Wiring LEDs up to a switch box - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 08-12-2004, 04:18 PM   #41
PreciousAngelJS25
Forced to move on...
PreciousAngelJS25's Avatar
Fan#: 10406
What I Drive: RIP: 2002 ZX5 LG "Sexi Rexi" :(
FF Reputation: 5 PreciousAngelJS25 Good Standing Member
Yeah I never thought about doing the vent LEDs. They just never hit me as something I'd wanna do. But I always wanted to do the LEDs under the dash and in the back. I think I will take your advice about putting the switches in the fuse box door. So what is the "prob" with hooking up the LEDs to one of the fuses rather than hooking it up directly do the battery??
RIP: Sweet Rex 2002 ZX5
May 2002-July 29th, 2011
gumpcrew #13
HatchNation #122
\m/ (>.<) \m/
PreciousAngelJS25 is offline
Old 08-12-2004, 04:20 PM   #42
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
There isn't a problem, it's just easier IMO to just run right from the battery cause then your not messing with the vehicle's fuses and all that. You can easy draw power from the fuse panel also, it's very easy like how I posted.
It's just my personal preference.... that's all.....
Chad (S2)
S2 is offline
Old 08-12-2004, 04:32 PM   #43
XfocusX
Fan#: 6997
What I Drive: 2k1 tw.blu.met se sedan
FF Reputation: 1 XfocusX Good Standing Member
so for the fuse run off, you just put the pos wire into the fuse slot and shove it(fuse) back in? which fuse?
Nor-Cal SPI Syndicate Boss
XfocusX is offline
Old 08-12-2004, 04:34 PM   #44
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
I actually don't know... there are 'accessory' fuses in there. I always tied into one that already had a fuse in there but you can actually just use one of those 'male terminals' and put it into an empty slot if there is one, can't remember, I will go look on my car right now, back soon ok..... 5 minutes......
Chad (S2)
S2 is offline
Old 08-12-2004, 04:36 PM   #45
PreciousAngelJS25
Fan#: 10406
Yeah i was wondering the same thing too.
Could you explain again how to hook it directly to the battery again??
gumpcrew #13
HatchNation #122
\m/ (>.<) \m/
Old 08-12-2004, 04:36 PM   #46
XfocusX
Fan#: 6997
[led]-------pos________[switch] _____pos______[fuse]
|_____neg________ [ switch]_____neg______[ground]
both switches are only one.^ could not make it work only once inthe pic. he he
XfocusX is offline
Old 08-12-2004, 04:41 PM   #47
XfocusX
Fan#: 6997
and a male terminal, is thad just a fuse looking little guy, and you put it into any one of the open fuse slots? can i get one at the parts sture? is it called a male terminal, or something else?
XfocusX is offline
Old 08-12-2004, 04:42 PM   #48
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Fuse 52 would work, there shouldn't be a fuse actually in there but you can use the male terminal to get power from there. I also checked to make sure and ALL my neons are all run from a direct wire from the battery (I RECOMMEND THIS).....
Chad (S2)
S2 is offline
Old 08-12-2004, 04:43 PM   #49
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
Correct.....
Chad (S2)
S2 is offline
Old 08-12-2004, 04:47 PM   #50
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
The negative wires (grounds) don't go to the switch...... they go to the actual car (grounded to the steel of the car).
Might help if you know how a switch works, let me try to explain below.....
A switch has two terminals (three if it is lighted) but we are just going to use the two terminal switch. Anyway, here is sorta a 'pictograph' of what the switch looks like off and on....
OFF ( ------/ \-------- )
ON ( -------------------- )
The vertical lines when the switch is flipped cause the current to continue on with it's path. If the switch is off, it breaks the flow by breaking the circuit. Does that make sense.
Chad (S2)
S2 is offline
Similar Threads
HOW-TO: Making an Ashtray Switch Panel (for neons, LEDs, and whatever else) OrangeSVTguy MK1 Interior Mods & Upgrades 71 11-14-2012 11:14 PM
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 10:59 AM
Interior LED's & Wiring?? RideRed0331 MK2 Interior Mods & Upgrades 27 09-13-2008 01:32 PM
Window Switch LEDs joshfink MK1 Interior Mods & Upgrades 4 06-03-2008 09:21 AM
Window LED Switch Problems! :( ouikikazz MK1 Interior Mods & Upgrades 7 12-08-2006 08:47 AM
