PATS Bypass? Ford Bypass Kit? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-23-2010, 06:44 PM   #1
Dan-O
Dan-O's Avatar
Fan#: 50029
What I Drive: 2002 FrankenTurbo powered Beetle
FF Reputation: 13 Dan-O Great Standing Member
Buy-Sell-Trade Rating: (26)
Has anyone used the OEM Ford PATS bypass with a remote start? I'm looking for some input.
I'm attempting to bypass the PATS and I bought a Code Alarm PKU-F1 but I can't make it work.
I went in with the IDS and made sure the allow extra keys PID was enabled. I do have two keys and I'm sure I'm programming it correctly.
I need to get a more robust solution that is solid and reliable.
I found the Ford PATS bypass for $15 and was wondering if anyone had used it or should I just go with an ADS TB kit?
Thanks for the input.
There's no replacement for displacement...
Yeah, there is: Boost!!
Dan-O is offline
Old 01-24-2010, 04:50 AM   #2
daidie
daidie's Avatar
Fan#: 70867
What I Drive: 2003 maroon red 3 dr hatchback(zx3)
FF Reputation: 7 daidie Good Standing Member
just mount the transponder from one of the keys into the casing surrounding the ignition barrel, just make sure the alarm system you are using with the remote start has an immobiliser included.
red focus zx3, stainless from cat back, the big 3, k&n, anti carjack mod, in dash dvd with jbl sub and custom 5x7's, ghia interior light mod.
have you repped someone helpful today
daidie is offline
Old 01-24-2010, 08:04 AM   #3
Dan-O
Dan-O's Avatar
Fan#: 50029
I appreciate the input, but I'm looking for specific input from someone with experience with the Ford unit.
I used to have the transponder already mounted to the column.
The transponders don't always like the cold weather, that's why I'm looking for a different solution.
I'm also eyeballing an ADS unit.
Dan-O is offline
Old 01-24-2010, 08:16 AM   #4
andrewjay84
Fan#: 61141
What I Drive: 2012 RAM 1500 Sport
FF Reputation: 6 andrewjay84 Good Standing Member
Buy-Sell-Trade Rating: (8)
Have you thought about using a DEI PKFM or DEI PKALL? Both modules use data instead of using an rf antenna ring. 2 keys required for programming.
What is the oem bypass like? Is it the bypass that consists of a micro relay and has an embedded PATS chip in it?
andrewjay84 is offline
Old 01-24-2010, 08:25 AM   #5
Dan-O
Dan-O's Avatar
Fan#: 50029
I'm don't know what the Ford unit is.
Found it in the parts catalog on-line.
I agree on the data route. The ADS unit is a data unit too.
Dan-O is offline
Old 01-24-2010, 08:37 AM   #6
andrewjay84
Fan#: 61141
I think the oem is similar to what I described...it has an embedded chip that has to be programmed and installed near the antenna ring of the factory PATS module. I would fully recommend data connection. No problems when it gets cold outside.
Code Alarm products are horrible. I wouldn't wish those on anyone I know.
And if the ADS unit your referring to is the idatalink, its the same technology as the DEI Xpresskits, so pick up whatever is a better deal.
Old 01-24-2010, 09:16 AM   #7
Dan-O
Dan-O's Avatar
Fan#: 50029
Yup the ADS-TB is a data unit.
I found one for like $20 or so.
Dan-O is offline
Old 01-24-2010, 05:03 PM   #8
andrewsfm
andrewsfm's Avatar
Fan#: 70099
What I Drive: 2008 Ebony ATX SES w/ Leather & Sun
Points 1,719, Level 24
Points: 1,719, Level: 24 Points: 1,719, Level: 24 Points: 1,719, Level: 24
Level Up 19% Completed
FF Reputation: 5 andrewsfm Good Standing Member
This is what you need...
http://cgi.ebay.com/PKFM-DEI-XK04-Xp...item4ced3f8925
...and it's also what I use on my 08.
This particular seller I've bought an alarm sensor from before with no issue.
DEI 2-way Alarm & Start / DDM Ballasts + CAP 6000k 55w HIDs in Eagle Eyes Projectors / 6000k 55w HID Fogs / All INT+EXT LEDs+7W LED Reverse / K&N Air Filter / Kumho Ecsta 4X Tires / 35%/20% Tint / Black Grille / Maxxsonics MX-1 + 2500W Stereo
andrewsfm is offline
Old 01-24-2010, 06:34 PM   #9
Dan-O
Dan-O's Avatar
Fan#: 50029
I ended up grabbing an iData ADS-TB unit for $20.
Same idea as the one you posted.
I learned my lesson about cheap, not inexpensive, but cheaply made bypass units.
Thanks again for the input everyone.
Dan-O is offline
Old 01-25-2010, 03:53 PM   #10
mkc70
Fan#: 66596
What I Drive: 1999 silver C70
FF Reputation: 1 mkc70 Good Standing Member
Finally went with the good unit. Ford OEM unit was made by Code.
mkc70 is offline
