Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 11-17-2012, 08:12 PM   #101
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
FF Reputation: 1 bbcobra Good Standing Member
I decided to finally fix mine today. Had it out and took the cover off. I have the cracked solder joints so I go looking for my solder iron. After searching for 2 hours I gave up and put the intake and battery back in. I guess I'll take the module with me to work Monday and get it finished. I'll just take it apart again next weekend.
I may also take that weight off of the trans. linkage while I'm in there and see how that feels.
2003 SVT Focus, Competition Orange, EAP. Cervini's 1 piece rear spoiler, Eibach sway bar kit, Steeda Springs, K&N filter, steeda shifter, VF Engineering lower motor mount.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 11-18-2012, 01:42 AM   #102
DarkSVT03
DarkSVT03's Avatar
Fan#: 104226
What I Drive: 2003 black SVT focus
FF Reputation: 2 DarkSVT03 Good Standing Member
Ok so my SVTf runs like ass some days and runs great other days. I have 139k on mine, and I was wondering if this could be the issue? No cel, but I believe I did get the code once last month, but it went away. Some days I have great torque, and other days I have nothing. I work at Oreilly auto parts, so the imrc is cheaper for me. Would it be worth replacing? I can't solder or I would try and take a look.
DarkSVT03 is offline
Old 11-18-2012, 09:10 AM   #103
MDCalvert
MDCalvert's Avatar
Fan#: 87161
What I Drive: 2002 ford focus svt
FF Reputation: 1 MDCalvert Good Standing Member
Seems most likely to be it. I would still take it apart and look around its not to hard at all to do. You can always find a friend to solder for you. Also big thing is the copper contact point can be dirty and be making it run funny. Be yes I would replace it if not taking apart lol.
MDCalvert is offline
Old 11-19-2012, 02:00 AM   #104
jimmy03svt
Fan#: 105918
What I Drive: black 03 5 door
FF Reputation: 1 jimmy03svt Good Standing Member
have a p1518 code pop up today..car still runs perfect no change in idle or power, also i cant where to get the imrc module(the box?). what is the dsi clip? and the scanner says nothing but p1518. i see many different explanations for it but im not sure how the component works so anyone who can explain it? thanks!
03 focus svt..stock
jimmy03svt is offline
Old 11-21-2012, 10:30 AM   #105
jvert
jvert's Avatar
Fan#: 80613
What I Drive: 2004 Red ZX5 SVT
FF Reputation: 1 jvert Good Standing Member
03 focus svt..stock
I got the same code and just orderd my IMRC from Steve at Tousley Ford. My car too is stock and I have not noticed any loss in power or mpg's.
2004 Red ZX5 SVT #132 of 1079
jvert is offline
Old 01-05-2013, 04:51 PM   #106
jvert
jvert's Avatar
Fan#: 80613
Finally fixed. Great write up!,,
jvert is offline
Old 02-02-2013, 08:50 PM   #107
stanger19899ddr
Fan#: 100097
What I Drive: 01 zx3, 2002 SVTF, 2004 Silver euro
FF Reputation: 1 stanger19899ddr Good Standing Member
Focus SVT IMRC
This is a great post
My SVT was getting the dreaded IMRC check engine light when I found this post
Figured I would try to fix my module today after I retuned from the salvage yard.
I found a unique thing today I think
While I was walking around I found a duratec 24 valve engine in and decided to look inside the IMRC Module The 99 and new have the short cable.
Took the screws loose fo the circuit board Wiggled the connector and the circuit board and the motor are easily removed.
Turned the gear with the cable on it and the cable slid out. It even had the same number on the box as my 02 foocus SVT. YOu can clean the contact and whatever else you need to do and dont have to unsolder anything.
ALSO found out a 96 Contour duratec 24 valve V6 engines module is a dirct replacemnt for the SVT. Just put one in mine and cleared the light
WORKS GREAT...
stanger19899ddr is offline
Old 02-04-2013, 08:53 PM   #108
IH84DZ
Fan#: 101801
What I Drive: 03 CD silver SVT 5 door
FF Reputation: 5 IH84DZ Good Standing Member
Got a P1518 at 108K miles a few months ago when winter hit. Cleared it immediately - never had a driveability symptom so it was obviously an intermittent problem...until recently when it would come back within days... Saw the thread and decided to actually try and fix it instead of buying a new module.
It was pretty easy - thankfully I had a sharp soldering iron to keep hot spots small and it was interesting getting the holes in the IC board free from solder so I could align the connector pins... a little patience was the key.
48 hours later still no code. Thanks for the good writeup
IH84DZ is offline
Old 02-28-2013, 11:16 PM   #109
AlfPrev
Fan#: 104347
What I Drive: car
FF Reputation: 1 AlfPrev Good Standing Member
I did this fix to two separate IMRC actuators and fixed one. 50% aint bad, good tips
AlfPrev is offline
Old 02-28-2013, 11:45 PM   #110
stanger19899ddr
Fan#: 100097
IMRC fix still working
After a couple weeks the IMRC Is working great
NOW
I just need to figure out the last problem
A CODE 13 flashing AIRBAG Light
Had the AIrbag module re set , VIN put into the RCM and still a code 13, ANy thoughts.
Tags
dsi imrc
