Brake Problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-30-2009, 11:23 PM   #1
djbasick
djbasick's Avatar
Fan#: 41693
What I Drive: 2004 CD Silver ZX3
Points 530, Level 10
Points: 530, Level: 10 Points: 530, Level: 10 Points: 530, Level: 10
Level Up 60% Completed
FF Reputation: 4 djbasick Good Standing Member
Unhappy Brake Problem
After replacing the pads and rotors on the front I ran into a problem.
Keep in mind i have not bled the brakes because i did not detach any brake lines. I also did not see any brake fluid leak from anywhere.
The pedal would travel with no response until it was about 2 inches from the floor then it would engage the brakes just as normal. I am thinking its a problem with just having to bleed the brakes and for whatever reason i have air in the lines, or its a problem with the master cylinder. I also noticed that the emergency brake light would come on if i were to rapidly press on the brake pedal, mind you that I noticed the light come on after I cleaned my rear drum brakes. Has anyone had a similar problem?
Any input would be greatly appreciated!
thanks
basickly speaking........
ZETEC CREW #118
Steeda SRI, ST170's + 8000K H.I.D., Mono MTX Amp, 1 Farad Cap,Pioneer 12 X2
djbasick is offline
Old 12-30-2009, 11:26 PM   #2
05yellowd20
Fan#: 62464
What I Drive: 2005 Yellow ZX3 2.0 Duratec
FF Reputation: 15 05yellowd20 Great Standing Member
Buy-Sell-Trade Rating: (4)
sounds like you didn't pump your breaks up and preset the self adjusters (if you did the rears) before driving.
05yellowd20 is offline
Old 12-30-2009, 11:49 PM   #3
djbasick
djbasick's Avatar
Fan#: 41693
so I should just undo the rear drums again reset the adjusters and it should be good?
ZETEC CREW #118
djbasick is offline
Old 12-30-2009, 11:52 PM   #4
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,748, Level 78
Points: 14,748, Level: 78 Points: 14,748, Level: 78 Points: 14,748, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
you should check your brake fluid level before anything. there is also a sensor in the resivior that uses the light.
goinloco1 is offline
Old 12-30-2009, 11:54 PM   #5
djbasick
djbasick's Avatar
Fan#: 41693
I looked and the fluid level is up past max
ZETEC CREW #118
djbasick is offline
Old 12-31-2009, 12:18 AM   #6
05yellowd20
Fan#: 62464
Then yes more than likely your rear pads are not contacting the drums. In theory you can drive in reverse and hit the brakes several times and it should self adjust. But i find it easier (on most cars) to just adjust the self adjusters so they are fairly close.
Old 12-31-2009, 12:31 AM   #7
djbasick
djbasick's Avatar
Fan#: 41693
thanks man ill try that in the morning and let you know what happens
ZETEC CREW #118
djbasick is offline
Old 12-31-2009, 01:01 AM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,445, Level 65
Points: 9,445, Level: 65 Points: 9,445, Level: 65 Points: 9,445, Level: 65
Level Up 32% Completed
Forum Activity 8%
Pulling your ebrake also adjusts the rear drums from what I have been told.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
Old 01-01-2010, 06:17 PM   #9
djbasick
djbasick's Avatar
Fan#: 41693
two things:
1. i put the the front brake pad clip that holds it onto the caliper on wrong so it wasnt letting the entire caliper grip onto the rotor.
2. the rear had not been self adjusted as was mentioned above.
Thanks for the help guys.
ZETEC CREW #118
djbasick is offline
Tags
brakes , fluid , master cylinder
