HOW TO: IMRC Removal and Repair - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2010, 07:09 PM   #1
SVT_ME
SVT_ME's Avatar
Fan#: 53618
What I Drive: '02 Ranger XLT- '08.5 MS3 GT
FF Reputation: 7 SVT_ME Good Standing Member
First off, credit for this idea goes to an older thread which now seems to be gone. I'm just going into slightly more detail.
This problem is very common, and I suspect 80% of SVT owners need not replace the IMRC but simply clean the internal contacts.
So, do you have this problem? If you answer "no" to the following, it is 90% likely this procedure will work for you:
1) Is my cable broken?
2) Is my lever broken?
What you need:
1/4in ratchet with 8mm & 10mm sockets
Phillips screw driver #1 & #2
Soldering Iron
Thermal paste
RTV
Ok, lets begin.
First, remove the drivers side headlamp, battery, battery tray, and airbox/uper half of CAI/SRI:
You see that the IMRC is located behind the headlamp.
Now, before unbolting the IMRC box, disconnect the cable from the lever. This is done by (with one hand) roatating the lever towards you, while grasping the end of the cable and sliding it off of the post.
Now, unbolt the box and remove it while snaking the cable out along the path shown.
Ok, the hard part is done
Next, take the IMRC to your bench to begin disassembly.
First, remove screws securing cover. Then using a straight razor blade cut around the seam to free the RTV.
Now that the unit is open, remove the screws as shown, and desolder the power wires and connector pins.
Remove PCB, and this is what you have.
At this point you will notice, there is not much to this box. Notice the gears are made of metal, thus the odds they will ever strip is very slim. The electrical circuit is very simple as well, and failure of these components under normal operation is slim to none. The motor is nothing more than a glorified coil, and under normal operation coils are basically indestructable.
Leaving us with the true weak point of this unit... the contact Which is the copper strip with a nickel plated contact shown in the above picture.
Now, to remedy the dreaded P1518, we must burnish (clean) said contact.
Notice the grey color. This is not very condusive to conduction.
Using a piece of fine grit sand paper (paper), or a fine nail file (file), press down gently on the copper strip (DO NOT BEND COPPER STRIP),
Insert paper/file, release copper strip and pull paper/file out. DO NOT MOVE BACK AND FORTH, SIMPLY PULL.
Repeat 3-5 times, and marvel at your new looking contact.
Now, before you reasemble the box, make sure your FET has enough remaining thermal grease to dissapate heat properly... In my case, I wiped it away and used thermally conductive gap pad.
Add thermal grease if you need to.
Now reattach the PCB the reverse of removal.
Using standard RTV, run a bead around the edge and screw the cover back on.
Bolt up the box to its bracket and run the cable along the same path you took it out of. BE SURE TO RUN THE CABLE INTO THE GROOVE BEHIND THE BATTERY TRAY, SO THAT WHEN YOU PUT THE TRAY BACK IN YOU DO NOT SMASH THE CABLE.
Hook up the cable end to the lever post by rotating the lever towards you and sliding the groove of the cable end on to the post.
Replace airbox/upper half CAI/SRI, battery tray, and battery.
Hook up battery... Start car... and enjoy your engine codeless dash
I'm sure I forgot something, I will edit as I remember things or get suggestions from other members.
Originally Posted by HGFireHazard View Post
Truthfully, the only person I really trust to work on my cars is me. I know when I do something right and I know when I do something wrong...
SVT_ME is offline
Old 01-26-2010, 11:33 PM   #2
SVTRSST
70 100 70 70 : (
SVTRSST's Avatar
Fan#: 50439
What I Drive: 2003 Sonic Blue SVT Focus
Points 8,570, Level 62
Points: 8,570, Level: 62 Points: 8,570, Level: 62 Points: 8,570, Level: 62
Level Up 40% Completed
FF Reputation: 16 SVTRSST Great Standing Member
Buy-Sell-Trade Rating: (10)
very nice! thats what i was thinking how can this stupid system fail?!, i need to remove the little chip though..
any kind of grease we should use with the gears?, can the motor ever fail?
'03 SVT
0381 of 3985
SVTRSST is offline
Old 01-27-2010, 09:56 AM   #3
LongDucDong
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
FF Reputation: 10 LongDucDong Great Standing Member
Nice write-up!
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
Old 01-27-2010, 12:20 PM   #4
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,173, Level 41
Points: 4,173, Level: 41 Points: 4,173, Level: 41 Points: 4,173, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I remember the original write up. I thought the guy cleaned/lubed the gears up too. Nice write up.
I now drive a Japanese Ford.
macdiesel is offline
Old 01-27-2010, 01:37 PM   #5
SquirrelZX3
your killing my fun
SquirrelZX3's Avatar
Fan#: 34544
What I Drive: 1995 shitbox neon red
FF Reputation: 18 SquirrelZX3 Great Standing Member
nice write up but so far my svt seems to be operating just fine but good to know if i have any future problems
United States Army Honorable Discharge
Attending UTI and driving a pos beater mopar
SquirrelZX3 is offline
Old 01-27-2010, 05:34 PM   #6
RyersonUnit
Fan#: 55742
What I Drive: 2002 Sonic Blue SVT Focus
FF Reputation: 1 RyersonUnit Good Standing Member
Thank you so much!! This answered all my questions! Woot...saves me like $500CDn
Adam
RyersonUnit is offline
Old 01-27-2010, 05:39 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
It's right there in the "New Members Read Here First. SVT Performance Chat "Read First" Threads."
(in the "SVT Specific: How To and Information Links")
"How To" Intake Manifold Runner Control disassembly"NEW"
Regardless, thanks for the more in depth write up.
WD40 is offline
Old 01-28-2010, 12:54 PM   #8
SVT_ME
SVT_ME's Avatar
Fan#: 53618
Thanks for the heads up WD
Odd, I clicked the original link and it didn't work...
Anyway, now there are 2.
SVT_ME is offline
Old 01-31-2010, 06:18 PM   #9
SVTROADRACER
Fan#: 72581
What I Drive: 02 silver svt
FF Reputation: 1 SVTROADRACER Good Standing Member
Nice write up!! My only question is, do i still need to remove my battery with it being in the trunk? J/K!!
SVTROADRACER is offline
Old 01-31-2010, 06:32 PM   #10
tczx3
tczx3's Avatar
Fan#: 48551
What I Drive: 2002 ZX3 (SVT Eng/Tran), 2002 SVTF
FF Reputation: 32 tczx3 Great Standing Member
Buy-Sell-Trade Rating: (8)
As a side note to possible failures... If you have the 'marbles in a coffee can rattle' at start up the problem is the plastic pulley that the cable attached to inside the IMRC. See pic #9. The shaft that turns the pulley can strip the engagement pin on the pulley. If you open up your IMRC and have plastic shavings the pulley is toast and unrepairable. In my case this failure was caused by a faulty DSI manifold. The runner that rotates inside the manifold was beginning to 'sag' from the pivot points wearing and the runner was catching/binding causing the pulley in the IMRC to fail. I suspect the runners catching and binding is the actual cause of the broken DSI clip that so many experience.
2002 ZX3SVT SVT engine/trans conversion w/ SVT guages, headlamps, front grille, bumpers, 17" Euro, Hankook Ventus V12, AEM CAI, Borla
2002 SVTF Infra Red! Stock w/ Dual oulet exhaust and rolling on Proxes 4
2002 SVTF Pitch Black-Dad's new ride!
tczx3 is offline
Tags
dsi imrc
