2000 2.0 SOHC SPI Auto swap to 2.0 DOHC Z Auto ? Bolt in? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 12-10-2009, 04:08 PM   #1
2000 Wagon
Fan#: 71180
What I Drive: 2003 Gold SE Wagon
FF Reputation: 1 2000 Wagon Good Standing Member
Question 2000 2.0 SOHC SPI Auto swap to 2.0 DOHC Z Auto ? Bolt in?
Bought a 2000 wagon with a totaled 2.0 SOHC SPI Auto. Will any DOHC bolt in? Can buy a used DOHC for about the same $$$ as a SOHC. Can I get lucky here?
Thanks. jay
2000 Wagon is offline
Old 12-10-2009, 04:21 PM   #2
dsmuts
dsmuts's Avatar
Fan#: 56574
What I Drive: 97 Black SHO
FF Reputation: 9 dsmuts Good Standing Member
Its a little more involved that just bolting it in. you need the wiring harness as well as a few other pieces IIRC. I'd just go with the SPI it would be an easy swap then.
"Don't make me angry, you wouldn't like me when I'm angry"
dsmuts is offline
Old 12-10-2009, 08:27 PM   #3
02_z_x_3
Fan#: 53977
What I Drive: 02 zx3
Points 4,381, Level 42
Points: 4,381, Level: 42 Points: 4,381, Level: 42 Points: 4,381, Level: 42
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 4%
FF Reputation: 9 02_z_x_3 Good Standing Member
Buy-Sell-Trade Rating: (13)
yes you would need the ecu and the wiring harnesses. everything else is the same including the trannies
02_z_x_3 is online now
Old 12-12-2009, 03:02 AM   #4
Broncoboy80
#MattinglyBuilt
Broncoboy80's Avatar
Fan#: 59885
What I Drive: 2014 BRZ, 1993 RX7 FD
Points 6,684, Level 53
Points: 6,684, Level: 53 Points: 6,684, Level: 53 Points: 6,684, Level: 53
Level Up 67% Completed
FF Reputation: 13 Broncoboy80 Great Standing Member
Buy-Sell-Trade Rating: (8)
Trannies? No no no, they are not the same. However, if you beleive they are then i got an IB5 tranny sitting in the garage i can sell you! haha
Your going to want the Motor, motor mount for the pass. side, tranny, ecu then your set sir
CREATOR OF THE CLEANEST FOCI's
Instagram - #MattinglyBuilt
Originally Posted by HaveBlue83 View Post
^yo, that bitch is LOW and clean!
Broncoboy80 is offline
Old 12-12-2009, 10:05 PM   #5
02_z_x_3
Fan#: 53977
Forum Activity 4%
no all auto focuses use the 4f273 trannies. well the '00-'04's at least. i know i have a spi tranny on my girlfriends zetec motor right now. the autos are the same, the manuals however are not. the zetec uses a mtx-75 and the spi uses the aforementioned ib5. auto to auto you are safe using the same tranny.
Old 12-13-2009, 01:45 AM   #6
02_z_x_3
Fan#: 53977
Forum Activity 4%
excuse me 4f27e tranny
Old 12-13-2009, 05:35 AM   #7
Broncoboy80
#MattinglyBuilt
Fan#: 59885
Did i mention i got a spare IB5 in the garage for sale!?!?! I think i did, just slaper on there
Old 12-13-2009, 05:31 PM   #8
dsmuts
dsmuts's Avatar
Fan#: 56574
Auto's are the same. I forgot about the ECU. I'd just get another SPI though and keep driving it.
dsmuts is offline
Old 12-20-2009, 02:40 AM   #9
Focus_Happy
Focus_Happy's Avatar
Fan#: 62197
What I Drive: 2 SVTs & 1 Electric
Points 306, Level 6
Points: 306, Level: 6 Points: 306, Level: 6 Points: 306, Level: 6
Level Up 12% Completed
FF Reputation: 2 Focus_Happy Good Standing Member
Buy-Sell-Trade Rating: (4)
Just completed swap project
O.K., I just finished swapping my SPI (dropped valve seat) to a Zetec. I have a '00 wagon and I decided I didn't want to put another engine in that was prone to dropping valve seats. So with all certainty I can say that yes, the ATX transmission will swap between the two engines. However, there is much more involved than just swapping the engine, ECU, and wiring harnesses. The following is a list of things I had to swap during the conversion and is not necessarily all inclusive:
Motor (obviously).
Pass. side motor mount & black support bracket (I swapped the mount and not the bracket and couldn't figure out why everything wouldn't line up).
ECU.
ECU wiring harness (splice in to the rear of the wires running under front pass seat, otherwise you'll have 3 GRN/BLK wires to figure out where they go before you can solder them up).
ATX wiring harness (connectors are different for alternator & rear O2 sensor).
A/C compressor.
A/C line segment that attaches to compressor.
Throttle cable (different connector to TB).
Cruise control cable (different length).
Fuel line from firewall to fuel rail.
Flex pipe.
MAF to TB intake piping.
All cooling hoses & plastic piece on front cross member.
Fuel inertia shut off switch (different connector... or you could cut & splice).
Power steering line from pump to steering rack.
I think that pretty much covers it, as long as you get an engine that has an alternator, starter (with wiring), and CAT included. After doing this swap, I would recommend that if you are going to go through that much work to your vehicle, you might as well just fork out the extra $$$ to get the transmission (and the wiring harness for it) already attached to the engine and go to a Duratec setup. Just my opinion, but you might be happier with the results. Or you could always get a rebuilt SPI. Your call, but I can say it was a fun learning experience for me. If you have any questions, please feel free to PM me.
I hope this helps someone else trying to decide if this is something that they would like to do or not. I looked all over the internet to see if anyone had actually done this and what was involved, but couldn't find anything concrete, so here you go.
Last edited by Focus_Happy; 01-28-2010 at 02:15 AM. Reason: Found that original cruise control module works with new cable.
Focus_Happy is offline
Old 12-20-2009, 11:28 AM   #10
InfraRedSVTF
InfraRedSVTF's Avatar
Fan#: 17442
What I Drive: 2013 Focus ST3/2015 Fiesta ST
Points 3,504, Level 37
Points: 3,504, Level: 37 Points: 3,504, Level: 37 Points: 3,504, Level: 37
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 3 InfraRedSVTF Good Standing Member
Why bother splicing wires, when you can drop the gas tank down a few inches by removing just one bolt, and plugging the wires in on top of the tank, and fishing the rest to the back of the tank where they plug in. It is way easier, and less chance of electrical problems later. I have changed out at least half a dozen of these, and it is really easy once you look closer at it.
I <3 Bewst!
InfraRedSVTF is offline
