Joshuasvt Good Standing Member
All I can tell you is to keep trying. It does slide out but it is a PITA!
-JT
Joshuasvt is offline
Old 06-11-2011, 05:24 PM   #64
spvensko
Fan#: 68819
Is there something I need to do to loosen it up? I may try spraying some WD40 on it and letting that sit for a bit to see if it helps. I can twist the cable within the bracket so I know it's not stuck that way. When I tried pulled on it I could tell the entirety of the intake manifold was moving around a bit so I didn't want to force it. Thanks for the insight!
spvensko is offline
Old 06-11-2011, 05:37 PM   #65
Joshuasvt
Joshuasvt's Avatar
Fan#: 27135
Originally Posted by fast_ryda View Post
Is there a way to fake it or disable?.
Ask my Ex-Wife, she could do both!. Sorry guys couldn't resist, haha
-JT
Old 06-11-2011, 07:40 PM   #66
bostonman
Fan#: 83471
Points 24, Level 1
Any tips?
I found the removal of the wire clip is the worst part of the repair.
I forced it out and thought I broke the cable but I was lucky. The wire end clip is made of nylon and didn't break:
This is how the cable end look:
I found the right way to remove it, is by either:
1. you can push the nylon head in -OR-
2. rotate the cable until the slot head aligned with the holder bracket and you should be able to slip off through the side.
Good luck.
Tat
2003 SVT-Focus
Old 06-11-2011, 09:02 PM   #67
spvensko
Fan#: 68819
Good luck.
Tat
2003 SVT-Focus
Exactly what I needed, thanks a bunch!
spvensko is offline
Old 06-17-2011, 05:36 PM   #68
LOADED
LOADED's Avatar
Fan#: 81895
What I Drive: 2003 Sonic Blue SVT Focus
Points 1,922, Level 26
Points: 1,922, Level: 26 Points: 1,922, Level: 26 Points: 1,922, Level: 26
Level Up 22% Completed
FF Reputation: 1 LOADED Good Standing Member
I hooked up my scanner before i got my tune and no codes and after i loaded my tune i scanned it again and it said my SVT Intake Manifold Runner Control was stuck open?
I don't have a CEL. should i worry about it?
2003 Sonic Blue SVT Focus #524
LOADED is offline
Old 06-21-2011, 03:58 PM   #69
spvensko
Fan#: 68819
I managed to get my IMRC box out and take it apart. I didn't trust my soldering skills to completely disassemble it but I was still able to sneak the sand paper into the crucial contact spot. After cleaning and reassembly, my CEL is gone (or at least has been since Sunday.) The exhaust note is back to normal, my torque has doubled and I finally love my SVT again. Thanks again for everyone's help!
spvensko is offline
Old 06-21-2011, 06:46 PM   #70
mySVT
mySVT's Avatar
Fan#: 5557
What I Drive: 2013 Ingot Silver ST
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 1 mySVT Good Standing Member
Ok, so I wanted to wait a little while before posting results, but I finally broke down (not literally) and replaced my IMRC. I just bought a new one from Tousley and installed it myself. Pretty easy job, only removed the airbox to disconnect the cable, then went in from underneath to swap it out. I reset the CEL and so far, after about 600 miles, the light has not returned. I think my MPGs are better, but it's kinda hard to tell since I ran in an autocross last weekend... I'll keep you posted.
So if anyone wants a slightly bad IMRC to try to take apart and fix, I've got one I'll sell pretty cheap. That way you can try the fix without disabling your car in the process.
SVT SQUAD #12 '13 Silver Focus ST3, moonroof
Old: 03 Silver SVT ZX5 #1459/2173, HIDs, Moonroof, Audiophile. Mods: Hawk pads, Waynes Tune, K&N filter
Older: 02 Silver ZX5 Premium, Leather, Moonroof
mySVT is offline
Tags
dsi imrc
