HOW TO: IMRC Removal and Repair - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-02-2013, 06:59 PM   #111
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Thanks for the great write up. Had the cel popping up till it came on all the time. Pulled the imrc today, didn't desoder anything just took screws out and used a screwdriver and sand paper to get between the contacts. Didn't get to test drive it yet but when I started it the manifold was pulled closed and the cel was off. Hopefully stays off for a good while.
I now drive a Japanese Ford.
macdiesel is offline
Old 05-06-2013, 03:31 PM   #112
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
My fix did not work. I did this back in Nov. resoldered the joints, cleaned the contacts and put everything back. got the CEL within a day. I'm getting ready to get a used one from a pull a part to see if it really fixes it before I try a new one. I hear that several other models use the same box with different cable legnths that will swap right in. I know of a couple of guys who installed a new IMRC to only have the code come right back.
mine pulls the lever at start up then releases after a few seconds. then the code comes right back if I reset it.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 06-25-2013, 08:42 PM   #113
bbcobra
bbcobra's Avatar
Fan#: 88400
Points 430, Level 8
ok, I can verify that a IMRC from a cougar (99-02) is the same as the focus. The cable is slightly longer (2 to 3 inches). I just put one on mine and it has fixed my issues. The old IMRC actuated the lever slowly then snapped back to the long runner position after starting and I think this was the whole problem. Probably a timing issue in the activation of the IMRC circuit. The replacement box actuates much quicker and holds there just like it's supposed to. Taking off is so much better with the added touque on the low end now.
bbcobra is offline
Old 06-25-2013, 08:54 PM   #114
DarkSVT03
DarkSVT03's Avatar
Fan#: 104226
What I Drive: 2003 black SVT focus
FF Reputation: 2 DarkSVT03 Good Standing Member
Sweet ^^^^*
I'm buying one off a 99-02 cougar since its cheaper then the oem one :) thanks!!
DarkSVT03 is offline
Old 06-26-2013, 05:37 PM   #115
DarkSVT03
DarkSVT03's Avatar
Fan#: 104226
Just bought the imrc. I'll let you know how it goes
Old 07-02-2013, 09:31 PM   #116
macdiesel
macdiesel's Avatar
Fan#: 31579
Went oem and no more cel light since installing
Old 07-03-2013, 07:17 AM   #117
bbcobra
bbcobra's Avatar
Fan#: 88400
Points 430, Level 8
Mine is good to go now. my gas mileage has also picked up some too.
bbcobra is offline
Old 01-11-2014, 09:51 PM   #118
dman25
Fan#: 95916
What I Drive: 2000, Red, SVT Lightning
FF Reputation: 1 dman25 Good Standing Member
this didnt work for me =( im gonna have to buy a new box, thanks for the write up though, it really helped!
dman25 is offline
Old 01-12-2014, 08:45 AM   #119
termi-on
Fan#: 118731
What I Drive: 2003 cobra, 2003 svtF
FF Reputation: 1 termi-on Good Standing Member
Thank you for the write up
termi-on is offline
Old 05-07-2014, 02:58 AM   #120
Fierceintent
Fierceintent's Avatar
Fan#: 117556
What I Drive: 04 infra red Svt, 03 2.3 red sedan
Points 499, Level 9
Points: 499, Level: 9 Points: 499, Level: 9 Points: 499, Level: 9
Level Up 98% Completed
FF Reputation: 1 Fierceintent Good Standing Member
Changed my imrc today and it made a difference. Only problem I encountered was trying to remove the air box, Make sure to just pull really hard straight. I thought it was bolted. Also getting the old cable off the plastic, I just got some pliers and broke the tabs. Gas milage is up. Thanks for write up!
Fierceintent is offline
Tags
dsi imrc
