SCT Datalogging issues PLEASE POST - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-21-2010, 11:32 AM   #81
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,359, Level 29
Points: 2,359, Level: 29 Points: 2,359, Level: 29 Points: 2,359, Level: 29
Level Up 40% Completed
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Originally Posted by disciplerocks View Post
The only problem I have had is connection issues in cold weather. I usually just bring it in and sit it by furnace vent for a minute.
Now if it only worked with windows 7 now that would be sweet!
Livelink 6.1 works fine with windows 7.
Blivit is offline
Old 04-21-2010, 11:36 AM   #82
Blivit
Blivit's Avatar
Fan#: 51292
Originally Posted by 1turbofocus View Post
The returnless system of the o8 and up has the same type cannister and a fuel rail psi sensor just like the early years , The ECU is getting a reading of fuel psi from somewhere because I saw this on a Ford scan tool , whats changes that makes the o8 Diff from the o9 or o7 ? If Ford can read and the ECU read this signal why cant SCT read it ?
Ford physically changed the processor from 07 to 08 then changed it again from 09 to 2010. One of the reasons for this may have something to do with the control of the fuel system.
The 2010 may be different but I am looking at one now. There is no sensor anywhere on the fuel rail. IDS does not log anything fuel pressure related on this car.
Blivit is offline
Old 04-21-2010, 12:30 PM   #83
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,526, Level 100
Points: 52,526, Level: 100 Points: 52,526, Level: 100 Points: 52,526, Level: 100
Level Up 0% Completed
Forum Activity 63%
Activity: 63% Activity: 63% Activity: 63%
Buy-Sell-Trade Rating: (28)
There has to be a sensor somewhere ? Otherwise it would have to be a full manual return fuel system and the ECU have no controle over the pump correct ?
The 2010 Fuel pump ,what I understand is still controled by the ECU no?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-21-2010, 05:21 PM   #84
disciplerocks
GT40 all the things!
disciplerocks's Avatar
Fan#: 59330
What I Drive: 04 ZX3, 12 Hatch
Points 13,460, Level 75
Points: 13,460, Level: 75 Points: 13,460, Level: 75 Points: 13,460, Level: 75
Level Up 53% Completed
FF Reputation: 13 disciplerocks Great Standing Member
Buy-Sell-Trade Rating: (17)
Really! Sweet! I have not checked for updates since I got the thing lol. Now I can use it on my new laptop with a working battery woot!
04 ZX3 Mostly Stock ["Best Non-SVT" FITF '12][3/13 ROTM][7/14 ROTM][2014 ROTY]
12 SE Hatch Sport & Winter Package, ST Front End
94 F150 XLT 5.0 HO, OBDII Swap
89 Bronco II XLT Crawler
disciplerocks is offline
Old 04-22-2010, 07:51 AM   #85
Blivit
Blivit's Avatar
Fan#: 51292
There is no FRP sensor on the rail in a mechanical returnless system. Also, if you look at an 08+ code, there is no fuel pump voltage table. Pressure is controlled by a regulator in the fuel tank. I noticed IDS has "fuel tank pressure" which I am assuming to be what the ecu uses...but I have not logged it. I am also not sure if this is in livelink or not.
Blivit is offline
Old 04-22-2010, 11:20 AM   #86
Grommish
Fan#: 38896
FF Reputation: 1 Grommish Good Standing Member
What device are you using
Enhanced XCal 3
Year/make/model and strategy of vehicle you are logging
2003 SVT Focus
What is the firmware revision on it
Current Version:1.2.121-3000
What version of livelink are you using
Live Link 6.1
What operating system is on your computer
Win7 Pro
I know its very well documented on here, but i was asked to add this to the list.
I must also say, this is not a 'bash' on SCT, but they need to get this addressed. The SCP Protocal was "sporactic" on the old live link, and now it only logs for 10-20 seconds before freezing. When i called SCT to see when it would be address and/or who I needed to speak to about a refund so I could go get a DiabloSport, the Tech I talked to told me they "Could not reproduce" the condition on their local 03 SVTF and couldn't find a car locally that did it.. He also told me there was no evidence of an issue and, I'm quoting here, they are "working on other issues with other cars" and that the Focus Engineer "had no estimate on a firmware update"..
Again, not a bash, simply a report on what I experienced thus-far..
I've got the stock-ish SVTF as far as Engine mods, working with Tom's tune and having issues with it. I NEED to be able to datalog as the car become undrivable at times.. Without the datalog, he can't fix it and its a $500+ investment sitting as a paperweight.. (I did the XCal3, Dashscan and tune special).
When I was Datalogging, the ONLY PID's I was doing as LOAD, SPARK and ENGINE SPEED..
2003 SVTF - Stage 2 Eibach Sportlines, 75mm UDP/38MM ODP, 28.6MM RSB, CFM STS - Tuned by Tom
2006 MazdaSpeed 6 - Zoom zOOm
1998 Escort ZX2 - Currently in Pieces...
Grommish is offline
Old 04-22-2010, 11:53 AM   #87
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 63%
Yes , Understand , I am asking if the ECU controles the voltage/signal to the regulator/pump , If it does then wouldnt there have to be a signal/psi to the ECU for it to maintain fuel psi ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-23-2010, 08:17 AM   #88
Grommish
Fan#: 38896
Stupid Websense.. Double Post..
Grommish is offline
Old 04-23-2010, 08:29 AM   #89
Blivit
Blivit's Avatar
Fan#: 51292
Using IDS there was no log-able parameter for fuel pressure...or voltage on the 2010 we have here. The tank pressure was a static value.
Blivit is offline
Old 05-01-2010, 09:31 PM   #90
borchey12
borchey12's Avatar
Fan#: 66057
What I Drive: 2009 Sangria Red SES coupe
Points 130, Level 2
Points: 130, Level: 2 Points: 130, Level: 2 Points: 130, Level: 2
Level Up 60% Completed
FF Reputation: 1 borchey12 Good Standing Member
What device are you using: X3
Year/make/model and strategy of vehicle you are logging: 09 focus PRP0
What is the firmware revision on it: 1.2.121-3000
What version of livelink are you using: 6.1
What operating system is on your computer: vista
I was datalogging with Tom earlier and everything was going ok (other than the "noisy" reading from my wideband) then, I loaded the third tune from Tom and started to log, but I got a message about not getting data for 10 seconds so the log would terminate. This happens about 4 minutes into the log. I've restarted my computer several times and unplugged and replugged everything several times and keep coming up with this. Does anyone have any idea about what's wrong? Thanks for any help
borchey12 is offline
