tczx3's complete how-to on front wheel bearing replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-10-2010, 07:20 PM   #1
tczx3
tczx3's Avatar
Fan#: 48551
What I Drive: 2002 ZX3 (SVT Eng/Tran), 2002 SVTF
FF Reputation: 32 tczx3 Great Standing Member
Buy-Sell-Trade Rating: (8)
Had to replace the front wheel bearings on my son's SVT so I figured I'd how-to the process!
Note: tczx3 assumes no responsibilitiy for injury or damage while using this info!!
This is probably not for your average do-it-yourselfer as there are a few special tools required and this would be a challenge in the driveway but I don't want to discount anyones mechanical ability.
First securely position car on jack stands and remove front wheel(s). We did both sides since both wheels went the same 165,000 miles but only the drivers side was bad. I figure if you're in there doin one side might as well do both. From here out we'll discuss one side only, but obviously the same for both sides.
Remove brake caliper. 15mm bolts hold the caliper to the knuckle. Turning the wheel full lock to the outside will help with access to the bolts. Set caliper assy on suitable stand to prevent damage to brake hose. Milk crate works well!
Remove tie rod end. Nut is 15mm as well. Remove nut and use ball joint remover tool to pop ball joint out of knuckle.
Remove lower control arm ball joint pinch bolt. The nut is 15mm and the torx head is a T50. You probably won't need to use the torx to hold the bolt to remove the nut as the pinch bolt is likely seized into the knuckle. This bolt is not threaded into the knuckle either, only the nut is threaded onto the bolt. If you're lucky the bolt will come out. If you live in the rust belt like us the bolt is likely to be seized in the knuckle. As a suggestion you may want to purchase two bolts along with your new wheel bearings so if you destroy the bolt you will have a new one on hand. We were able to persuade ours out with some pb blaster and a brass hammer!
Remove strut pinch bolt. This bolt is a 15mm wrench also.
Remove bolt holding ABS wire to knuckle. Carefully pry sensor out. If it will not come out, disconnect wire at connector and remove with knuckle to remove later.
Remove axle nut. On our SVT it is a 32mm nut.
Press axle out of hub. This may or may not be an easy proposition. The RH side pushed out easily with a few taps from a brass hammer but the LH side was seriously seized into the hub. A special hub removing tool is available and may be required. You can't easily hammer the axle out, instead the axle end must be pushed out of the hub. We were able to use a gear puller to get the job done.
Pic of seized/galled axle splines:
Once all of this is done you should be able to press down on the lower control arm to pop the ball joint out of the knuckle and then work the strut out of the knuckle as well. Wa la, knuckle in hand!
No more knuckle!
You will need a hydraulic press to remove the flange and bearing from the knuckle. An arbor press will not do it!
You will need to press flange out of bearing first. This will split the inner race in half. Half will stay in the bearing, half will be on the flange. Note the press set up in the pics.
Make sure you are pressing on the end of flange to press it and part of inner race out. This is what you'll get:
We'll cover removal of the inner race in a few....
Remove circlip from backside of knuckle.
Press bearing out of knuckle, again note press set-up:
Press inner race off of flange
Note use of bearing puller/holder to secure inner race. A little heat on inner race may ease removal. Note flange surface. The wheel bearing 'kits' include a flange so this step is not necessary.
What's left of the old bearings:
Clean up the flange and knuckle. Red scotch-brite helps to polish up the surfaces for re-installation of bearing/flange.
New bearing and parts ready to go:
Press the bearing into the knuckle first. Remember to press on the outer race only! Do not press on the inner race to force the bearing into the knuckle. You will damage the bearing!
Reinstall circlip. Circlips do have a up and down. The 'sharp' corner of the circlip should face 'up'.
Remember also.... If you have ABS the black seal must be towards the inside of the knuckle or your ABS will not work. And the circlip ends must point up with the opening at the hole in the knuckle for the ABS sensor.
Press wheel flange into bearing. Again remember to press against the inner race only. Support the flange and press knuckle/bearing assy onto flange.
This is what you should have when you're done:
Now you're ready for reassembly. Clean up all components on car: LCA stud, tie rod end, strut end, etc. Clean splines on CV axle thoroughly. I used a Moly paste on the splines for reassembly to ease removal next time. A normal grease will not really work as it will squeeze out of the splines under load. The Moly paste will not. Same as GM drive shaft spline grease.
Reassemble in reverse order and torque to correct specs.
Be sure to inspect all components for wear and replace if neccesary... LCA ball joint, tie rod end, brake pads, etc.
We replaced the sway bar end links while in there. Note new links compared to old. Liftime warranty, greaseable, only $16!
And hopefully you're all done!
Previous mod..... Dual outlets!
2002 ZX3SVT SVT engine/trans conversion w/ SVT guages, headlamps, front grille, bumpers, 17" Euro, Hankook Ventus V12, AEM CAI, Borla
2002 SVTF Infra Red! Stock w/ Dual oulet exhaust and rolling on Proxes 4
2002 SVTF Pitch Black-Dad's new ride!
tczx3 is offline
Old 01-10-2010, 07:56 PM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Very nice! I'm needing to do this soon myself.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 01-10-2010, 08:07 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Good pics and walkthrough. Wish I owned a press.
BC_ZX3 is offline
Old 01-10-2010, 08:21 PM   #4
norcalfocus01
Fan#: 55603
Great write up.
Where did you get the endlinks from? Were thay 16 ea or for the pair?
norcalfocus01 is offline
Old 01-10-2010, 08:38 PM   #5
tczx3
tczx3's Avatar
Fan#: 48551
Endlinks were $16 each, bearings $32 each. Got both items from a local car parts wholesaler. Not sure how they compare to the Moog that alot of guys use, but were readily available to me from local vendor.
tczx3 is offline
Old 01-10-2010, 09:44 PM   #6
focuzed1
focuzed1's Avatar
Fan#: 10722
What I Drive: 2002 liquid grey zx3
Points 10,971, Level 69
Points: 10,971, Level: 69 Points: 10,971, Level: 69 Points: 10,971, Level: 69
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 16 focuzed1 Great Standing Member
Buy-Sell-Trade Rating: (15)
Great write up.. sticky nomination...
Too Fast For Me... TONS OF WHP... GOBBS OF WTQ......
Go ahead put your car where your mouth is....
focuzed1 is offline
Old 01-13-2010, 05:50 PM   #7
norcalfocus01
Fan#: 55603
Sticky'd
Old 01-16-2010, 10:44 PM   #8
focus2ner
focus2ner's Avatar
Fan#: 43573
What I Drive: 2002 silver ZX3
FF Reputation: 1 focus2ner Good Standing Member
All I have to say is THANK YOU! I have to do my drivers side and was a little confused on doing it. But this will help a lot!
Posted via FF Mobile
focus2ner is offline
Old 01-19-2010, 11:35 AM   #9
TheGeak
TheGeak's Avatar
Fan#: 9559
What I Drive: '04 CD Metallic Silver ZX3
FF Reputation: 3 TheGeak Good Standing Member
Wow...how did you EVER get your Strut Pinch Bolt loose? Looks like you managed it with a 3/8" ratchet with a 15mm socket...I'm on my way out to Sears to buy a 15mm 1/2 drive socket and a 18" breaker bar! I've tried WD-40, PB Blaster, Heat, hammer, and just wow...it won't budge. I figure we will see how it holds up against the laws of Physics!!
Otherwise a GREAT write up so far! Despite your warning I'm doing this in my drive way with the help of a local shop (who is going to press the actual bearings for me)! Hopefully if I can liberate this bolt I will be back on track!
Breaker Bar and Socket worked, bolt is loose! I still can't get the lower control arm to pop out OR get the rotor to come off (I feel really stupid, but the thing won't BUDGE!)
---Jason
TheGeak is offline
Old 01-19-2010, 01:14 PM   #10
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
For the control arm, tie a bar to the control arm using a chain wrapped around both. Get it good an snug then just stomp on the bar. I think I got that out of the Haynes manual.
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
