how do you change the headlight bulb on a 07 focus? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-09-2010, 07:48 PM   #1
puppetman
rawr
Fan#: 65577
What I Drive: 07 ZX3, 86 honda vf500f, 81 Vespa
Points 3,508, Level 37
Points: 3,508, Level: 37 Points: 3,508, Level: 37 Points: 3,508, Level: 37
Level Up 6% Completed
FF Reputation: 3 puppetman Good Standing Member
ok, well this seems like a stupid question but i want some confirmation on the subject, and im hoping ford designers arent this retarded when it comes to basic maintinence.
the drivers side headlight blew and i was trying to change it today. i took the two bolts out off that seem to be holding the headlight housing in, but it still wouldnt budge. so i did a few searches on this trusty forum, but i want a bit of clarity on it.
i read that for the 05-07 models there is a bolt attaching the housing to the frame of the car, and to remove it you have to go through the wheel well. this is pictured and explained in the thread on how to paint the headlights.
so my question is, in order to change the bulb, is all of this really necessary? or is there a way to get into it without full removal of the housing? its colder than a witches tit outside and i dont want to be out there jacking the car up and digging in the wheel well right now.
so thanks in advance guys.
in illinois there are 4 seasons....almost winter, winter, still winter, and construction
Originally Posted by blackoutSVT View Post
hey man don't hate, it cost alot of money to look that cheap...
puppetman is offline
Old 01-09-2010, 10:45 PM   #2
puppetman
rawr
Fan#: 65577
oh come on
Old 01-11-2010, 08:50 AM   #3
Justin J
Fan#: 49087
What I Drive: '07 SES sedan, SAP, 5 speed
FF Reputation: 2 Justin J Good Standing Member
Just unbolt the cruise servo, take off the rubber boot on the headlight and remove the bulb? I've never removed the headlights to replace bulbs on the focus. Pass side is easier, no part removal necessary.
Justin J is offline
Old 01-11-2010, 03:54 PM   #4
puppetman
rawr
Fan#: 65577
cruise servo? would that be the plastic center peice thats over the grill? i didnt try taking that off because i didnt think i would be able to reach in far enough to get to the bulb
Old 01-11-2010, 06:21 PM   #5
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
On my '06 (same as an '07).........On the passenger side, remove the rubber boot from the back of the housing, and unsnap the connector from the bulb and pull it out of the way.
Reach your fingers in there and turn the plastic holder ring counter-clockwise, about 1/4 turn or so. Then the bulb and ring will just pull out. Reverse the procedure to reinstall....that bulb has a location tab, so it will only go back in at a certain angle.
On the driver side you may have to remove a few pieces.....I have an SRI, so I have to remove my air filter to get to the bulb. First time I did the whole job.....I almost pulled my hair out getting the attachment ring loose.
I'll keep my guns, my freedom, and my money.....you can keep the "change".
bluefront is offline
Old 01-11-2010, 06:30 PM   #6
puppetman
rawr
Fan#: 65577
then would it just be easier if i did it like this guy says, http://www.focusfanatics.com/forum/s...ad.php?t=59986, and i remove the whole headlight? thats really my question..i was just wondering if there was an easier way
Old 01-11-2010, 08:37 PM   #7
Justin J
Fan#: 49087
The cruise servo is right next to what looks like an air filter housing. It's a black/silver box with a cable coming out of it that goes to the throttle body. 2 or 3 10MM bolts and it's off. Then it's wide open to the back of the headlight. The black plastic piece between the headlights does not have to come off.
Justin J is offline
Old 01-12-2010, 07:14 AM   #8
bluefront
bluefront's Avatar
Fan#: 56816
What do you want to do......just change bulbs or the whole housing? If you just want new bulbs, it's silly to remove the entire housing. That would take 3x as long.......
Old 01-12-2010, 09:01 AM   #9
puppetman
rawr
Fan#: 65577
ooh ok. yeah all i want to do is replace the bulb. i just thought removig the housing would simplify it but i guess not. on my previous car, and on my moms hundai, the housing would just unbolt with 2 or 3 easy screws and then you could swap the bulb.
thanks guys i will look into this later today when i get back from school
Old 01-12-2010, 01:37 PM   #10
puppetman
rawr
Fan#: 65577
ok i removed the cruise servo and got to the bulb just fine. thanks again guys +rep to you both for bearing with me
